Question about Marantz SR-7300 6.1 Channels Receiver
Marantz Receiver SR7300 display gone blank
Hi, my receiver works but the display is dead. i can still control the amp using the OSD. any ideas how i can fix it? is it to do with the fuse? if so how do i change the fuse? any help appreciated.... koolace
  • Anonymous Dec 18, 2007
    same problem on sr7000
4 Suggested Answers
SOURCE:
whitesox
  • 64 Answers
SOURCE: Receiver will not turn on
It is probably shorted out. the fact that you hear a relay click is bad news for you. Take it in and tell them that you cannot get power from the switch through to the main board.
Posted on Jul 26, 2007
  • 133 Answers
SOURCE: marantz 4240 receiver
It could be the op amp, however there are other possibilities like:
- a bad speaker or a speaker cable (try some swapping, see if the left channel is still dead)
- a bad / damaged speaker connector or a bad solder contact on that same connector inside the unit
- a dirty / oxydized connector pin or a bad pin solder contact on any of the connectors inside the unit
- if the main volume pot is actually made of several pots stacked onto a common axis (unlike the standard stereo pots it will have more than six pins), see if any of the pins are poorly soldered and resolder if necessary, if it has a connector also check that for dirty contacts
These are just some of the possibilities so don't take anything for granted.
Hope you can find out what it is.
regards
3rq8 (Triarcuate)
Posted on Aug 03, 2009
  • 417 Answers
SOURCE: hello i have a marantz receiver sr7400 fuse
Unplug the unit. Carefully unscrew the screws for the case. Probably 4 screws, 2 on each side of the unit. Remove the cover. Look for the fuses, and replace with exact same type/specs of the faulty fuse. If the fuse, is on a printed circuit board, be careful dislodging the fuse. Hope this helps.
Posted on Apr 07, 2010
Yamaha htr-5460 Receiver: all settings show up on the TV screen. Can't get them to go away
Page 21 of your manual!!!!
Happy New Year!
Short display Selecting the OSD Mode 1 Turn on the video monitor connected to this unit. 2 Make sure the AMP mode is selected and press ON SCREEN on the remote control repeatedly to change the display mode. The OSD mode changes in the following order: full display, short display, and display off
Dec 31, 2012 | Televison & Video
Tip
Troubleshooting Flat Panel Monitor issues. Screen is blank and power indicator...
Screen is blank and power indicator is off
The monitor is possibly not receiving power. Perform the following steps to fix the problem:
  1. Ensure that the electrical outlet and the monitor are both switched on.
  2. Check that the power cord is firmly plugged into the electrical outlet and the power supply unit.
  3. If the power cord has a removable fuse, replace it.
  4. Try another power cord.
  5. Try another electrical outlet.
  6. Check the power connection at the back of the panel.
Screen is blank and power indicator is steady green
Brightness and Contrast may be too low. Adjust the brightness and contrast using the On-screen display controls (OSD) by selecting the button
Screen is blank and power indicator is steady amber
The monitor is in the Power Management Standby state. The power management feature is invoked when the computer recognizes that you have not used your mouse or keyboard for a user-definable period. Perform the following steps to bring monitor out of the power management state:
  1. Press any key on the keyboard or move the mouse to restore operation.
  2. Check the Power Management software on your computer.
  3. flatpnlmont12.jpgPress the (OK) key to switch between analog and digital mode. If the panel is the wrong mode for the signal being provided, the monitor appears to go into sleep mode.
Screen is blank and power indicator is flashing green
Display mode of the computer is outside the range of the monitor. The display mode the monitor uses is controlled by your computer. Therefore, you should refer to your computer's documentation for details on how to change display modes.
The image size, position and shape may change when the display mode changes. This is normal and the image can be readjusted using the IMAGE SETUP and the monitor controls.
Note: Unlike CRT monitors, which requires a high refresh rate to minimize flicker, TFT technology is inherently flicker-free. If possible, configure your computer for 1600 x 1200 addressability at 60Hz vertical refresh rate.
Use the following table as a guideline and reconfigure your computer to use a supported display mode. The highest resolution (for example, 1600 x 1200) produces the optimal output, but limitations of your monitor may prohibit this setting. Adjust the addressability mode until an image appears.
CHECK SIGNAL CABLE" message is shown and power indicator is steady amber.
The monitor is not receiving a video signal. Perform the following steps to fix the problem:
  1. Check that the signal cable is firmly connected to your computer
  2. Check that no pins are bent in the signal cable connector.
There are noises in the video signal. The IMAGE SETUP function is used to adjust the level of noise in the video signal which causes horizontal lines or areas where the image appears to be unstable and jitters or shimmers. This can be done automatically or manually.
Note: It is not applicable to digital input.
Use the image setup fix the problem:
  1. flatpnlmont6.jpgSelect (Image Setup) menu in the OSD.
  2. Select Manual to adjust CLOCK/PHASE settings.
Image appears to be discolored
The color setting may be incorrect. Perform the following steps to adjust the color settings:
  1. flatpnlmont8.jpgSelect (Image Properties) from the OSD menu.
  2. flatpnlmont9.jpgSelect (Color Properties) to adjust the color mode you find most comfortable or fine tune the colors using the Custom menu.
