Question about Toshiba 32A33 32" TV
Universal remote works for basics but won't change input
I need to set up a Wii in my son's room; it is an old Toshiba tv with av inputs on front panel.  The original remote is lost and I'm using an RCA universal rcr311st that works fine for television functions but I cannot get it to switch the input to "aux" so he can use the Wii.  I don't see any manual way to do this on the television itself. Is there any way to do this? Thanks Rich K
  • fast lane Feb 08, 2009
    need to grt tv off cable mode back to tv for convert box to replace ant on tv
    Scholar:
    New Friend:
  • 70 Answers
Rich,
good day , what button can you see infront of your TV screen?
Not familiar with this model but if you'll manage to locate a button marked as "TV/AV" or "AV" press this button until it the display switch to A/V mode (audio/video). Or if this is a really old model, from Tuner mode or channel model. set the channel station to 1 then press the " - channel " button and see if it will change from tuner mode to A/V mode
cheers,
mark
Posted on Jan 31, 2009
Need remote codes to program remote for toshia tv and a philips tv
Posted on Feb 08, 2009
How to connect wii?
On the TV or Remote there is a button called AV/input/source, press this and select the input the wii is connected to.
Sep 06, 2014 | Toshiba 27A34 27" TV
How do I fix Magnavox HDTV stuck in av after use of Wii?
If the Wii is not used, and if some other source is used, does the set still stay stuck??? If it stays stuck with the Wii connected, but not with some other device, then the fault is with the Wii and not the TV. Maybe there is something in the characteristics with the Wii output that is the cause...
If that input stays stuck with any source, when I used to do TV service there were a number of things that caused this. I had to sometimes change the input control IC (input matrix IC), and or, one or a few of the components associated with this IC. These components were identified by following the digital control signal paths with a digital scope and volt meter and using the schematic diagram as reference. Sometimes I found the main uPC (micro-controller) in the TV set was the cause because it was not properly sending the command for the input change.
The most basic thing you can check is if the remote is sending the proper remote command signal to the set. If you do not have a remote control signal analyzer you can try another remote such a universal remote control to compare.
May 01, 2014 | Sanyo DS31590 31" TV
I have a really old sanyo tv. The roommate brought it with a universal remote, which will not work with the TV, and I also bought another universal remote that will not work either. I just want to get to...
Sanyo sets, especially the old ones are like this, if no button on set the only thing you might try is run one channel at a time below channel 2 to see if one of the upper channels is the video input, other than that you are done.
Dec 14, 2012 | Televison & Video
Can't find input setting on old proscan tv. tried channels 90/91/92. only white fuzz
You are trying to connect the TV by AV setup. You have to select the input selection to TV to AV. If the TV have a Menu button on its front panel, you can enter into its menu options, surf through, and select the input selection window. Here you can select input to AV.
If there is no 'Menu' button on the front panel of the TV, you can'd do this selction. You must have its remote control to select this option.
Jun 01, 2012 | Proscan PS27125 27" TV
Have new 55ux600u toshiba. Hooked up a one year old wii and get no color
The 55ux600u toshiba hdtv has a setting that needs to be changed with the wii in order to get color.
1. Click 'Menu' on the TV remote 2. Arrow over to 'Preferences' 3. Arrow down to 'AV Connection' 4. Click 'OK' 5. Arrow down to 'AV Input' 6. Change setting from 'ColorStream HD' to 'Video' by clicking the right arrow. 7. Hit the'Exit' button on the TV remote.
This will give you color for your Wii. You will have to change this setting back in order to view DVDs in color. :-)
Jan 01, 2011 | Video Game Consoles & Games
I changed the cabling between my Phillips tv and set-top box a few times and I lost the signal. The signal is from UPC, it's piped tv. They said to locate the av channel on the tv and this would restore...
The only way to change the source for the 28PW8608/05 is to use the remote. On the original remote, just below and to the left of the power button is the button you need. The image on it is a square with an arrow going into the square from one side. The inputs should go TV, EXT1, EXT2, (EXT3 on some models), Front). Depending on the set top box, you may need to enter the setup menu and set the digital source for the input (Press together Fast Rewind and Stop > Setup > Digital Source) or the decorder (next option in Setup).
