Question about Microsoft Windows XP Home Edition
Need to setup windows xp faxing
The windows connectio wizards demands i put the windows cd in, but i lost that decades ago. So when I go into cotrol panel, add windows components, and select fax it tells me to put in the winows disk, i don't have one. is there a driver that I can install?
  • Microsoft Master
  • 1,183 Answers
Since you donot have the windows xp cd , you would not be able to enable the fax feature in windows xp home edition.
Alternatively you can download a fax program from the interent and configure the same to send faxes.
One such porgram is called snappy fax, can be downloaded from the link below
http://www.snappysoftware.com/
Thanks
Proton
Posted on Jan 31, 2009
Tip
Windows XP fax
If you need your<b> PC</b> to be able to fax, you must install the <b>Windows XP fax</b>. Add / <b>Remove Programs</b>, click Add / Remove <b>Windows Components</b>. In the <b>Windows Components Wizard</b>, select the check box next to <b>Fax Services</b> and make sure you have the installation CD handy.
on Feb 24, 2011 | Computers & Internet
Tip
How to Configure Windows XP to send and receive Fax?
If you are using windows XP, you can use sending and receiving option for fax service built into windows XP. You can enjoy free facilities of fax from your computer, because buying a dedicated fax machine for home or small office may not be a feasible option. Using windows XP based fax services; you can read, save, forward, delete the fax messages. By default fax service is not installed in your windows XP, but if you have windows XP CD, you can install fax feature using Add or Remove Program option.
Follow the gives steps to install fax components:
  • To install this feature, you will need to be logged into your computer with administrative rights.
  • Make sure, you have installed modem driver on your computer before running fax components setup.
  • Now click on Start button and go to System Control Panel then double click on Add or Remove Program.
  • Select the Fax services check box under Add or Remove Windows components.
  • Now click Next to finish the fax installation wizard and close it.
After the fax components installed, now configure the fax setting before using it.
  • First click on Start button, go to All Programs> Accessories> Communications then click on Fax Console.
  • Now in fax configuration wizard, type the fax cover page information then click on Next.
  • Select the suitable modem for fax and also enable others send and receive options.
  • Now type the TSID (Transmitting Subscriber Identification) and click Next then type here CSID (Called Subscriber Identification) and again Next.
  • At the end select the printer to be automatically printing the fax and click to finish.
on Feb 13, 2010 | Computers & Internet
FAX
If you have fax on hp officejet 5610.
You can recive fax .
start>steeting>printers and Fax> Setup Fax.You need windows XP CD for this Fax installation.IF manufacturer given software u r not need to install again.Just review the fax configuration by rigt click on fax icon then go to properties.
IF it helps
pls RATE ME
Jun 25, 2009 | HP Officejet 5610 All-In-One InkJet...
Hp4300 series disc won't work with my new hp window vista computer my printer is a 4315v
Please perform the steps given below and check if yuo are able to fax
1. Open a MS Word Document.
2. Click File -> Send to -> Recipient using a fax modem.
3. Follow the instructions given in the fax wizard. Ensure that you select the HP all-in-one as the fax program.
Now check whether you are able to send the fax.
OR
Try setting up the Fax once again
=== Fax Setup wizard ===
- Double-click on the HP Solution Center to open it.
- Go to Settings --> Fax Settings & Setup --> Fax Setup Wizard.
Complete the fax setup wizard and then, try to fax
Vishwanath V U
May 19, 2009 | HP Officejet 4315v All-In-One InkJet...
Ethernet cotroller drivers for Win XP Prof
Here is a link to an excellent tutorial that will guide you through the process of updating drivers in XP.
It has instructions for opening the Device Manager and finding out what hardware is installed in your system. Then you need to go online from another computer, download the appropriate drivers and burn them to cd, load this cd in your computer, then update the drivers on your system from the cd. You can drag the setup files to your desktop and install them from there.
I hope this information allows you to resolve this issue. If I've managed to answer your question or solve a problem, please take just a moment and rate this post....thanks!
Mar 31, 2009 | Microsoft Windows XP Professional With...
How can i download the CD software.
Here is the download page from Lexmark (click here).
Unplug printer USB from computer.
Chose OS version and download the driver.
After downloading run installer file, this will start printer setup wizard.
Connect printer back when required from setup wizard.
Don't forget to rate the solution.
Thanks
Aug 28, 2008 | Lexmark X4270 All-In-One InkJet Printer
Networking window xp to win98
Just run the Network Setup Wizard and set it as you want when it finish run this wizard using your Windows XP CD on Win98 make the setup same. But remember please provide detailed information for a Right solution.
May 12, 2008 | Microsoft Windows XP Professional
Microsoft Windows XP Home Edition Logo
74 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
