Question about Sherwood RX-4105 Receiver
Sherwood RX 4105 no input for a turn table
There is no dedicated input for my turntable, I used the Aux and other inputs, but the volume is very limited.
Is there a way to remedy?
  • 336 Answers
Check for a line level switch on the turn table, it may be under the turn table itself lift the rubber mat and spin the table by hand, it may not have one or it could be on the back.
You can buy a phono amp that will boost the phono signal. Check at Radio Shack or google it.
Posted on Jan 31, 2009
I have a Sherwood RX-4109 receiver. The right side channel has low volume and cracks, can it be fixed?
show me a picture so I can tell if it is even worth fixing. you may be better off getting another one.
Aug 13, 2014 | Sherwood RX-4105 Receiver
Does the sherwood rx 4105 receiver have analog or digital inputs
Unfortunately the RX-4105 is a stereo only receiver with only analog L/R inputs. You will have to find a stereo output & go in through one of the stereo inputs.
Feb 12, 2013 | Sherwood RX-4105 Receiver
How can i put my technic turntables to my amp and connect amp to my pc
Hi, connect to amp using phono inputs on rear panel. If no phono dedicated inputs you can connect to aux or cd inputs however the volume output from your amp will be low. A preamp will fix that. Connect from the record out plugs on the rear panel panel to the mic input on your computer. You will need a rca to 3.5mm jack cable. Cheers john. Styluscity
Aug 06, 2012 | Technics Audio Players & Recorders
I have a new Yamaha RX-V365 receiver and an older technics turntable, regardless of input setup I cannot get any volume from the turntable, yet all other inputs like CD, Tuner are fine....amp issues in...
Some turn tables do not have a built in amp, especially the older ones, the sound goes from the needle to the output. If the amp your are using does not have a designated phono, turn table, input it may not have the turn table pre-amp built in. Some turn tables have to be grounded to the amp to work properly.
Aug 30, 2009 | Teac DC-D2800 Shelf System
Can I hook the reciever to mm bose subwoofer and 5
if bose unit has built in amplifier .Then your sherwood would have to have a variable RCA output jacks in order to work with sub.Then bose audio input RCA cable would connect there.If bose unit does not have built in amp .Then you would connect sherwood left/right speaker outputs into bose left/right inputs .Then other bose speakers will connect to bose unit
Jul 30, 2009 | Sherwood RX-4105 Receiver
Technics turntable plays but no sound with Sherwood receiver
The problem is the fact that the new receiver has no phono input. The phono input has an extra stage of amplification built in. Your receiver is working fine. You need to purchase a phono pre-amp. These run around $20. Connect the turntable to the preamp and the presmp output to any line level input on your new receiver and everything will work as expected.
Dan
Apr 12, 2009 | Sherwood RX-4103 Receiver
My turntable works on old reciever and not new one
A traditional turntable only works on Phono (which contains special preamplification and equalization circuitry designed to raise the the level and flatten out the response of a phono cartridge).
After you do that, iIf you're not having hum problems I wouldn't worry about the ground. Or try it again on the FM Ground.
Feb 20, 2009 | Sherwood RX-4105 Receiver
Low volume and unbalanced deck
Turntables require amplification, they have very low output on their own. If your Sherwood has an Aux input try using that, older receivers often had a built-in pre-amp on the aux jack. You can obtain a stand alone pre-amp for less than $50, I use one from mcm, #40-630.
Dec 29, 2008 | Technics SL-BD22 Turntable
Sherwood receiver rx-4105 fm doesnt pu any frequency (just static) , am does
You need to hook an antena to the back of the unit (A peice of speaker will do!) you should see a screw in back of uniGood luck and Thank you for using FixYa.
Dec 17, 2008 | Audio Players & Recorders
PS-T3 connection to Sherwood 4105 Receiver
You need a phono stage (phono amp) between the turntable and receiver to boost the lower signal from the turntable. If your receiver has phono inputs, use those as there will be a built-in phono stage.
Oct 14, 2008 | Kenwood KD-291RC Turntable
Sherwood RX-4105 Receiver Logo
208 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Josh Whitehead
Josh Whitehead
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
