Question about Brother MFC 210C All-In-One InkJet Printer
Mfc 210c my printer keeps on saying paper jam...i already remove the paper jam..please help me
  • 27 Answers
If you are certain that you have removed all paper, try power-cycling your printer. Remove power cord and wait a minute or two then plug back in.
Posted on Jan 31, 2009
I have a Brother MFC 420cn and it keep saying paper jam and there is no paper jam help please
->Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
->To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
->For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
->Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
->Try printing another document
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Feb 25, 2013 | Brother MFC 420CN All-In-One InkJet...
Have an Error 51 on Brother MFC-210C all in one printer?
I can help you with your Brother MFC-210C error 51 problem.
Error 51 refers to a paper jam error.
Clear the paper jam to clear the error code.
If the error code will not clear after clearing the jam, resetting and powering off, the printer may require service.
I hope that helps.
Aug 30, 2010 | Brother MFC 210C All-In-One InkJet Printer
Screen says
If there is no jam it is generally a mechanical issue such as...
1. The planetary arm assembly not engaged correctly
2. Ink cartridge/purge switch harness not connected correctly
3. Purge cam switch broken
4. Gear(s) on maintenance unit broken
5. Paper feed motor broken
6. Main PCB defective
I find that if there was a paper jam, and the user pulled the paper out, option 4 is most likely. It is the smallest of cracks but ruins everything! You will need to see an authorized service center for repair.
Jan 27, 2010 | Brother MFC 210C All-In-One InkJet Printer
When printer turned on it says paper jam clear paper,why
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 07, 2009 | Brother MFC 210C All-In-One InkJet Printer
Paper jam problem
Remove the back cover and put an index card thru where the paper goes, that should push out any left over scraps.
Jul 22, 2009 | Brother MFC 210C All-In-One InkJet Printer
My Brother can not function because the LCD appears Jam Paper
There might still be a piece of paper stuck when you pulled the paper out or the paper sensor might have remained in an active position. Just Have to put it back in position.
May 21, 2009 | Brother MFC-210C All-In-One Printer
Printer says paper jam, but there is no paper in the printer. (mfc 210c)
If the paper tore when removing it, chances are there could be a small piece of paper still causing the paper jam. Sometimes all you need to do is turn the fax off for a few minutes and then turn it on again and the paper jam message is gone
May 10, 2008 | Brother MFC 210C All-In-One InkJet Printer
How to replace back cover of MFC-210C?
There are two clips on either side which need to be squeezed together then the cover can be slipped back into position.
Apr 16, 2008 | Brother MFC 210C All-In-One InkJet Printer
Unable to print
press menu then start mono (blue button) then fourtimes arrow up (tel-index). Machine will be in maintenance mode and lights will flash. What error code does the machine display?
(to leave the maintenance mode press 9 then 9)
Nov 26, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
168 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
