The paper will not go through the printer... it seems as if the paper can't get on the track and eventually gets jammed.
  • 27 Answers
First, make sure you are using the correct type of paper for the printer. Some printers, for instance, can not handle glossy paper. Next, lift the front & back covers of your printer and look at the rollers; they look like long metal rods with black rubber wheels spaced across them. Check to see they are clean and no build-up has occurred. I cannot tell you how many roller assemblies you have in your printer, but if you have checked them all and the problem still occurs, it could be due to an internal obstruction or failing motor/spool assembly.
Posted on Jan 31, 2009
Paper keeps shifting during loading and eventually gets jammed every time
Seems like the rollers are either dirty, or worn out. Probably the latter.
“Paper jams” on page 68
“Paper or specialty media misfeeds” on page 68
“Printer does not feed paper, envelopes, or specialty media” on page 69
“Banner paper jams” on page 69
Paper jams
Is the jam in the paper
support?
1 Press to turn off the printer.
2 Firmly grasp the paper, and gently pull it out.
3 Press to turn the printer back on.
Is the jam in the printer? To automatically eject the paper:
2 Press again to turn the printer back on.
The paper automatically ejects from the printer.
To manually remove the paper:
If paper or specialty media misfeeds or skews, or if multiple sheets feed or stick together, try the following solutions.
Check paper
condition
Use only new, unwrinkled paper.
Check paper loading Load a smaller amount of paper into the printer.
Load paper with the print side facing you. (If you are not sure which side is the printable
side, see the instructions that came with the paper.)
See “Loading various paper types” on page 21 for information about:
Maximum loading amounts per paper type
Specific loading instructions for supported paper and specialty media
Troubleshooting
68
Remove each page as
it is printed
Remove each page as it exits, and let it dry completely before stacking.
Adjust the paper
guides
Adjust the paper guides:
When using media less than 8.5 inches wide
To rest against the edges of the paper or media, making sure it does not buckle
Jul 22, 2010 | Lexmark X2500 All-In-One Printer
Paper jam
What about you open the back of your printer & tighten it
Apr 17, 2010 | Canon imageCLASS MF6550 Monochrome Laser...
The paper jams up when the printer pulls it into print
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed throught the printer. The reason for this, in some cases I have been able to clear the paper track of debris that was deposited there over time. Worth a try. I have fixed a number of printers this way saving costly repairs. Bud
Jan 21, 2009 | Lexmark X4530 InkJet Printer
I have a paper jam I cannot fix
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 08, 2009 | HP Photosmart C7280 Laser Printer
Faulty paper pick-up & tracks down the length of the paper
This problem is caused by a slippery paper pick-up roller. Because the paper slips, it "arrives" too late in the printer mechanism resulting in image shift or paper jam.
You can see this gray rubber roller by removing the paper tray and the imaging unit and turn the printer on his back. Sometimes it helps to "clean" the roller with some sandpaper (take care to remove all small particles!) and/or clean it with some liquid (white spirit, thinner etc.)
Adri Hankel
Aug 07, 2008 | Samsung CLP 300 Laser Printer
Ip4300
Took a can of Blow Off (dust remover) and blew through paper track, and used a paper towel soaked in Isotope Alcohol and rubbed the tracking rails..
Everything seems to work fine for now except the canister paper holding is not feeding properly and the paper is getting jammed when you try to use it. This is not that important as long as paper can be fed the normal way and it doesn't jam..
Jul 12, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Landscape copies get stuck
The roller may have something stuck in that area, something even as small as a peice of paper can continue to make it jam. if not, you may have to call the company to get a repair guy in... umm... or repairGirl?
May 17, 2008 | Toshiba 2060 Copier
HP PSC 1610 All-in-One paper jam
ur printer paper feeder gears r jammed or misaligned. kindly get ur printer serviced from a good technician.dont worry its a normal problem.wish u success
Mar 11, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
44 people viewed this question
k24674
jasbo
jasbo
