Question about Broan-NuTone VX475 Bagged Central System Vacuum
Power Unit VX475 Stops Working
I have a Nutone VX475 unit that continues to stop working after a couple of minutes. This was repaired approx a year ago but the unit continues to stop working for a period of time then after 5 min it starts working again. Then it stops after a couple min and the cycle continues. I'm wondering if my unit should have been replaced with another power unit.
The problem is NOT the motor. Its that the motor is not being cooled. You have to replace the whole top. Call Nutone and its only a $30 part
Posted on Feb 28, 2009
  • 38 Answers
The problem is definetly the motor. make sure the filter is not covered in the hair, if not you need a new motor. i fixed plenty of them.
Posted on Feb 08, 2009
My Broan-NuTone central vac shuts off after I am vacuuming for a couple of minutes. I turn it off for about 10 minutes and start vacuuming again and it keeps shutting off. What is wrong with it? I...
Some of these units have had trouble with the motors and this is what causes them to shut off. NuTone has been pretty good about replacing them under warranty. 1-888-336-6151.
Aug 17, 2011 | Broan-NuTone VX475 Bagged Central System...
My VX550CC also shuts down after about 15-20 minutes. My problem is that I can't find my sales receipt. Nutone told me after contacting them several times that they will not honor their warranty unless I...
Some People Hu...........Make sure that all filters are clean if need be renew..Sounds like overheating fault resulting in Thermal cut out operating....Good luck
Feb 19, 2011 | Broan-NuTone VX475 Bagged Central System...
Nutone central vac shuts down after a few minutes of use
this is a very common problem.
If the unit is less than 5 years old and you have your bill of sale it will be covered by warranty. Although one of my customers said that there is a recall on the motor in this unit. That is totally unverified. However, if it is still under warranty, contacting broan/nutone will give you the closest warranty depot, or they may just deal with you directly.
I do recommend that both the motor and the PC board inside be changed.
Good luck,
Mark
Nov 07, 2010 | Broan-NuTone VX475 Bagged Central System...
My unit is a little over 2 years old, and I cannot leave the power button in the on position on the main unti any more. The power was controlled by the vacuum power nozzle whether I was using the carpet...
Why can't you leave the power switch "on" ?
Does it stay running, ot does it not run at all?
if it stays on, the power probably isnt controlled by the power nozzle, but may be controlled by a door switch on the flapper doors where you insert the hose... Make sure all the "flapper doors" are completely shut, there's probably one stuck a little open I'm guessing...
Oct 22, 2010 | Broan-NuTone VX475 Bagged Central System...
My central vaccum just stop working last night. It does not turn on at all.
I've gone through 3 vx475 vac in the past 7 yrs. Last one was sent to me in Apr 2010. Just yesterday, once again, my vac just quit. Green power light is on but no other sign of anything. Had a burning smell when vac quit, like motor just fried. Called Nutone again and they can't imagine whats going on but will send out another vac free and was told to throw out old one. They said dust may get into the motor and cause it to quit. These vacs aren't cheap, can't imagine that its so simple to just call up and have a brand new one sent to me. I've asked if they are rebuilt units and was told no. So my advise to you, if you haven't already, is to simply call them up w/model and serial # and they shouldn't give you any prob. good luck.
Sep 03, 2010 | Broan-NuTone VX475 Bagged Central System...
Vaccum runs for 2 or 3 minutes then shuts off. Can not restart it for several hours. We have tried EVERYTHING with no luck. I see there is the same problem with the VX550...is there a recall on this one...
The VX series NuTone's have had some problems but NuTone is taking care of them as long as it is under warranty. You can contact NuTone at 1-888-336-6151 or whoever you purchased the unit from and you will most likely get a new unit. There are no parts available for the VX units so whenever there is a problem NuTone has been sending new units out.
Oct 06, 2009 | Broan-NuTone VX475 Bagged Central System...
Problems with 353 nutone
if its an older unit or it got heavy use it could be the motor they tend to sputter as there going out, as it rotates the electricity hits a burnt spot inside the motor and shuts itself off can you turn it on manually? they usually put a swithc on the tank itself if the problem doesnt occur when you switch it then it could be the hose itself normally they control the off/on use a meter to check the continuity beteen the two copper plates that are on the end of the hose ( the wall end )
Sep 16, 2008 | Broan-NuTone VX475 Bagged Central System...
Nutone central vac vx550
It's a known problem. I bought my vx550 last year in July and it stopped working this year in May. On for 5 minutes, shut down, can't run for a few hours, runs for another five minutes, etc. I called the Nutone customer service department and they exchanged the unit for a new one, cross shipped, via UPS. Mine was still under warranty though. It has to do with some defective thermostat or controller in the electronics of the vacuum.
Good luck
Sep 11, 2008 | Broan-NuTone VX475 Bagged Central System...
Checked and found that motor is definitely overheating for unknown reason. Since power unit is still under warranty, solution was to contact local service company for NuTone power unit and have them come out and fix/replace it free of charge.
Jun 27, 2008 | Broan-NuTone VX475 Bagged Central System...
Broan-NuTone  VX475 Bagged Central System Vacuum Logo
399 people viewed this question
Top Broan-NuTone Vacuums Experts
Steve
Gerry Harvey
Gerry Harvey
JoeVacs
Are you a Broan-NuTone Vacuum Expert? Answer questions, earn points and help others
