Question about Lexmark X1240 All-In-One InkJet Printer
I have installed a new X1240 with drivers and everything is working fine but no ink comes out of 17 and 27 new cartridges when printing. I have tried with both a Toshiba OS Vista and Compaq OS XP. The test will print in color but no ink when printing with either computer.
  • 1,800 Answers
Clean the cartridges conector and ur printer ones.
then print test page.
Posted on Jan 31, 2009
I have a lexmark x1240 and just installed a new cartridge. I keep getting an error message that says " print cartridge missing" install print cartridge even though both cartridges are in the printer.
If you insert the old cartridge, does it recognize it? If it does, then it's a problem with the new cartridge. Try to check if you already have taken out the protective tapes out of the cartridge.
If it still doesn't recognize the old cartridge, then it's a problem with the printer.
Nov 29, 2012 | Lexmark X1240 All-In-One InkJet Printer
Installed new cartridge still won't print
It could be that your printhead needs cleaning. Open the Lexmark Solution Center application on your computer. Go to the Maintenance tab and select Clean to fix horizontal streaks. Your printer will then print a page, forcing ink through the cartridge nozzles and clean them. Then try to print a document again to verify that the print quality has improved.
Nov 16, 2011 | Lexmark X1240 All-In-One InkJet Printer
Color cartridge do not want to print
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
May 28, 2009 | Lexmark X1240 All-In-One InkJet Printer
Lexmark X1240 all in one
was it a genuine lexmark ink? if not then that is the main reason why it not working
Feb 10, 2009 | Lexmark X1240 All-In-One InkJet Printer
Printer wont print, but it is going through the motions.
If ink cartridges are new, perform print head or maintenance cleaning at least 3x consecutively.
Nov 24, 2008 | Lexmark X1240 All-In-One InkJet Printer
Missing yellow when printing/even after many cleaning attempts!
new ink cartridge is much advisable. but for expriment basis i will tell you to place the ink cartridge in the bowl of water only the head from where the ink comes out in the water for nearly 24 hours.then remove the cartridge and clean it completely.then check. hope this helps............
thanks.
Nov 08, 2008 | HP Photosmart 4180 All-in-One Printer
Lexmark x1240 will not print
did you tried to set the properties to mono ?
Apr 12, 2008 | Lexmark X1240 All-In-One InkJet Printer
All in one printer does not scan or copy
If the Ink Status is showing a ? symbol after you have replaced the tanks, you just need to tell the printer that you replaced tanks ,
To do that , open your lexmark solution centre from the Lexmark start menu group.
Click Maintenence
Click Install New Print Cartridge
Jan 18, 2008 | Lexmark X1240 All-In-One InkJet Printer
Printer HELL !! need assistance
illustrate on how to replace the ink cartridge on printer
Sep 15, 2007 | Office Equipment & Supplies
Lexmark X1240 All-In-One InkJet Printer Logo
66 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
