Question about Whirlpool LGQ8000JQ Gas Dryer
Dryer Runs - no heat
I am at a loss.
I own a Whirlpool gas dryer, Model # lgq8000jqr.
It stopped working about two weeks ago. All the advice I have recieved has led me to two possibilities. Both of which I have addressed.
I have replaced the thermal cut out and the ignitor. I still have the same problem.
I have checked...the gas is on, the dryer is plugged in.
I am obviously missing something.
the other thing I have noticed, is that although I have allowed the dryer to run for up to ten minutes ( trouble shooting ) during these repair times, I have not been able to detect the odor of gas, shouldn't that be prevelant?
At any rate.....can you help me?
Thank you in advance.
  • 10 more comments
  • rsbosak3 Jan 31, 2009
    If the other thermostat or radiant sensor is just beneath the thermal cut off, then it has been replaced. ( when I replaced the thermal cut off ) If these are in a different area, then I'm not certain where to look for them, or what they may look like.
    If the other thermostat or radiant sensor is just beneath the thermal cut off, then it has been replaced. ( when I replaced the thermal cut off ) If these are in a different area, then I'm not certain where to look for them, or what they may look like. Also
    If the other thermostat or radiant sensor is just beneath the thermal cut off, then it has been replaced. ( when I replaced the thermal cut off ) If these are in a different area, then I'm not certain where to look for them, or what they may look like. Also noted
    If the other thermostat or radiant sensor is just beneath the thermal cut off, then it has been replaced. ( when I replaced the thermal cut off ) If these are in a different area, then I'm not certain where to look for them, or what they may look like. Also noted that
    If the other thermostat or radiant sensor is just beneath the thermal cut off, then it has been replaced. ( when I replaced the thermal cut off ) If these are in a different area, then I'm not certain where to look for them, or what they may look like. Also noted that the
    If the other thermostat or radiant sensor is just beneath the thermal cut off, then it has been replaced. ( when I replaced the thermal cut off ) If these are in a different area, then I'm not certain where to look for them, or what they may look like. Also noted that the ignitor
    If the other thermostat or radiant sensor is just beneath the thermal cut off, then it has been replaced. ( when I replaced the thermal cut off ) If these are in a different area, then I'm not certain where to look for them, or what they may look like. Also noted that the ignitor is
    If the other thermostat or radiant sensor is just beneath the thermal cut off, then it has been replaced. ( when I replaced the thermal cut off ) If these are in a different area, then I'm not certain where to look for them, or what they may look like. Also noted that the ignitor is not
    If the other thermostat or radiant sensor is just beneath the thermal cut off, then it has been replaced. ( when I replaced the thermal cut off ) If these are in a different area, then I'm not certain where to look for them, or what they may look like. Also noted that the ignitor is not getting
    If the other thermostat or radiant sensor is just beneath the thermal cut off, then it has been replaced. ( when I replaced the thermal cut off ) If these are in a different area, then I'm not certain where to look for them, or what they may look like. Also noted that the ignitor is not getting red.
    Problem Solver:
  • 12 Answers
Have you checked the other thermostat or the rediant sensor?
Posted on Jan 31, 2009
  • skc34673 Jan 31, 2009
    #7 Thermal Fuse
    #9 Thermostat
    #15 Thermostat High-limit
    #49 Radiant Sensor
    If you have tried these parts you might need a new pilot. I'm not sure what type of gas you have for your dryer. Try this site for diagrams and parts list.
Our Whirlpool Model LGR4634JQ0 will not heat up. I took the peep hole cover off and watched as I turned the gas dryer on (high heat). The chamber heats up and glows bright orange for maybe 15-20 seconds...
You're a good detective! Gas dryers have an ignition panel (what you saw glowing bright orange) that heats until it reaches a certain temperature. This temperature will cause the gas from the pilot to ignite and the dryer will run, staying at a constant temperature and thereby drying your clothes. It sounds as it your ignition panel needs to be replaced. It is a relatively simple process if you are comfortable making repairs. If you aren't, I suggest calling a repair professional. We did this a num ber of years ago. The repair service was reasonably priced and our dryer worked for another 6 years!
Good luck. If this works, please return to Fixya and rate my advice!
Jul 31, 2011 | Whirlpool LGR4634J Gas Dryer
Whirlpool dryer stopped heating Model - wed5500sq0
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101.,.,.
Mar 21, 2011 | Whirlpool Dryers
My whirlpool dryer runs great but all of a sudden has no heat. The motor is fine. Model ler6634bwo What is the success rate of changing the thermostat?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101..
Oct 11, 2010 | Whirlpool Dryers
Our Whirlpool Gas Dryer (Model No. WGD5200VQO) doesn't seem to heat up. It runs for hours and hours to dry a load of laundry. Admittedly, it never really worked that great since it was new. Any ideas on...
heatman101
Oct 02, 2010 | Whirlpool Dryers
Stops heating untill totaly cools down runs 1 cycle then stops
heatman101
Sep 20, 2010 | Whirlpool LGQ9858P Gas Dryer
Hi, I have a kenmore gas dryer Model # 11077532600. When I first turn it on the gas runs then shuts off after about 5 to 7 minutes. I experienced this problem a year ago and we had the thermal fuse...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Sep 02, 2010 | Kenmore Dryers
My gas dryer all of a sudden just stopped getting hot. it runs but just does not get hot.
heatman101
Sep 02, 2010 | Whirlpool WGD5600S Dryer
Gas dryer heating element won't come on.
There is a controller problem to turn on the gas manifold to produce heat. Since you have it only one week old, let's take the advantage of the warranty to have a new controller unit replaced.
Jan 03, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer does not glow or lite up but it runs
I just diagnosed the same problem with my estate model by wirlpool. It is most likely the thermal fuse located in the back (behind the panel) It is a $12.00 part. My neighbor fixed his father's unit with same issue 2 weeks ago.
Mar 07, 2009 | Whirlpool LGV4634JQ Gas Dryer
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool LGQ8000JQ Gas Dryer Logo
232 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
