Question about Emerson (33416-78414) Fan
Growling ceiling fans
I installed 4 emerson H96W commercial fans that are controlled by
a 10 amp solid state controller. At high speed the fans operate fine
but, as the speed is slowed the fans growel. I've heard that the growling
doesn't hurt anything although it"s annoying. Is there anything that
can be done to eliminate the fan growling?
    New Friend:
I've found that covering every single metal-on-metal joint with Teflon tape will stop all fan "groaning" problems
Posted on Apr 17, 2017
  • 2,035 Answers
Check to make sure all screws in motor housing are snug
(not over-tight) also check if the coupling covers the small gap b/w the housing ,if there no gap fan might make sounds a low speed...
good luck...
Posted on Jan 31, 2009
  • 1,800 Answers
There are several reasons why a ceiling fan will squeek or make noise. Most often, the reason is simply poor quality components. You will find this problem very common with cheaper fans that are sold at the home centers. Particularly the hugger style fans. Often times these noises can be heard from the first day the fan is installed. If all screws are tight and the junction box in the ceiling is well supported and snug, then you are the victim of a poor quality fan and the only remedy may be to see if the place where you purchased the fan will take it back if you are dissatisfied.
However, if your fan has operated for years without making noise, oiling your fan is not a solution, with the exception of the Hunter Original cast iron ceiling fans which are the only fans that require oil…or can be oiled for that matter. What you probably need to do is tighten some screws. I would start from top to bottom on the fan and make sure everything is tight. At the top, make sure the screws that hold the fan to the junction box are tight. You will need to remove the canopy that is mounted at the ceiling in order to check these screws. Next, when replacing the canopy, make sure those screws are tight. Next, check the screws that hold the blade holders to the fan motor, then the screws that hold the blades to the blade holders. This is the most common place screws get loose.
Once all of the screws are tightened, turn the fan on again and see if it still makes the annoying sound. If not, then you have solved your problem. If it still makes noise, maybe the problem is that your fan is out of balance. If your fan is wobbling, you will need to balance the blades. Check the link at the bottom of this posting for a video with instructions for balancing your fan.
If your fan is not wobbling, or you went through the process of balancing your fan and it is still making noise, then the bearings in your fan motor are probably wearing out and there is nothing you can do. All ceiling fans come with sealed bearings (except for the Hunter Original fans), therefore, oil is not a solution as some people have suggested. The cheaper fans have motors that will go out, so your best bet at this point is to replace the fan. I would suggest looking for a fan that has a superior motor next time you make your purchase. Not only will they run quieter, they will move more air and last a lifetime. The best motors can be left running 24 hours a day for years and never make a peep while keeping you 2 or 3 times cooler than cheaper fans. The best motors found in Casablanca fans that have the Casablanca XLP 2000 motor and Emerson fans that have the Emerson K55 motor. These motors are not in all of their fans, only in their upper end models. Use the link below for top quality fans to see examples.
Balancing a Ceiling Fan:
Top Quality Ceiling Fans:
  • 2,039 Answers
Do you have a vibration does it wobble please let me knw pierre
I have 2007 Suzuki XL7. I replaced radiator and fan assembly. Fans do not work. Is there a relay? If so, where is it?
Most fan and Ac relays are located in the under hood fuse and relay box. Adequately marked in owners manual or on plastic cover
Sep 03, 2016 | Suzuki XL7 Cars & Trucks
2007 ford taurus condensor fan not coming on with ac
Fan Control The PCM monitors certain parameters (such as engine coolant temperature, vehicle speed, A/C on/off status, A/C pressure) to determine engine cooling fan needs.
For variable speed electric fan(s):
The PCM controls the fan speed and operation using a duty cycle output on the fan control variable (FCV) circuit. The fan controller (located at or integral to the engine cooling fan assembly) receives the FCV command and operates the cooling fan at the speed requested (by varying the power applied to the fan motor).
EDGE/MKX, FIVE HUNDRED/FREESTYLE/MONTEGO, FUSION/MILAN/MKZ, CROWN VICTORIA/GRAND MARQUIS, TOWN CAR: FCV DUTY CYCLE OUTPUT FROM PCM (negative duty cycle) FCV Duty Cycle Command (NEGATIVE (-) duty cycle) Cooling Fan Response/Speed Greater than 0 but less than 5% Fan off, controller inactive Greater than 5% but less than 10% Fan off, controller is in active/ready state Edge/MKX, Crown Victoria/Grand Marquis, Town Car:
10% - 90% Edge/MKX, Crown Victoria/Grand Marquis, Town Car:
Linear speed increase from 30% to 100% Five Hundred/Freestyle/Montego, Fusion/Milan/MKZ:
30% - 90% Five Hundred/Freestyle/Montego, Fusion/Milan/MKZ:
Linear speed increase from 50% to 100% Greater than 90% but less than 95% 100% Greater than 95% but less than 100% Fan off
For relay controlled fans:
The PCM controls the fan operation through the fan control (FC) (single speed fan applications), low fan control (LFC), medium fan control (MFC), and/or high fan control (HFC) outputs. Some applications will have the xFC circuit wired to 2 separate relays.
