Question about Frigidaire FEF376 Electric Kitchen Range
Frigidaire electric range fef336 heating elements not heating
Not heating or lighting. unplugged for a few days, turned back on and clock working but not heating elements...please help!!
  • Anonymous Mar 31, 2014
    Heating element replacement
  • 750 Answers
Range does not heat (lights and timer do not operate).
This would indicate the range is not receiving the required 220 volts. Check house hold breakers or fuses, open wiring between the terminal block and the components, and the power cord.
Please leave a rating!
Posted on Jan 31, 2009
316418305 broiler element and bake element will not heat
Good Afternoon Friend,
I see that you are having trouble with your Frigidaire range, model# FEF336BC, broiler and bake element not heating. I would give your range a hard reset. You can do this by either unplugging it or cutting the power at the circuit breaker for 2-3 minutes.
After restoring power you will need to reset the clock. You will do this by entering in the time and pressing start.
Turn your oven on and if the elements are still not heating, I suggest either contacting the manufacturer or contacting your local authorized technician to diagnose your appliance. Hope this helps.
-Best Regards-
WP
Jan 23, 2012 | Frigidaire FEF336BC Electric Kitchen Range
I replaced an element in the oven of a frigidaire model fef366emd and somehow one of the spades came off the element without my knowing, I turned it on to see if it would work and I heard an electric...
all repairs should be performed by an authorized service person.you may have blown your home electrical breaker for the range. reset the home breakers make sure you reset both breakers. high voltage ranges have dual switches.the range should work after resetting the breakers.
Jun 02, 2017 | Kitchen Ranges
Heating element in Frigidaire range, model number FEFL64FSD.
Either the bake element is bad or the clock / control is bad. Element can be tested with an ohms meter
Sep 29, 2017 | Ovens
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
I have a Frigidaire ES330 electric range.The
The problem would be in one of your surface burner switches. You will have to determine which switch is bad. On the back of each switch should be a connection labeled "p". Unplug stove and Remove this "p" wire from any switch. Then plug back in and check to see if light goes out. Repeat this process for each switch until you find the bad one. Before you remove the p wire from each switch, be sure stove is unplugged.
Aug 22, 2017 | Kitchen Ranges
Bottom element on range doesn't work
we can check a few things, first off you need to confirm 220v. to unit itself, ill assume you do, the top elements are working correctly.. sounds like a bad electronic control, what youll need to check is on the control itself, there is a wire labeled L1, then there will be a bake terminal, ill also assume L1 has 110v, other\wise the clock wouldnt be liting up, but if you carefully unplug the bake terminal and test terminal for power( it will have 110v, after you select bake andstart oven.
Nov 17, 2008 | Amana AER5515QA Electric Kitchen Range
Frigidaire Electric flat top Range
My range will not hold the heat for either the convection or regular heat. the model number is CGLEF385AS2
Oct 07, 2008 | Frigidaire FEF364DQ Electric Kitchen Range
Oven shuts off
It possibly incompatible heating element installed on the oven that's why it pops up when you try to turn on and heat it..
Feb 24, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Element light is on but no heat from the burners
You only have voltage coming in on one leg of the 240 line. Either the terminal block connectors are loose or burned or you need to check the circuit breaker in the house and reset it. It is also possible that one of the wires burned off in the back of the unit between the terminal block and the clock.
Jul 20, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire FEF376 Electric Kitchen Range Logo
344 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
