Question about Panasonic SC-HT730 System
Disc tray won't open - Panasonic SC-HT730 System
  • 636 Answers
Try turning the dvd off if this dosn't work than try rotating the tray , there maybe a cd jammed in the unit . If this is the case you will have to remove the cover and manually remove the cd.
Posted on Jan 31, 2009
  • denyter Jul 26, 2011
    Thank you mike!! As i shook the unit around i could hear the dvds moving about, after i read your post and removed the front cover and shook the discs to the front, pulled them out, and restarted the system, hit open/close, it was back to normal. Cant thank you enough. Cheers!
My ibm intellistation z pro: nothing appears on the screen no ibm sign at start up no nothing also if i try to open the disk drive it won't open which seems weird
maybe a disc stuck in the drive? if you pull down outter door of disc drive (unless you can see the front of the disc tray already) there is a tiny hole on front of disc tray, large enough to get a paper clip wire into, that will release the tray and pop it open
Mar 06, 2013 | Computers & Internet
DVD/CD disc opener won't workGetting
Usually the tray has to be opened and inspected and if lucky it can be realigned--if not parts may be hard to find as they usually do not sell individual parts for the mechanism.
Nov 05, 2012 | Televison & Video
Open a paper clip and push one end into little hole next to disc tray. push hard, the tray will open.
Jul 19, 2012 | HP Pavilion a1640n (RC663AA) PC Desktop
Disc drive won't open
CD/DVD drive?
Some have a tiny hole, right under the tray that comes out. Use a paperclip in the hole to manually open the tray.
(Some desktop computer towers have a door in front, that needs to be eased open first, then access to the actual CD/DVD drive unit can be obtained)
Regards,
joecoolvette
Jun 02, 2012 | Dell Computers & Internet
My RCA 5 Disc changer (RP-8065) won't open.
Try to download the service manual to your set from net. It will have all details.
May 22, 2012 | Audio Players & Recorders
My dell 1645 disc drive won't open , I burnt a
There should ba a tiny hole on the front of the tray cover on the drive.
Switch off, get a paper clip or something about the same thickness and insert it carefully in to the hole, push it in until the tray opens.
Jan 08, 2012 | Dell Computers & Internet
Sony rdr-hx720 tray won't open and says traylocked?
The disc tray does not open and you cannot remove the disc after you press Z (open/close). ,Turn off the recorder. Once the clock appears in the front panel display, disconnect the mains lead. (If the recorder does not turn off or if the clock does not appear in the front panel display, disconnect the mains lead anyway.) Connect the mains lead again while pressing down A on the recorder, and release the button when the disc tray opens. Then, keep [/1 on the recorder pressed for about ten seconds until "WELCOME" appears in the front panel display
Oct 08, 2011 | Televison & Video
The disc tray on my iView 4000KR won't open. It has a disc inside that plays fine, but won't eject. This has never happened in the 18 months I've had the player.
Under each disk tray is a very small hole; this hole is for use when you experience the problem like yours.
Get a paper/money clip and straighten the wire; push the wire into this hole and your disk will open.
Regards
HCF
Jun 22, 2011 | Computers & Internet
Disc tray will not open. I've turned on &off several times and it won`t open the tray. tries to but won`t open
This problem is caused by a loose drive belt in the eject mechanism, you need to open the ps2 and replace the drive belt...
Take off the top cover, then take off the cover from the top of the dvd drive mech... then carefully remove the disc tray and you should see the belt near the front. Replace that belt and it should work fine again
On a couple of rare occasions the drive motor has been found to be faulty, but usually replacing the belt will fix it
Jan 25, 2011 | Sony PlayStation 2 (PS2) Console
I cannot open the DVD drawer on my Philips DVDR3480 DVD RECORDER – it just won’t open? The screen display just keeps saying ‘Error’. Any help is appreciated.
I have two of these dvd recorders and both have the exact same problem where the drive won't open. It opens fine when there is a disc in the tray. So I just unscrewed the cover, press the white part which would be over the center of the disc as it's trying to open, it should then open. Then just make sure there is always disc left in the tray.
Nov 26, 2008 | Philips Televison & Video
Panasonic SC-HT730 System Logo
138 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
