Question about Mitsubishi HC1600 Projector
HC5000 master reset
There is a secret button push to initalize the microprocessor on the HC 5000 projector. For service purposes.
It is supposed to fix the non-responsive menu problem.
Can you tell me what the button push sequence is?
2 Suggested Answers
SOURCE: how do you play video games on the lcd projector
with HDMI cable on my Xbox360.
just select HDMI Entry
Posted on Dec 05, 2011
How i enter service mode on RISO HC 5000
first press print/pause and get print mode off
then press middle up button first and while pressing it menu and ok also press
then type ASTU
Sep 15, 2014 | Riso HC5000 HIGH SPEED COLOR INKJET...
How to know if HC5000 lamp is out
Lamp timer mean nothing in the end its just a light bulb and can go at any time.
Dec 05, 2011 | Mitsubishi HC5000 LCD Projector
After cleaning my solis, the machine wont switch back on. i've checked power supply and made sure the service door is closed.
Hi
On Master 5000's there is either a fuse or reset button on the back side of the boiler. The fuse is under a clamp on the side. The reset button is between the 2 black wires (white terminals) on the back of the boiler (front of the boiler is towards the front of the machine). If you machine is 2004 or older then you might have a fuse (they made the switch in 2004).
May 17, 2011 | Solis Master 5000 Espresso Machine
I follow all the steps to reset the filter time and lamp time with a new bulb but it will not reset any ideas
This Projector is controlled by an internal microprocessor. Under certain exceptional circumstances, the projector may not operate correctly and the microprocessor will need to be reset. In such a case, please push the Restart switch by using a cocktail stick or similar and before turning on again, make the projector cool down at least 10 minutes without operating. Only push the Restart switch in these exceptional instances.
Jan 03, 2011 | Hitachi CP-S335 Multimedia Projector
Our Mitsubishi HC5000 can no longer project red but the other colors still work. What can we do to fix it? Thanks,
What input are you using. If vga check the pins on the port of the projector or the vga cable may have a damaged bent/broken pin. component may have a bad cable.
Jun 06, 2010 | Mitsubishi HC5000 LCD Projector
Turn on of unit sometimes does not light lamp. Red/Green flashing light, then turns on the next time. (Using button on unit) When using remote, can sometimes get it to turn on the first time (without going...
I'm having the same issue now. Did you ever figure out what was wrong with your unit? Was it a bad lamp? Mine is only 9 months old, low hours, but perhaps a bad one? Can't understand why it would light sometimes but not others.
Jul 01, 2009 | Mitsubishi HC5000 LCD Projector
Master Reset
the OPCODe can master reset the phone. I screwed up my phone by trying to change the theme and evry time i pressed menu the phone restarted. However, i found a post on another site that read...
For me, Motokit, PTS, and the reset of the tools could not reset my phone. Here's how I reset my phone with just the phone keboard.
This will reset all your menus. On my Verizon Razr V3m phone, my contact and my picture gallery were not affected. (Make sure you key the command in exactly. 18*1 is Master Clear, and you don't want do to that.
From your phone, enter this sequence to go into OPCODE mode fairly quickly:
Press CLR then
048263*
This puts you in OPCODE mode, where you can enter special commands. Be CAREFUL here.
Enter a the code for a Master Reset command:
18*0
Press the middle navigation button.
Wait. The screen should show "SUCCESS" after a few seconds.
Push the LEFT soft key (back). You'll be back at the OPCODE screen.
Push the RIGHT soft key (options). Push this button again to select Cancel Entry (the only option).
This gets you out of OPCODE and back to where you started. You might have to push CLR a few times to clear the number you entered to get into OPCODE mode.
It was really helpful
Aug 16, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Mitsubishi HC1600 Projector Logo
203 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
