Question about Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0 Tecumseh Engine
Oil blows out of tube
I have a 8 hp tecumseh snow blower when running at full power it blows crank oil out of a breather tube next to carb any ideas
  • 387 Answers
You either have a head gasket going bad or your piston rings are shot which causes air to go down into the crankcase building up pressure which exits through the breather tube.
Posted on Feb 01, 2009
Tecumseh manuals free
mmm interesting.after comming up to temperature engine experiences excess blow by into crank case .doutfull if it has the wrong size rings for the cylinder as there would be other syptoms as well.think some thing is going on with the reed vave sticking open causing pressure build up into crank case
Jun 29, 2014 | Garden
Ran perfect last yr , gas was stale drained carb bowl and replaced gas it started up right away then cuople mins later it started blowing oil out of the oil over flow tube
Sounds like the Needle valve in the carburetor is stuck 'down' letting gas continually run from gas tank into carb. When the valve can't go up (Close) gas will run past the carburetor and into the crank case I bet your oil is full of gas. Check oil level see if it is overfull
Jan 22, 2014 | Tecumseh Snowblower Snow Blower Starter...
Why is my 8.5 hp troy built snow blower leaking oil while under strain
Make sure the crank case is not over full when not running and make sure the crank case breather is clear.
Dec 15, 2013 | Troy Bilt 5.5hp Self Propelled Mower
5 hp tecumseh no power
you need to remove carb for cleaning... if it has an adjustment on the bottom of carb try turning it SLOWLY in and out... also possibly a screw on the side under a black cap... might try it as well engine model number would help here
Dec 11, 2013 | Tecumseh 5hp Engine Snow King Mtd Blowers...
8 hp tecumsch engine for snow blower oil comes out the side vent tube when running
replace the oil breather filter and make shore you did not over fill the moter with oil
Jan 16, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Oil blow by
A little blow by is normal. Make sure the oil level is correct. If there is excessive blow by, then check the reed valve under the valve cover. It may be damaged or loose.
Jan 31, 2009 | Craftsman 16" High Garden Tractor Snow and...
Tecumseh Snow King HS40 engine only runs on full choke, no power
i did and thanks - just picked up one that does the same thing and i plan to take your advise
Thank you Jerr
Jan 01, 2009 | Karcher 2500 PSI Pressure Washer
Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0 Tecumseh Engine Logo
661 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
