Question about Haier HWD1000
Haier HWD1000 washer/dryer
Hi, I am using Haier HWD1000 washer/dryer. When I am drying clothes, dryer runs for 5 minutes and stops by showing warning code as EC4.
Solved!!!! theres a flaw in the machine, lint builds up in air return area from the back of the machine to the heater, takes about 45 min to fix, take off lid and back pannel, remove weight, remove heater wires and hoses, remove plastic air return area, clean out lint, put back together, the air temp sensor is in the plasic housing in the rear of the plastic housing, the lint blocks air from circulating and triggers warning
Posted on Feb 04, 2012
Did anyone figure out how to solve this problem??
Posted on Apr 03, 2010
  • octowboy Feb 04, 2012
    yes, lint build up in plastic air return vent in rear of machine, take off top and back pannel to access. remove heater then plastic air return area and clean out.
3 Suggested Answers
  • 22 Answers
SOURCE: Dryer Problem
EC4 The temperature of air vent
Within 30 minutes of dry cycle there is 5 minutes in which the temperature is not increasing.
You need to call for repairs. Probably the heating element is faulty.
You can create a custom program without a dry cycle and hang dry your clothing.
Posted on Aug 20, 2010
aborcass
  • 2651 Answers
SOURCE: Haier HWD1000 washer/drye
please repost for i have no knowledge of the haier productline
Posted on Jan 31, 2009
Error 4 ON HAIER WASHING MACHINE.
Error U04 means the door is open.
Put your knee against the door handle and press it against the handle until you hear a click. The machine should start filling within a minute.
This is a problem I had start occurring about a month after I started using the machine. You will soon do this for every load, a minor annoyance on a cheap machine.
Error EC4 refers to the temperature of the air vent.
Ask the technician to
repair it.
Alternatively make a custom cycle with no drying cycle and hang dry the laundry. I usually do this myself as opposed to listening to it groan for 2-3 hours.
Aug 10, 2010 | Haier HWD1000
On my Haier HWD1000, I keep getting error message E11... what does this mean?
Error E11 means either:
The water level can not
reach the reset water level
within 5 minutes
OR
reach the setting water level
within 8 minutes
What this means is check your water supply for sufficient pressure and if for some reason it stops and starts (eg. well drawn water with a small reservoir sometimes.)
You may have to make sure that there are no other water uses going on at the same time.
Jun 21, 2010 | Haier HWD1000
Haier washer/dryer combo not drying clothes
Check things like the Filter / clear fluff...Make sure outlet hose if any is not kinked and passing air..Hope this helps..
Oct 02, 2009 | Haier 14.3 lb. Washer/Dryer Combo
My HWD1000 Haier Washer/Dryer combo error EC4
EC4 is regarding: The temperature of air vent.
The dryer heater is not working properly. Call a repair technician.
Alternatively, create a custom wash cycle with no dry cycle and hang dry the laundry if you are past warranty and do not want to pay to repair it.
Jun 11, 2009 | Haier HWD1000
Hwd1000 washer dryer combo is not moving into the drying cycle
Its time you found out where your filter is to clean out thoroughly
Mar 02, 2009 | Haier HWD1000
Jan 31, 2009 | Haier HWD1000
Hwd1000 drying
More than likely your heating element is dead.You can get one at a hardware store.There not that dificult to replace.I could walk threw it with you on live chat.
Hope this helped. Let me know.Please rate.
For more help go to live chat.
lenwest
Jan 30, 2009 | Haier HWD1000
Dryer Problem
Nov 21, 2008 | Haier HWD1000
How do you DRY with the Haier washer/dryer
Have you tried lengthening the dryer cycle or running it at a higher temp? The usual culprit for wet clothes is not running a dryer long enough or hot enough. (I remember some stand-alone dryers (coin-operated with a fixed drying time per coin) that needed two cycles to dry stuff.
Jul 12, 2008 | Haier 14.3 lb. Washer/Dryer Combo
Haier HWD1000 Logo
846 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
shaun taylor
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