If you do not have the original remote, you will need universal remote with an input or source button and to find the code that matches the function. Some codes may only operate the basic functions. (The lowest end universal remotes often lack this feature.) A universal remote that can be programmed via a USB connection with a computer will be the fastest to set up.
I hope this helps.
Dec 29, 2010 | Philips 32PW6506 32" TV
Do i need a remote to aquire the av input on the tv
I believe on the Toshiba 14AF44 that you can change inputs by using the channel button on the front of the TV, as well. Either channel down to the lowest channel and then channel down again to start going through the available inputs, or channel up to the highest channel and then channel up again to start going through the available inputs.
Hope this helps!
Feb 18, 2010 | Toshiba 14AF44 14" TV
Sylvania 6420FF TV - SELECTING AUDIO/VIDEO INPUT w/o remote
During a recent move the remote was lost. I have the 6420FF in my son's room and trying to set up dvd and wi console set up, but cannot adjust tv via menu button on tv. Is there any way to set-up game system and/or dvd without remote?
Jun 13, 2009 | Sylvania 6420FB 20" TV
Can hook up my wii to this tv
The AV Multi Out plug that is included with the Wii will allow you to connect the console to most televisions or video cassette recorders (VCR). First, look at the back of your television AND your VCR and see if you have colored holes label "Input". Though most TVs have them, almost all VCRs do as well.
  • Audio/Video (AV) inputs are located on the front or back of the TV or VCR.
  • They are smooth silver posts with the inside showing a color, usually red, white and yellow.
  • Look for inputs marked Audio and Video IN.
  • The image on the left features stereo audio inputs. Some televisions have only one audio input. Click here for help setting up a mono audio connection.
  • Do NOT connect your system to anything marked OUT.
Where do you have these inputs?
Additional Options:
Connecting to a Television
  1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console. setuptvav.gif
  2. Insert the RCA plugs on the Wii AV Cable into the input connectors on the TV. Plug the colored connectors into the following inputs:
    Yellow = Video Input
    White = Audio Input Left (or Mono)
    Red = Audio Input Right
    Interested in playing your games in Dolby Pro Logic II (simulated surround sound)? Click here setup information.
  3. Once the cables are inserted and the Wii is powered on, you must find the Input Select for your TV to view the game (it is likely not going to be seen on Channel 3 or 4). Typically this is found by pressing the TV/Video button on the Television's front panel or remote control. If you have more than one input channel, keep pressing TV/Video until you see the display from the Wii.
    If you do not have a TV/Video button, then the input could be labeled something different. Some other common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, or a channel such as 00 or 99.
    Still can't find it? We have compiled a list of known input selects for many popular brands. Click here to see our list.
    Go to Next Step (Set Up of the Wii Remote) >
Connecting to a VCR, DVD-R, Cable Box, etc.
    In order to connect a video game system through a device such as a VCR, DVR, cable or satelite box, it must have Video and Audio "inputs." While most VCRs and VCR/DVD combos have these inputs, other devices typically have "Outputs" which will not work for playing your Wii console. Please verify the device you are attempting to use has these holes.
    While many cable/satelite boxes and DVRs may have "inputs," accessing them can be difficult. Please consult the instruction manual for the device you are connecting to, for more information.
  1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console. setupvcrav.gif
  2. Insert the RCA plugs on the Wii AV Cable into the input connectors on the VCR. Make sure you are plugging the connectors into the holes labeled"Input" or "In". Holes labeled"Output" or "Out" will not work. Plug the colored connectors into the following inputs:
  3. Once the cables are inserted and the Wii is powered on, put your TV on the channel you use to watch movies (usually channel 3 or 4). Put in a video tape and play the movie. When you see the movie playing, press stop (do not power off the VCR!) and proceed to the next step.
  4. You will now need to find the Input Select for your VCR. This is usually a button on the original remote control that is labeled Input Select, AUX, Input, EXT, Line In, or a high or low channel. For more information on locating your input select, click here.
Nov 26, 2008 | Video Game Consoles & Games
How do I switch to Av manually?
You may have to get an exact replacement to get ALL the set's functions to operate. Universal remotes don't let you access all the functions of some TV's If you can use the buttons on the front of the set to bring up the menu, you may be able to scroll through it and find where you can select the type of input you want. You would select AV. Stargazer
Aug 19, 2007 | Bush 2871NTX 28" TV
Toshiba 32A33 32" TV Logo
2,824 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
