Dryer will start but wont stay running when you release start button. If you hold start button it will run but will not heat. after about 10 minutes it will run fine.Dryer will start but wont stay running when you release start button. If you hold start button it will run but will not heat. after about 10 minutes it will run fine.
You can't post conmments that contain an email address.
Aha!
You are going to make me guess!
I am guessing you have to hold the start button down.
So.
Try a new start button first.
If that does not fix it, replace the timer/control unit.
God bless your efforts.
Usually
when an electric dryer overheats it's because of a defective cycling
thermostat or a clogged vent system. Clean any lint from the internal
and external ductwork, and/or replace the cycling thermostat
Check your circuit breaker. It may not be your dryer at all. 220 dryers run on two separate circuits one to run the motor the other to run heating element.
i would check the door switch. it may be worn just enough that the vibration of the dryer opens the circuit for just a moment. then check for other loose connections. the fact that you can restart immediately usually indicates a momentary break in the circuit. a temperature switch usually takes a short time to reset. while it's still running, try rattling various switches or smack the door to see if it shuts off. (just a couple of simple ideas to start with).
good luck....jay
If it heats w/ the timer in off position whenever plugged in the the element is shorting to ground, its most likely due to either a broken coil or a cracked insulator. If heating w/ timer set for drying but motor is not running, the heat circuit thru the centrifugal/start switch on the motor is stuck closed.
