Question about Sony Cyber-Shot DSC-P200 Digital Camera
Battery not charging
My battery is not charging. It charges for a few minutes before it goes off.There is no problem with the electric socket though.
    Problem Solver:
  • 13 Answers
Well depending on how long you've had your camera you may need to go out and buy a new battery or go out get a contact pen. This pen allows you to clean the contacts on the battery. You can get it at any Radioshack. If you charge it and still doesn't work then you'll have to buy a new battery or if you're feeling really brave a new camera. Those are my suggestions. Good Luck!
Posted on Jul 30, 2007
SOURCE:
Won't charge
It would help if you mentioned the device you are trying to charge.
If per chance the device has some power left and the device is on, shut the device off and then on again (after waiting a minute or two).
Try a different cable.
Try a different electrical socket.
If you are using a powerboard, try a different powerboard or plug
directly into a wall socket.
Check the cable socket in the device, is it loose?
If it is a device with a removable battery, remove the battery for 10 minutes. Then try again.
If none of that works, it might be the battery is exhausted and needs to be replaced.
Aug 06, 2014 | Nextbook Tablets & eReaders
Battery runs down with can parked
I'm not certain I understand the problem, but it sounds as though the battery is not charging properly. Check it yourself, or have the charging system and battery checked. With the engine running the battery voltage should read about 14 volts. If it is much lower, the charging system is not working. If the battery goes down with the car just sitting, there is something drawing more current than it should. Easy things to check are for a glovebox light, overhead light, trunk light or underhood light that does not turn off. Normal draw with everything off, after sitting a few minutes, should be less than 100 milliamps. I hope this is helpful.
Mar 27, 2014 | 1999 Nissan Primera
My nokia 6500classic is not charging
As you said in the question your mobile is not charging.
*Your charging socket as problem.
*You need to change that socket.
*You can visit to your nearest service center for repair.
*They will take few minutes for this.
You can also charge your mobile by using battery charger.There you should remove battery from the phone and then you should charge the battery.
Thanks for your question.
Jun 20, 2011 | Nokia 6500 Classic Cellular Phone
I have a Canon G5 and am on my third set of rechargeable batteries (I bought an extra Canon rechargeable battery when I purchased the camera and then 2 Canon brand replacement batteries when the first 2...
Thank you for such a detailed description, wishing others would take your lead. To the problem camera designated batteries (other then AA rechargeable) have always been a bit of a sore spot for me because the user is compelled to purchase a specific battery. As much as I prefer the name brand accessories for the camera there come a point where you just gotta venture forth with third party accessories. There is nothing wrong with using an "off" brand in fact what I've found is that is some cases they are a better battery. Again back to the problem. I grasping thoughts on how to word this but, here goes. As much as the manufactures would like you to believe that these batteries do not form a memory they do. Also the battery can trick you into thinking it's fully charged when in fact even though the charge light is saying completed it's only got about 1/3 charge. I've worked with Canon's BP 511 and now the "new" BP 511A for many years The BP511A or equivalent is the better battery. What needs to be done is to drain those batteries down until they stop, let it cool don't take it from the camera to the charger. Time the battery when you put it on the charger, meaning not to the second but what you would "normally" do is plug the battery into the charger and leave it right. Well what's possibly happening is that within ten minute the ready light is coming on, (something stupid going on in the battery) So check the battery stat of charge after say 15 minutes and if it says it ready (drum roll please) remove the battery unplug the charger for a few seconds and place the battery charger back onto the wall outlet and plug the battery back into the charger and look at your watch again. I've had to do this as much as three times until the thing would get the idea it was to take a charge "normally" about 2 hours will bring it back up. There is no device I've found to completely drain one of these batteries so over a period of time in your case one year the batteries begin this fit. I've since replaced the BP511 for the better BP511A's or equivalent. I'm not pointing a finger because myself and staff do the same thing and pull the battery before going to a shoot if it's showing partial discharge and the thing gets put onto charge and we start this cycle all over again. Be careful of the charger as well meaning don't just disconnect the battery and put it back on charge when it's going the cycle thing disconnect the charger from its power source as well because it holds a memory for a few seconds and will just shut off in a few moments if you don't.
Long story but I've been doing this now for 9 years since the dawn of Canon's 30D Cheers
Jan 16, 2011 | Canon PowerShot G5 Digital Camera
Battery not charging and overheating very quickly
actually.. our indian electricity as 240volt and 50 hertz..
and united states electricity as 110volt and 60 hertz.. i think you aware of this...this makes changes i think..if u r not aware try google search abt electricity IN america and india...
1.take ur mobile and go to LG showroom nearby and ask about this problem..
2.and we can have better converter for this type of mobiles...
"try asking in famous electrical and electronics shop.."
if the battery is suddenly discharging thats seems to be duplicate battery .. try buying original battery that cost more....
"DONT FORGET TO RATE THE SOLUTION "..
Apr 15, 2010 | LG KC910 Renoir Cell Phone
Camera starts to boot but suddenly shuts off.
Assuming the battery is fresh out of the charger: a "well used" battery that can no longer accept a full charge (at the end of its useful life) can have the results you describe (it's not unlike like a flashlight with dead batteries - when the light goes out, turn off the flashlight - wait a few minutes and turn it on again - the light shines [though not very brightly] and quickly goes out again). After many charge / discharge cycles, the battery no longer has the ability to hold a charge. This is a gradual process that happens over the life of the battery. An indication of this is that you'll notice that you can take many fewer shots now when compared to when the battery was new.
There is a possibility that a new, fully charged battery will allow the camera to work again. However, if the existing battery is not very old or or has relatively few charge / discharge cycles, it is probably an issue with the camera. A local camera store may be able to help you determine if it is a battery or camera issue - otherwise, a quick google search reveals that a new battery for this camera is under $15.
I hope this helps - and good luck!
Nov 13, 2009 | Kodak EasyShare C653 Digital Camera
Toshiba Satellite a205 Battery Will Not Charge
You did what all should not have been done. your battery works as a buffer between high surge of electricity which comes through electrical supply i.e. it protects your smps from burning up. From your current position it seems your smps fuse has blown. If they have given one or else your smps itself has gone. I'll tell you for your future usage of battery. Whenever you get any electronic equipment with chargable battery you should never switch it on unless and untill you have charged it for continuous 24 hours. Never try to run such equipment directly through dc or ac power. Hope your fuse has gone its not costly.
Jun 19, 2009 | Toshiba Satellite A205-S4607 Notebook PC
Sony Cyber-Shot DSC-P200 Digital Camera Logo
69 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