For 3-speed fans, although the PCM output circuits are called low, medium, and high fan control (FC), cooling fan speed is controlled by a combination of these outputs. Refer to the following table.
If you don't understand these thing's listed above your best bet is to take your vehicle to a qualified repair shop . Have the vehicle checked for DTC'S - diagnostic trouble codes !
Jun 14, 2016 | Ford Cars & Trucks
Were is the fuse located on a 02 linclon ls for the secondary airflow injector
The solid state relay (Figure 124) switches the high current required for operation of the electric AIR pump. Input control to the solid state relay comes from the powertrain control module (PCM).
  • Disconnect SSR.
  • Key on, engine off.
  • Measure voltage of B+ circuit at SSR harness connector and battery negative post
  • Fuse # F1.11 15 amp Auxiliary fuse box -underhood
Jul 08, 2015 | Cars & Trucks
Generlly uWave oven fans have sevealr speeds. They are accomplished with an electronci speed control device in the form of a "Triac." That is a solid-state device that can fail sorted, which means the fan will run continuously on "high." It means the uWave oven needs a new controller, which will be expensive.
Feb 19, 2015 | GE Microwave Ovens
Blower on 2009 Nissan sentra went from low to high by itself and won't turn down just stays on high ? What do I do
You may need a repair book to fix this. Looks like you have a control module and a fan control amplifier that controls fan speed. Both components are solid state meaning they don't use a mechanical relay. Either component could keep the fan speed on high.
Feb 20, 2014 | Cars & Trucks
Fan control switch only works on high
If you blower fan will only work on high know that most blower motors are power by a basic electrical circuit that utilizes a multi resistor or a solid-state resistor to control different fan speed modes (low, medium low, medium and high). If the resistor malfunctions it may lose one or more of the lower fan speed settings. First check the fuse and change if needed. If that doesn't fix things change the resister.------------------------------------------------------------------------------------
Launch CResetter Oil Lamp Reset Tool
Mar 07, 2013 | Cars & Trucks
You have a special fan there. Hunter Originals are my specialty.
There are two ways to accomplish a slower speed with this fan.
1. A wall variable speed control, solid state, rated for 3 or more amps, regular fan controls will not work as your fan draws 2.5amps on high, not even new ones that are labeled for the Original.
2. Retrofit the fan to make it a three speed. If you're good with wiring, it's really simple. What you need is, a standard 3 speed pull chain switch, not a double pole one like cheaper/new fans have that use capacitor speed control, we are using cap. speed control, but not the same way they do. So you want an "SP3T" switch. You also need an 9 10 or 11 or 12 MFD capacitor (depending on how fast you want your low to be 8 is 20rpm, 11 is 75 approximately). You will remove the switch cap to your fan, and you will find your switch has a black, blue and red wire connected to it. Remove all wires, attach the black to L on your new switch, attach blue to 1, then you need 2 extra pieces of wire. Stick one wire in 2 and the second wire in 3. Now, get your capacitor and hook one side of it to the red wire and position 2, then hook the other side to the wire you put in position three.
Remember to get the Single pole switch for non capacitor speed control fans, if you get the double pole, both winding sets in your fan will be activated, which will draw double current and burn your motor out.
Also, are you aware that your fan uses oil (like an engine) ? and is not permanently lubricated?
Jan 08, 2011 | Hunter Ceiling Fan Control Switch
HB ceiling fan is getting slower and slower bi the day
Solid-state controls change the level of power in the fan motor to control the speed of the fan. For instance, when you switch from medium to high on a solid-state fan, the speed control mechanism increases the power of the motor. Solid-state controls are generally equipped in fans with controls that have predetermined settings, such as low, medium and high.
The solid state device in or around the fan motor could be defective and in need of replacement.
Dec 07, 2017 | Hampton Bay 52 In. White Redington...
The Hampton Bay Altura Ceiling fan functions only with remote.
I contacted the manufacturer ( after my Altura fan would run on high speed only and the remote would not control any thing. They said their was a manufacturing defect with a capacitor that affected many of the Altura fans. We are now on a waiting list for a new capacitor and housing, because they did not have enough replacement parts.
Nov 26, 2008 | Hampton Bay 52 In. White Redington...
Emerson (33416-78414) Fan Logo
337 people viewed this question
Top Emerson Dryers Experts
Jim Thurston
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Emerson Dryer Expert? Answer questions, earn points and help others
