Question about Vacuums
I just inserted new print cartages and its not being recongized. When i try to print, it still shows empty print cartiages
  • 360 Answers
Try rebooting the printer
Posted on Jan 31, 2009
Hi, I have a relatively new Dyson DC19 and the
Hi David, it's Jack at Dyson.
I'm surprised to hear you've having difficulty emptying the bin on your DC19, as this should be straightforward. It's possible the catches could be a little stiff if they haven't been opened before, but our online Support guide shows what you need to do: http://www.dyson.co.uk/support/dc19t2/dc19t2/how-to-use-your-dyson-vacuum/emptying-the-clear-bin-step-1
If you do need further help after you've given this a try, please call our freephone UK Helpline on 0800 298 0298, or email us at askdysonUK@dyson.co.uk
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Aug 11, 2013 | Dyson Dc19db Multi Floor Cylinder Vacuum...
Keurig model B40 How do I empty the resevoir , I can empty the cold watet tank. We are moving so need to completely empty all water.
The water reservoir lifts out. There are two tabs on the side which lock it in place. You may have to pres on them to remove it. If you are wanting to completely empty the entire machine, I have found an instruction manual and have instructions for purging: Fill reservoir with clean water and replace on machine with lid on it. Raise and lower handle without K cup inserted. Wait for the red light next to "heating goes off.
The blue lights on the control center will begin flashing. Put a cup on the drip tray and press "Brew"
When finished, repeat brew procedure 2 or 3 times and inner tank should be empty.
Hope this helps, if it does, please place a vote for me.
Good luck with your move,
Handie Andie
Mar 28, 2011 | Vacuums
I just emptied the canister and now the vacuum will not start. Is there a restart button?
It sounds like there is some kind of button that the canister pushes down when it is inserted. Make sure the canister is inserted properly.
Mar 14, 2011 | Dirt Devil Featherlite Bagless Vacuum...
My vacuum stops showing "bag full" even after I
This is most probably due to a worn out or clogged Control Valve Assembly.
Detach the hose and see if it runs. If it does, place hand over hole. If it shuts off, CVA is probably the cause. A clogged CVA is generally due to using generic/made-to-fit bags. Genuine bags have "Home Solutions" printed on them.
You can try turning the dial all the way to the large dot, then try to run the vacuum.
If it is the CVA, you'll need to take it to an authorized Aerus Electrolux store and have their service tech repair or replace the part. I recommend a service and clean of the vacuum at the same time. This will extend the life of the vacuum.
Nov 21, 2010 | Electrolux Epic 6500 Vacuum
The bag indicator shows full but the bag is empty
In my bag vac, I have found that when the light shows the bag is full when its not that there is something between where it sucks into the vac to where it empties into the bag...maybe cat hair, dog hair....etc. Try removing the bag and running it, this may allow the air to flow alittle faster and force out the jam. You may also try removing the bottom of the vac, usually just a few screws, and checking to see if you can see the jam. What is happening is this jam is slowing down the air flow and the vac thinks the bag is full....also check the filter where the air leaves the bag area...also look where the bag connects, sometimes trash can hang there.....good luck
Jan 28, 2010 | Hoover Vacuums
My SpotBox was working fine and I had to empty the
have you checked for hair clogs it is over heating? the machine might shut off due to over heating.
Oct 04, 2009 | Bissell 12005 Spot Bot Handheld Vacuum
Kirby g4 vaccum
please clarify what you mean?
Do you mean motor bearings or brush roll bearings?
brush roll bearings can be adjusted to lower the brush closer to the carpet when worn.
to do this remove the front brush assembly, there is usually a sticker below the belt hole showing RED = POSITION 1 HIGHEST (ie a new brush roll)
GREEN = POSITION 2 MIDDLE (brush part worn)
BLACK = POSITION 3 LOWEST (brush fully worn)
At each side of this there are 2 clips unlock these and remove the bottom cover.
Release the belt tension by rotating the belt release at the front.
Before removing the brush roll, at each end of the brush roll there is a grey plastic bearing carrier (Square at the ends) MARK this with a pen or marker just so you know the original position, also look closely for the coloured markings as indicated above or numbering 1,2 or 3.
If RED or "1" is showing you need to remove the brush roll by pulling it out and rotate the endcaps to Green or "2" and re-insert the brush roll, If Green or "2" is showing then rotate the endcaps to Black or "3" and re-insert.
If Black or "3" is showing then the brush roll is worn and cannot be adjusted any more, fit a new brush roll and insert with RED or "1" showing.
To re-attach the belt, move the belt to the middle of the roll and rotate the belt knob at the front ensuring the belt engages with the hook on the inside.
May 09, 2009 | Kirby G4 Bagged Upright Vacuum
Empty bag shows as Full
You have a clog, either in the hose, the dirt inlet by the brush roll or the filters are clogged.
Mar 17, 2008 | Vacuums
Vacuums Logo
18 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
