Question about Sony Playstation 3 (PS3) Console
Ps3 wired connection prob.
I have a ps3 and a cable modem connected to a computer which works fine. The modem has an ethernet port so I ran an ethernet cable directly from the modem to the ps3. I still cant get the ps3 to connect???
  • 650beast Mar 08, 2008
    i run my cable directly from my modem to my ps3and i still cant connect for online gaming i have the mac address and i even was able to find the IP address but my ps3 times out every time i run the connection test which doesnt let me play my games onliine
    Problem Solver:
  • 11 Answers
I can't be certain, but does your ISP rewuire the hardware connecting to it to have a certain MAC address (i.e. the one used to first 'activate' the Internet connection)? If so you may need to 'clone' the MAC address to get online either by a router or some other method.
Posted on Sep 26, 2007
SOURCE:
I am trying to set up a switch between my PS3 and my PC. I have an external DSL modem. I purchased a 5 port switch(Rosewill RC405-x) but no luck. Can I use an ethernet splitter instead?
You did not explainhaow you connected all your equipment together.
Connect your PC and PS3 into the 5 port switch.
Connect your DSL modem into the 5 port switch, if there is a WAN/internet port on the 5 port switch then connect the DSL model into this port.
You may need to power off the 5 port switch wait a 1 min and power up the 5 port switch again so it can setup an IP address table for the connected ports.
If this still does not work the replace the 5 port switch with a normal 5 port hub.
Mar 20, 2012 | Rosewill RC-405 - Switch - 5 ports -...
A need help
you can set your playstation 3 online by two ways, 1- by a wired connection, and 2- Wireless,
1-Wired Connection: Plug an ethernet cable from your highspeed modem to the back ethernet input on your ps3 system, and follow on your ps3: Network Connection > Internet Connection Settings > Easy > Wired Connection. and follow steps
2- Wireless Connection: You must have a Router connecting ethernet cable from your intenet modem to the router, and follow on your ps3: Network Connection > Internet Connection Settings > Easy > Wireless Connection and follow steps,
hope this helped you on setting up your ps3 connection :)
Apr 13, 2010 | Sony Playstation 3 (PS3) Console
How can I connect my ps3 to my computer modem?
Here is a general guide I wrote. For Vista, however, I think you will have to go to the sharing tab instead of the advanced tab when you are browsing the properties of a connection...
1. Get a CAT5 or CAT6 crossover cable. The cable that came with the PS3 is a normal Ethernet cable, therefore it cannot be used for this operation.
2. Make sure you have two sources for network communication. For example, you can have 2 ethernet ports on your computer, or you can have a wireless card and a Ethernet port etc. It helps to draw out a connection blueprint such as this:
DSL Modem > CAT5 cable > Network Card 1 > Computer > Network Card 2 > CAT5 Crossover cable > PS3
3. Connect your computer to the modem and verify that you have an Internet connection. Then, click on Start, go to settings, control panel. Double click on Network Connections, and identify the connection to your modem (Network card 1).
4. Right click on the modem connection, and choose properties. Next, click on the advanced tab (Sharing tab for Vista users), and check the “allow other users to connect…” checkbox. After the checkbox is checked, click on the “Home networking connection” drop down box and select the name of the second network connection. Click OK and exit the properties window.
5. Finally, connect the CAT5 crossover cable from the second network adapter of the computer to the PS3, and voila, your Internet connection is now routed to your PS3. Please be aware that your computer must be on in order for your PS3 to stay online. In the long run, a router may be a much better device to use than your computer, since it consumes only a fraction of the electricity than your computer does.
Mar 16, 2010 | Sony Playstation 3 (PS3) Console
Will not pick up my pc
then there is no connection from your ps3 to your computer/modem. make sure you have a phone wire connecting your modem to a pc, then have a ethernet cable connecting your ps3 to the modem. or you can keep the phone wire to the pc, and connect the ethernet cable to the ps3 and the pc.
Dec 14, 2009 | Sony Playstation 3 (PS3) Console
PS3 (80GB) Obtain IP Address : Failed, Help?
Try swapping the ends of the ethernet cable between your PS3 and the router. Otherwise, try a different ethernet cable. Also check that there are lights on by your ethernet port on the PS3 and the router.
Mar 31, 2009 | Ubi Soft Entertainment Tom Clancy's...
I have no computer or cable and need to set up internet on my PS3
??? A router will NOT replace your modem; the router won't work without the modem. If you're going to give advice, please make sure it is somewhat correct.
Okay. So first you need the telephone cord to go from the phone jack into the DSL port on your modem. Then you need the Ethernet cable that came with your modem (looks like a phone cord but much bigger) to go from the ethernet port in the back of the modem into the wan or internet port on the router. Verify that the DSL and internet lights are on on the modem.
For the rest of the setup, watch this . It will walk you step by step in connecting your PS3 to the wireless internet. Thanks and please take a moment to rate as fixya.
Feb 04, 2009 | Sony Playstation 3 (PS3) Console
Ethernet port
two ports will be available on the CPU, normally 1 port for the phone cable and the other to modem, please connect to one of these ports and see.
Feb 07, 2008 | Computers & Internet
Need help with ps3 internet hook up
The ps3 wifi is very finicky --
While the ps3 scans for a hotspot turn the router off then on so the router aquires the ps3.
Goto settings
Goto network settings
Goto network connection, select enable
Goto Internet connection settings just below internet connection-
Push yes when it says you may be disconnected
Select wired or wireless
For wireless use scan or enter manually
Follow on screen instructions.
Once that is set up return to main menu and go to network near the right
Then once in the internet browser press triangle and goto file and enter the internet address you would like visit.
If all else fail use the ethernet cable to attach it to your laptop. Then run network setup on the laptop and add the ps3.
Nov 10, 2007 | Sony Playstation 3 (PS3) Console
Ps3 wireless
It depends... If you use a router for the Internet then you don't need any cable, just turn on the router and then go to the PS3 and configure the PS3 to work with the router. If you have wired internet, then you will need an Ethernet cable, but since the PS3 comes with an Ethernet cable, you don't need to buy one. With the Ethernet cable, you have 2 options. If your modem has an Ethernet port, then just connect the PS3 to the modem directly. If the modem doesn't have an Ethernet port or direct connection won't work, then you can use Internet Connection Sharing to connect your PS3 to the Internet.
Jun 29, 2007 | Sony Playstation 3 (PS3) Console
Internet connection
Sony Playstation 3 (PS3) Console Logo
119 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
