Question about KDS Visual Sensations 190i 19" CRT Monitor
Monitor making humming noise
My monitor has recently started making a high pitched sound ...starts out low and then gets louder & louder and fades away.Lasts about a minute or so. i can be on the computer surfing or it can make the noise when I'm not doing anything.Sounds like speakers getting too close together.I have my own speakers sitting close to the monitor.Could this be the cause?I've had the same speakers for several months and its just now doing this.I haven't had this monitor very long.It was given to me a few months back but I really like it.If its an easy fix I might be able to fix it & keep it.
  • Patty Green
    Patty Green Jan 31, 2009
    I moved my speakers away & will wait for it to go out.I still have my spare so I'll be just fine.Good of you to give me all the info.I appreciate it.
  • 382 Answers
First try moving speakers away from monitor a bit. Some speakers magnets actually reduce the life span off monitor. I hope I am wrong but usually a high pitch whine is the High voltage Transformer. Costs more than the monitor. All you can do is continue use till it goes. Speakers usually deteriorate the tube itself. HVT are just one of those parts that go due to use. Hope it gives you more enjoyment before it goes. Good luck and try to have a good day.
Posted on Jan 31, 2009
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ... > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from
High pitched sound coming from my Samsung DLP TV - Open Forum ... > Forums > Social > Open Forum
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
Low pitched humming
When it makes the noise and you able to do this try turning to the right and to the left. If the noise changes or goes away than your on the right track with a bad wheel bearing.
Dec 27, 2012 | 1998 Pontiac Grand Prix
SyncMaster 793DF 17" CRT Monitor: monitor makes high pitch noise...
With a piece of wood or plastic hit the flyback with the monitor turned on. If you note some change in the noise. Replace the flyback.
Normally, it is the cause of the noise.
Warning: High Voltage!! Do at your own risk!!!!!!
Best regards,
May 16, 2010 | Samsung SyncMaster 793DF 17" CRT Monitor
My Icebox computer will not start up properly. When I turn the power on, it simply hums like an old television with no signal.
Hello,if your computer is old and the noise is low frequency but very disturbing and sometimes gets louder and then lows then is your power supply and you must change it.If the noise is more high pitch and it doesn't change frequency then should be the graphic card.If its like scratching noise is the hard drive.You must figure out exactly where the noise is coming from before replace anything
Feb 03, 2010 | IceBox (HL1214) PC Desktop
Monitor Goes black, or flickers on and off
The high pitch sound is coming from the inverter. It is faulty and needs to be repaired or replaced. The inverter supplies high voltage to the CCFL lamp, this lamp gives the backlight to the LCD so you can see the LCD images.
Check out LCD parts for parts, service and DIY info. use this link :-
Aug 29, 2009 | ViewSonic OptiQuest Monitor
1997 Civic LX A constant mid-high pitched humming noise?
Have you had the water pump replaced yet? Could possibly be the water pump making noise because it's about to go.
Nov 08, 2008 | 1995 Honda Civic
My Moniter won't work!
That high pitched sound in one way is a very good thing. It pretty much points out the source of the problem itself. That is more than likely either a blown capacitor or transformer on the power source inside the monitor. I would rule out the power inverter for the LCD backlight because the power light will not turn on either. I have found that Samsung is very good with their repairs, and if it is a somewhat recent model they should be able to get it drop ship repaired with little expense. That can be an inconvenience, and if you do decide to replace the monitor altogether, please be eco-conscious and have the old screen either donated to a goodwill organization where scavengers like me will buy it for raw parts, or to an electronics recycling center. E-Waste is becoming a very large problem and LCDs and flat screens are a hefty piece of it.
Jul 08, 2008 | Samsung 226BW Monitor
KDS Visual Sensations 190i 19" CRT Monitor Logo
215 people viewed this question
Top KDS Computers & Internet Experts
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
