Canon PIXMA iP4200 InkJet Photo Printer
Problem for Canon PIXMA iP4200 InkJet Photo Printer
Ip4200 - printing issues!
By handy2k on Jul 30, 2007
My ip4200 has just been installed on a new computer with Xp and latest drivers from canon. All ink tanks are full though for some reason the printer will pick up paper and just sits there until windows times out. It won't even print a test page. I have tried reinstalling driver. Is there a way to reset the printer's memory? or am i going about this the wrong way?
Cheers
handy
Same Problem
Dec 27, 2007
-   canon pixma ip4200 reset tool / general tool
-   Guest
Best Solution
posted on Jul 30, 2007
Helpful)
Benimur
Rank: Guru  Canon Expert
Rating: 88%, 3786 votes
Perhaps you can try:
remove the USB connection of the printer;
uninstall and remove all drivers of the Canon IP4200;
reboot your PC;
plug in your usb to the PC from the printer;
power on your printer;
let windows auto detect "New Hardware found";
let windows auto install drivers;
test print.
If after plugging in your usb and powering your printer Windows did not auto detect "New Hardware found", it's possible that your printer's usb cable is defective.
If Windows auto detected the Canon IP4200 and auto installed all the necessary drivers but failed in the test print, repeat above steps but instead of auto install, use the original CD driver and not the new drivers (Let me choose which drivers I want".
RESET - User manual is available from the Canon site. There are 2 versions, 1 is a Quick Start Guide in pdf and the other is a User's Manual (On-Screen). Both does not say anything about reset, however you may want to google "fix your own printer" and variations of resetting all sorts of printers are available. Some works, others are ... well you can always give it a try. Or in the On-Screen Manual,you can also try the Troubleshooting/Printing Does Not Start.
Another thing that you can try is installing the printer in another PC using the old CD drivers and see if it works. If it does, then it is a driver issue with the new PC.
If it does not, you're back to reset .
Hope this be of some help to you. Good luck and kind regards.
Was this helpful?
Yes
No
Popular Solutions for Canon PIXMA iP4200 InkJet
Questions and Unsolved Problems for Canon PIXMA iP4200 InkJet
Do you recommend Canon PIXMA iP4200 InkJet Photo Printer?
Answer
Answer
I have a problem with the paper feeder.The printer worked a minute ago when I printed a thick sheet,... (More)
Answer
I've a iP4200 printer. The waste ink absorber is full & needs to be replaced.
Answer
The middle light keeps flashing and does not stop -(No paper jam) - light blink 3 times the stop... (More)
Answer
The printer is not very old...I am having trouble with the paper feed. ..paper crumples a bit in rt... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon PIXMA iP4200 InkJet...:
Top Printer Experts
Rank: Guru Guru
Solutions: 790
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
