Question about Bowflex Treadclimber TC5300
I was able to calibrate but my right belt is crooked. it is too far on the right in the back and too far left up front. I tried to loosen belt and readjust belt but it didnt work. HELP
    President:
  • 2,976 Answers
Take the belt off and either flip it sideways it or replace it. The belt is stretched out of alignment.
Posted on Jan 31, 2009
Do you remove belt when removing alternator
Hi:
To remove the belt, you must loosen the belt tensioner pretty far.
It is located up near the front of the engine, not far from the air conditioning compressor. It has a 10mm bolt that must be loosened, and that will allow the belt to be removed. After the Alternator is replaced, tighten the belt back up, and start the car , shut it back down and adjust the belt as needed.
Mar 22, 2014 | 1998 Honda Civic
Trying to get main pulley off of front of motro to change front seal. Can't figure out if bolt is right or left handed threads. Do I need a special tool for it?
there are special tools, you just need to stop engine from turning, left to loosen, (right hand threads)you need to do a timing belt service while its apart.
Sep 13, 2011 | Subaru Impreza Cars & Trucks
How to replace the belt on the Maytag Neptune FAV6800AAW?
See if my Clutch Fix post will help. I also have links to Service Manual which will be big help. The drive belt can be walked on the Clutch Pulley but it is a very snug fit even with the drive belt tension bolt loosened. Watch you fingers as you walk the drive belt onto the clutch pulley….Rich
Apr 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Timing belt replacement
Disconnect negative battery cable. Disconnect power
steering reservoir, and remove reservoir bracket.
Disconnect wire harness bracket for Data Link Conne
ctor No. 1. Remove generator and generator bracket.
Remove ABS actuator. Raise and support vehicle. Rem
ove right front wheel. Remove right engine
undercover. Remove power steering drive belt. Sligh
tly jack up engine and remove right engine mounting
insulator.
Remove spark plugs. Remove crankshaft pulley. . Remove right engine mounting bracket.
Remove No. 2 timing belt cover. . Temporarily install crankshaft pulley with pulle
y bolt. Set No.
1 cylinder to TDC on compression stroke. .
Loosen mounting bolt of No. 1 idler pulley and shif
t pulley toward left as far as it will go to reliev
e belt
tension. . Temporarily tighten idler pulley. Remove cranksh
aft pulley and No. 1 timing belt
cover.
If reusing timing belt, mark direction of rotation
on belt. Also place match marks on belt and camshaf
t
pulley. . Remove timing belt from engine.
NOTE:Always turn crankshaft clockwise.
Mar 18, 2010 | 1997 Toyota RAV4
My belt keeps coming off on my tiller its a 24
There are several possibilities:
1. the belt is old and over stretched and needs to be replaced.
2. you have a bent shaft that causes the pulley to speen crooked.
3. The pulleys are not lined up. You should be able to adjust them by loosening them and sliding them back and forth on the shaft.
Mar 09, 2010 | Craftsman Garden
I need to replace a belt on my hotpoint dreyer how do i do it
Disconnect power.
Open the door and look along the front upper edge of the door opening. In the top left and right rounded corner of the door opening you will see screws going upward into the top. Remove both screws and raise the top.
Look down inside the open top dryer from above . If unbroken it should be showing across the tub from left to right. If broken you won't see a belt (about 3/8" thick). If belt is missing, proceed. On each left and right edge there will be a screw holding the front assembly to the case of the dryer. Remove 1 on each side.
The dryer front can now be pulled toward you about 3 inches at the top. Take the new belt and work it over the drum from front by lifting and rotating the drum. Lay belt on drum about 1/2 way back from front with groves down on the drum and proceed to reassemble machine by reversing disassembly procedure.
When reassembling the top, part of each underside edge of the top must go beneath a sheet metal lip located at each right and left edge of the dryer just below the control panel. If the small space between the side and top panels is wider at the back than the front you have not accomplished this alignment, try again.
Once you have the top and front back on, pull out the dryer and remove the small access panel at the back bottom. The belt must be "looped" around the motor and idler pulley like this ( http://www.applianceaid.com/images/ldrger-idler-pulley.jpg ). Slowly turn the drum around one turn to line up the belt, to make sure that it will not fall off because of being crooked or twisted.
Sep 16, 2009 | Hotpoint NWXR473GV Dryer
Replace the serpentine belt
First note the route of the belt. make a drawing.
Adjustments are made by moving the power steering pump. far right of belt system.
loosen top fixed bolt above center of drive wheel on p/s pump.
loosen bolt below drive wheel on p/s pump.
Push p/s pump to the left to loosen belt.
Remove old belt .replace following route of your drawing.
move p/s pump to right .
top of belt should have 1/2 inch deflection.
tighten bolts
The end
If you dont have belt route mail me at
andymalt61@hotmail.com
for drawing
Good luck .Andy Bartolo
Mar 17, 2009 | 1998 Jeep Cherokee
HOW TO REPLACE A POWERSTEERING BELT ON A 1997 ISUZU RODEO
If it is like a 94, the power steering belt is either middle or front, You might be able to sneak it past the fan, not sure, usually you have to take the fan off, Not the four bolts up front but the 3 bolts into the block holding the bracket. take the fan shroud out,2 srews/ bolts, and clips, getting the top radiator hose out of the way helps. Loosen the tension nut up front, and I believe you have a square hole for a half inch drive breaker bar, use it to move the pump left and right to loosen and tighten the belt. Then tighten the nut back up, put every back, you are all set. If the belt is in the middle, you have to take off the ac belt first. Loosen the tensioner on this belt, and wind it down, Then back up when you are done. Hope this helps.
Jan 26, 2009 | 1997 Isuzu Rodeo
My bowflex tc5000 will not calibrate
Check the speed sensor and make sure it is no farther than a credit card away from the drive pully. Unplug unit Located...remove left and right rear covers and back cover. 3 screws in each and 4 screws in back. Follow 2 black wires up to drive belt pulley under back of left treadle. slide sensor in with cc between it and the pully. Recalibrate
Dec 07, 2008 | Bowflex Treadclimber TC5300
Bowflex Treadclimber TC5300 Logo
246 people viewed this question
Top Bowflex Sport & Outdoor - Others Experts
Jerry Greenberg
Jerry Greenberg
Paul Carew
ray gallant
Are you a Bowflex Sport and Outdoor - Other Expert? Answer questions, earn points and help others
