Question about Acer AL1917W LCD Monitor
Al1917w lcd monitor resolution problem
Hi, I recently bought an 19-inch widescreen LCD Acer (al1917w lcd) monitor without checking in advance whether I might come across any resolution problems, given that my display adapter (video and graphics card) is not exactly the best of its kind. I am running Windows XP and the adapter is a 32 MB intergrated S3 Graphics ProSavageDDR. The highest resolution I can get using what Windows claims to be the best / newest driver is 1280 x 1024 (other options are 1024 x 768 and 800 x 600 and the same problem happens if I use them). Everything on my monitor now appears too wide, especially images which appear distorted. Recommended resolution for this Acer is 1440 x 900. What could I do to make that resolution an option? Is that possible at all with my current video card? If I definitely need a new graphics card, what do you recommend? I connect the monitor to the PC using a VGA cable. My card does not support a DVI cable so I can't try using that. Thanks in advance!
  • Dimitar Vlahov Jul 31, 2007
    the guest comment was from me, Dimitaer. I am not satisfied with the offered solution, as it does not really help.
  • Dimitar Vlahov Aug 10, 2007
    Could anyone else suggest a better solution?
Get a new video card, you dont need the best video card to support 1440*900. It is affordable and the best solution.
Posted on Sep 10, 2007
I have the same problem! Here's what I did: Go into the Display control panel, go to SETTINGS, click on ADVANCED, and then on the ADAPTER tab, then on LIST ALL MODES. There are several 1400 settings. Try them out and see which one is best for you.
Posted on Aug 10, 2007
How to increase scren resolution I have bought a 21.5 inch widescreen Asus monitor & am running windows XP but do not have the resolution sugested every thing looks small & long when looking at...
read this article of microsoft about changing resolution
http://www.microsoft.com/windowsxp/using/setup/personalize/resolution.mspx
Note: you need an HDMI cable to change the resolution of your pc to 1920 x 1080
Jan 21, 2011 | ASUS VW246H 24 Widescreen LCD Monitor,...
I install window 7 but my benq 15" lcd monitar's screen rosuation not competible. pls guide me how i increase the rosulation thnx
As for your 15" LCD BENQ Monitor, "1024 x 768" pixels is the Maximum Resolution
If you increase your screen higher than the Maximum resolution you get a black screen! because the monitor cannot support the resolution higher than "1024x768" pixels.
How to change your screen resolution Win 7-> Link
FYI
Here are typical resolutions for some popular screen sizes
19-inch screen (standard ratio): 1280 x 1024 pixels
20-inch screen (standard ratio): 1600 x 1200 pixels
22-inch screen (widescreen): 1680 x 1050 pixels
24-inch screen (widescreen): 1900 x 1200 pixels
Hope it helps.
Nov 22, 2010 | Computers & Internet
Acer monitor al1917w-a problems
I assume that you already try this monior with other PC and still get the same problem. You may have to open it up and inspect the inside, look for bad components such as capacitors in the power supply, the problem can also be inthe backlight inverter circuits also. See example of failed monitors: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 26, 2010 | Acer AL1917W LCD Monitor
I have changed to an Acer 19in wide screen monitor, my photo albums appear as wide screen pics
You need to set the PC video resolution to 1440 x900 @60Hz which is the native resolution of this monitor.
Mar 17, 2010 | Acer AL1916W 19" WideScreen LCD Monitor
Round things are shaped like eggs
This is a widescreen monitor. To get the display to look right, you need to install the software that came with the monitor, and set the resolution to the manufacturer's recommended setting (the monitor's "native resolution"). I don't know what that is for the AL1917W. I have the AL1917, not the widescreen. A friend got a 21-inch widescreen and had the same trouble as you until we set it to the proper resolution. (And it looks great and I'm jealous!)
Nov 17, 2008 | Acer AL1917W LCD Monitor
Vertical size
LCD monitors auto adjust and use a fixed resolution. It's impossible to reduce the vertical scan. The only what I could think of is to specify a widescreen resolution if the monitor is not widescreen and this may only work if you are connected by DVI cable. Sorry!
Jan 16, 2008 | Sony SDM-X95KB (Black) 19" LCD Monitor
Input Not Supported?
Try changing the resolution in the game. If that doesn't work change the resolution in 'Control Panel' under 'Display'
Jun 28, 2007 | Acer AL1916W 19" LCD Monitor
Input not supported when trying to play a game
the game will need to be set to the same screen resolution as your monitor or the best that suits, beccause of it being widescreen, so look in the graphic or video settings in the game, or change the resolution of your monitor to suit the games highest setting. This is done by right clicking on your desktop, down to properties and then the settings tab in the next window and then move the slider at the screen resolution box.
Apr 25, 2007 | Acer AL1916W 19" LCD Monitor
Acer AL1917W LCD Monitor Logo
1,271 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