A few dots are missing, discolored, or inappropriately lighted
A small number missing, discolored, or lighted dots may be present on the screen, which is an intrinsic characteristic of the TFT LCD technology and is not an LCD defect.
Using On-Screen display (OSD) controls
flatpnlmont12.jpgThe settings adjustable with the user controls are viewed through the OSD. Press the (OK) button to display the main OSD menu.
OSD main menu:
Note: The LCD monitor needs time to become thermally stable the first time you turn it on each day. Thus, to achieve more accurate adjustments for parameters, allow the LCD monitor to warm up (be on) for 15 minutes before making any screen adjustments
on Aug 08, 2010 | Televison & Video
Osd volume control won't go away
bad switch i monitor.
fix switch
or new monitor.
its just a switch, it closes and OSD pops. on demand by said switch, OSD is a timing processor in the display that has the OSD code in it , "program"
Mar 25, 2017 | HP Computers & Internet
I am trying to connect my Onkyo DS-A3 ipod dock to my Onkyo TX-SR508 receiver and I cannot get the TV to display the ipod menu. I've connected the red and white (R/L) and yellow video cable to the...
Is OSD set to ON? See below
Set the OSD (onscreen display) mode before you start using the RI Dock. 1. Plug in the AC adapter. 2. Turn on your TV and amp, and select the appropriate inputs on your TV and amp. 3. Insert your iPod into the RI Dock. 4. Select the video output mode depending on the video connection. While pressing the remote controller's [SETUP] button, press the Up [ ] button for the component video connection, press the [ ] button for the composite (default) connection. 5. Use the remote controller's [MODE] button to set the OSD mode. On: Playlists (artists, albums, songs, and so on) are displayed on your TV, and you can navigate and select your music or video while looking at your TV. While this mode is selected, your iPod displays the Onkyo logo. Off: Nothing is displayed on your TV and you navigate and select your contents by using your iPod's display.
Mar 15, 2017 | Onkyo Audio Players & Recorders
Hi. Very odd. My Philips FW-C83/22 has just stopped working. It's completely dead. There's no lights, no noise, nothing. It's like there's no power getting to it at all. I've checked the lead and fuse and...
the power supply has burned out, this is the most common failure in all receiver's, I never recommend repiring, the cost to repair is about $200.00 on average last time got one fixed, you can replace it with a new one if u watch the sales for less and the new receiver will be a far better unit with many improved functions and added features.
Jun 19, 2010 | Philips Audio Players & Recorders
I used to get OSD on the TV with my receiver, but it has gone and I don't know what setting to do to get it back. It is a Pioneer VSX-917V-s/-K. Thanks
did you happen to change to cable connecting the Reciever to the TV to an HDMI?
please note that the OSD will not appear if you have connected using the HDMI output to your TV.
Use component, S-video or composite connections for system setup.
Dec 30, 2009 | Pioneer VSX-917V-K Receiver
I don't know how to increase the volume
OSD Menu Functions
English
All the function settings for the LCD monitor are controlled via the control keys located on
the bottom part of the front panel. To display the OSD main menu, press the “Menu”
keypad button on the control keys2.gif. (Note: The OSD menu display will disappear
automatically after approximately 10 seconds, if no action is taken.)
The LCD2.gif monitor has been adjusted to optimal settings before shipment. Adjustments to
the monitor settings can be made using the OSD menu.
• Press the “Menu” button to display the OSD.
• Press the ▲ or ▼ button to select the function to be adjusted.
• Press the �� button to access the function to be adjusted.
• Press the ▲ or ▼ button to select the sub-function to be adjusted.
• Press the �� or �� buttons to change the current setting of the sub-function.
• To go back to the previous menu, press the button. Changes are saved
automatically.
Source
• To exit the OSD menu press "Menu" again. It automatically will save any changes
that have been made.
If this is helpfull; please indicate so.
JZKlipper/Mike
Nov 11, 2009 | Westinghouse LCM-19v5 Monitor
I don't know how to increase/adjust the volume on my LCM-19v5 computer monitor
OSD Menu Functions
English
keypad button on the control keys. (Note: The OSD menu display will disappear
The LCD monitor has been adjusted to optimal settings before shipment. Adjustments to
automatically.
Source
JZKlipper/Mike
Nov 11, 2009 | Westinghouse Computers & Internet
OSD control from receiver
I had the same problem on my 7200 until I realized that the display comes up on the television screen. I carefully followed the set up required from the manual. I got the Manual online at Marantz.com. I have a cable hook up so I connected the video cable out from the box to the Video in source on the 7200 and monitor out to my Television. I then pressed the Amp button to get the remote to Amp mode. I then pressed the OK button that is in the center of the four direction buttons and the menu displayed itself on the screen . I hope this helps. ercble
Nov 28, 2008 | Marantz SR-7200 Receiver
OSD not working (black screen)
Your 635 will not display the OSD screen through component. You must use either s-video or rca. It won't upconvert the screen menu this route.
I had one up until a week ago. There are two outputs on the back specifically for the OSD screen. I used a separate old 13" TV with s-video to do my setups. Hope this helps.
Sep 04, 2008 | Harman Kardon AVR 635 Receiver
Marantz SR-7300 6.1 Channels Receiver Logo
514 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
