Question about Kenmore 22422 Top Load Washer
Kenmore 70 series Heavy Duty washer model 110.82872100
My washer was purchased in 1987, it has been in storage for at least 15 yrs. I have since started using it and it works fine for 2-3 loads then the problems start. The washer has to sit for at least a week before its fine again.
I do not use perm press cycle anymore because after the first rinse it will not drain, spin nor agitate.
The cotton/sturdy cycle misses the first rinse cycle, trips the circuit breaker, the console makes a popping sound at the final rinse with shooting sparks(this happens after washing my 2nd load). The popping and sparks have caused two burn holes on my front panel.
Also, I have to turn the knob several times before it will make the connection to wash and sometimes it does something opposite of what it is suppose to do i.e. spin and its filling up with water or agitating.
What could the problem be or is it time for a new washer?
  • carolynrterr Jan 31, 2009
    I am a diy type person and would like to try and fix it before buying a new one.
    I have taken the cover off and there is alot of loose burnt tissue/wrapping paper type of material everywhere under the panel (like a firecracker that has exploded) there are small amounts of black sticky stuff on the paper and on some of the wires(may be whats left of the electrical tape). None of the wiring are frayed, loose or cut, but the round plug connector thing (i was able to disconnect from the prongs) connected by two red wires is in very bad shape so i'm off to the repairman. Thanks, I'll keep you posted.
  • carolynrterr Feb 01, 2009
    Ok, the part that was blown to smithereens turned out to be the capacitor(I had taken the kenmore washers part manual with me) and Sundberg Company had it in stock for $35.24. I have reconnected the part and have been catching up on laundary...no more tripped circuit breakers or sparks shooting out and all cycles are working perfectly.
    Even though my Kenmore washer is 22yrs old Sundberg Company, Chicago, IL, (773)723-2700, www.appliance-parts.com still has parts for it.
    I sure didn't want to have to buy another washer!
    Thanks everyone for you help!
  • 318 Answers
You probably have a bad or burnt contact in the timer. it could have had bugs get into it during the storage. it does happen. a new timer could cost 120-150 bucks and i dont think you will have much luck with an over 20 year old washer. if you did replace the timer then what would be the next thing to fail?
save your money and go out and buy a new roper or whirlpool built unit. roper is the cheaper version from whirlpool and has the exact same parts.
you can find a new unit for about 275-300 bucks. it will be a much better choice for you in the long run.
Posted on Jan 31, 2009
  • 27 Answers
You should have a couple screws in back or on the sides of the front panel. UNPLUG your washer and take this panel cover off. Check for loose wires and bad connections at the terminals. If you find a frayed/cut wire you can use electrical tape to fix the issue. It might be something as simple as a loose connector, but if it looks like a broken connector try to take that part to a repairman in your area for servicing.
I would advise that you leave this washer UNPLUGGED completely until you get it fixed/replaced, though. This is the type of thing that starts undetectable house fires in the middle of the night...
4 Suggested Answers
  • 17 Answers
SOURCE: Model 110 top loading washer will not spin
check belt
Posted on Apr 10, 2009
  • 714 Answers
SOURCE: kenmore heavy duty 70 series model 110-8237012
probably your drain pump leaking it has a seal right where it attaches to motor,,,,mine is leaking there but haven't replaced it yet! lol
Posted on Feb 28, 2010
  • 4332 Answers
SOURCE: Kenmore heavy duty 110 9238
Most common issue is foreign material in the valve. take it apart and clean or replace it.
Posted on Dec 07, 2010
Kenmore heavy duty 70 series model 110-8237012
Feb 27, 2010 | Kenmore Washing Machines
I lost 23 small rhinestones from jewelry in washer...
Yes. They can get trap in the pump, if they got in between the inner and outer tub.
Dec 12, 2009 | Kenmore 22422 Top Load Washer
Kenmore Heavy Duty 70 Series Leaking in the back
If you bought a new washer and you still have a leak, i guess it was not the washer but where it drains into. Sink or stand pipe has a leak. unless you are useing the old drain hose from your old washer. Dry up everything and look for the sorse of water with a bright light when the washer drains .
Nov 22, 2009 | Washing Machines
I have an old Kenmore Heavy Duty 70 series washer.
its a filter inside the water hose thats still blocked or the relay inside the washer for the cold feed is not opening up fully it could just need a clean or maybe a new one fitted
Nov 05, 2009 | Kenmore 22422 Top Load Washer
Help with Kenmore washer 70 Series
I called a repair man. The machine, it turns out is gear driven, and all the gears were shot.
May 27, 2009 | Kenmore Washing Machines
What is the date of manufacturing based on the serial number of my Kenmore 70 series washer?
Tyler,
It came off of the Clyde, OH production line the 26'th week of 2001.
Amazing, ain't it? Seriously... the info is embedded in the serial number. Here's the link to the code sheet.
Please remember to rate this solution as "FixYa", OK?
SG
May 02, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer will not empyy water or spin or wash on any cycle
something caught in drain pump, clamp hoses and remove pump inspect repair or replace.
Apr 04, 2009 | Kenmore 22422 Top Load Washer
Kenmore 82372110 70 series heavy duty plus won't spin
If it drains and won't spin you have to replace the direct drive coupling.
Feb 25, 2009 | Kenmore Washing Machines
Slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
Dec 30, 2008 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
646 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
