Question about Black Box IP Address Translator With Bandwidth Management (LR0051A) Proxy Server
I can't find the IP Address on my ARRIS Router!
I just bought an Xbox Live Netwroking adapter and I have to put in an IP Address but I can't find it!
    Scholar:
  • 54 Answers
The ip address should be given automatically by the router but since it is asking,
in your computer go to start,run,type in cmd and hit enterm
it should open a black box in that box type in ipconfig and hit enter,
it should give u a list of result,search the one which says ip address,
if the ip address of ur computer is 192.168.1.2,then the ip address for your xbox should be 192.168.1.7,
if the ip address is different than the example i gave you just make sure that the difference between the last numbers should be 5 atleast....let me kno the ip address of your computer and i can tell what ip address u need
for the xbox...........
Posted on Feb 05, 2009
I bought a new DSL-2642B Wireless Router and Modem but it won't let me connect to Xbox Live, the solution that the Microsoft Solution thingy game me was to change the MTU settings, any idea of how to...
In order to connect to Xbox Live with a Wireless Modem and Router, you will need a Xbox 360 Wireless Adapter. You can get a Xbox Wireless Adapter cheap on eBay, or you can buy it Microsoft at Gamestop. http://www.gamestop.com/browse?nav=16k-Xbox+360+Wireless+Adapter
To find your MTU Settings, follow these steps.
1. Click on 'Start'
2. Click on 'Run...'
3. In the bar, type CMD, and hit enter.
4. A black box should appear. Type "ipconfig" without quotation marks in the field.
5. Your IP Address, Subnet Mask, and Default Gateway codes should pop up.
6 Go to your internet browser and type you IP Address into the URL box.
7. You should find MTU settings, and you can set them to your desire.
May 28, 2011 | Microsoft Xbox 360 Console
How do I open my NAT settings for xbox live on a D-Link DSL-G604T. I also want to forward the specific ports for Xbox Live which are TCP [80] and UDP [88, 3074] but I am not sure how.
What you need to do first is set a static IP address on your Xbox. Also put the router IP address as the gateway and DNS server.
Don't know how you do that as I have never used one but it must have some network settings somewhere for you do that on the xbox.
Then go back to the network settings where your were on the router and set the following:
Rule Name: Xbox UDP 88
Private IP: put the ip address of your xbox here
Protocol: UDP
Port Start: 88
Port End: 88
Port Map: 88
Rule Name: Xbox TCP/UDP 3074
Private IP: put the ip of your xbox here
Protocol: Both
Port Start: 3074
Port End: 3074
Port Map 3074
Good Luck, feel free to get more clarification, do rate the solution if got help
Dec 08, 2010 | D-Link DSL-G604T Wireless Router
My Zonet ZSR4134WE Wireless-N router doesn't connect to live. I've checked the MTU setting and everything. It works perfectly, until it gets to the "Xbox Live" part of the test, then it fails. Please help.
you need to open the ports on your router for xbox ports are TCP 88 UDP 88 UDP 3074 TCP 3074 UDP 53 TCP 53
first connect the xbox to the network and get the ip address (like 192.168.x.x) and then use the computer and login to router setup page and under firewall open these ports for the ip address of xbox . If you find a DMZ there , then enable it for XBOX ip address and reboot the router. ** imp: try to make a static ip address on xbox so when you restart the xbox teh ip address should not change -
to check what is the ip address provided from you router :- go command prompt (start ->run- > type cmd and hit enter) a black screen(command) type ipconfig you will find ip address of computer , so you can set the ip address of xbox like that -but just make the last number different (like ip address on computer 192.168.2.5 then make ip address of xbox to 192.168.2.6) perform this will help .. its all about the ports but be sure with ip address
Oct 01, 2010 | Zonet ZSR4134WE Wireless Router
I got belkin wireless g gaming adapter for my xbox 360 the other day and i downloadaded the cd on my computer and followed the instructions, but when i put it in my xbox 360 the xbox couldnot find the...
You will need to match the wireless settings of your router and the gaming adapter.
Who is the manufacturer of your router?
connect your computer to the router with the cable and open the set up page of the router. check the wireless settings of the router SSID, Channel, security settings.
now you gaming adapter and the Router IP address should be in the same range. Suppose if the router IP address is 192.168.x.y and the default IP address of the gaming adapter is 192.168.a.b., then the number x should be equal to a. If it is not then you will need to change the IP address of the gaming adapter so that x will be equal to a.
after that open the set up page of the gaming adapter and change the wireless settings.
power cycle the router and the gaming adapter and now it should work.
For more info about networking Click Here
Oct 06, 2009 | Belkin (F5D7011) 802.11g/b Wireless...
IP address
I had the same problem with my Xbox and Netgear DG834 v4 (wired) router. I bought a Belkin F5D7632 wireless router and that did not work either. I then bought an Xbox wireless adapter and it connected ok. I do not know why the wired connection does not work. The cable length is 10m.
Dec 30, 2008 | Microsoft Xbox 360 Console
Ip address failed
I think you need to ring your internet provider and they will enable xbox live from their side. Its fairly simple and they will know what your talking about.
Oct 20, 2008 | Microsoft Xbox 360 Console
You need to let it automatically find dhcp and it will grab that ip address. If not then theres something wrong with your router because its now leasing an ip address out to the xbox at all. So make sure dhcp is enabled.
Aug 17, 2008 | Microsoft Xbox 360 Console
I cant get wirless xbox live
The 1st question I have is, are you using the official Microsoft wireless adapter (sold seperatly) manufactured by Microsoft? That is the first solution to this issue. If so you must go into your router settings using the home router IP address usually listed on the router unit and setup the router manually to see the microsoft wireless adapter (sold seperatly), try typing this ip address into your browser address line (192.168.1.1) this is usually a generic router IP address to access your router. Your 360 should have a MAC address listed when in the settings and that should be seen by the router as well. Also check your firewall settings to make sure that it allows wireless transmissions. ( My computer usually has to be running for it to see wired & wireless devices properly). I also prefer just running a wired network for connectivity issues with wireless, such as other electronic interferrence from cordless phones & microwaves as I sometimes get with my nintendo Wii.
PAeasop
Apr 20, 2008 | Microsoft Xbox 360 Console
Xbox 360 wireless adapter connection
Try resetting your router and reconfiguring. Secondly try using a different wireless security mode that the 360 adapter supports. If the router is a linksys, that could be the problem. Linksys has a very common drop problem. I have found that D-Link has better integrity for wireless devices. Also try putting another device on the network via Wireless, if the same result, replace the router. Also, you can do a search on google for wireless router tweaks, to optimize the router for and xbox wireless connection. One more thing. be sure you force an ip address for the adapter in the settings area on the 360. That promises the same IP everytime it connects. Then go into your router configuration and forward the ports for xbox live, the wireless connection may not even be dropping, but a port problem with live while trying to authenticate your game system
The following ports must be available for Xbox Live to operate correctly:
• UDP 88
• UDP 3074
• TCP 3074
Jan 06, 2008 | Microsoft Wireless Network Adapter Xbox...
Wireless connection of xbox 360
you can find your I.P adress on the PC you use at home that is connected to the wireless modem.
if not theres an option on the xbox 360 to find the I.P automaticly try that!
hope this helps please rate me
Regards Grant
Nov 25, 2007 | Microsoft Xbox 360 Console
Computers & Internet Logo
2,187 people viewed this question
Top Black Box Computers & Internet Experts
Johnny Massengill
Johnny Massengill
Glyn
Are you a Black Box Computer and Internet Expert? Answer questions, earn points and help others
