Question about Directed Video Mobile DVD Player with 9" Widescreen Overhead LCD Monitor - OHD901 Car Video Player
Directed monitor ohd-901 no video
I have a directed ohd-901 and I have a AV switch box for a ohd-1000 the guys at Directed Electronics said the 13 pin din plug is same but wired diferent at the AV switch box and the monitors so it doesnt work. I would solder in and add my own rca output and inputs if I can find out what wires are the video audio ect. Directed Electronics also said they dont warranty or sell the AV switch box and couldnt give me a wiring schematic for the 13 pin din plug or monitors. I have looked on web and had no luck anyone with any ideas let me know please. thanks Tim from Las Vegas
2 Suggested Answers
SOURCE: wire harness
I have a Directed OHD1040 dvd player with no wire harness nor control remote. Do you know where i can get the part for this unit without having to travel the world?
thank you so much
Posted on Feb 16, 2009
Hi There, I have a Marantz SR7005 Receiver and Bose 901 Series VI speakers with the Bose equalizer. I'm struggling to figure out the best way to connect the Bose equalizer/speakers to the SR7005. ...
It sounds like you've read one of my many posts on 901 deployment in the AV world.
Functionally, what is the difference between one amp with 'x' channels or 'x' mono amps? Nothing. Pre-outs don't know or care what else an external amp does.
According to this link http://www.ecoustics.com/electronics/products/new/642968.html those amps are 2- and 5-channel, respectively.
There was a time when I had two bridged-mono Carver Cube atmps (at a real 400 watts) pushing one 901 each but that was big time overkill.
I now use a Carver AV-406 (functionally the same as your MM7055) with the 901 EQ in between the AV Receiver's front pre-outs and two 110-watt channels. Other channels on the AV-406 pull subwoofer and surround back duties. My AVR directly powers only the center and surround speakers.
The MM7025 would work for you.
Jul 07, 2011 | Marantz SR7005 Receiver
Directed Video OHD800B will not power on...Please help?
Check the yellow wire, it has a 3 amp inline fuse. I have found that the inline fuse holder itself was defected and I replaced the whole fuse holder. You can find one at Radio Shack, Part # 270-1238.
Aug 02, 2010 | Directed Electronics OHD800B 8.5 in. Car...
How to install bose 901 eq to my pioneer vsx-1019ah-k
This works for all models of AV receivers when you want 901's as Front L&R speakers..
Get yourself a nice separate amp, draw the Front L&R pre-out signals from wherever you can find them. On many, there is a pre-amp out for every channel in case you want to run external amps for any channels. That is how my old Pioneer VSX-36TX is equipped. For others, you may have to borrow the signals from a typical Tape- or Adapter-Out RCA pair. Just remember, AV receivers disable digital inputs as soon as you switch in a Tape Monitor, so choose one you won't have to switch IN. The signal Out is always there regardless of the monitor state.
Patch the Active EQ directly off that point (Amp In from the receiver, Amp Out to the new amp). Run all the speaker level settings on the AV Receiver and rock on.
Nov 04, 2009 | Pioneer VSX-1019AHK A/V receiver
I would like to know how to connect my Bose 901 to my Yamaha RX-V765 AV Receiver.
Ahhh, the good ole Bose 901. (I like those)... And you want to connect them to the Yamaha RX-V765 AV receiver. That should be a piece of cake. I assume you only have two Bose 901 cabinets. If so, you simply need to connect one end of your speaker wires to the terminals found on the 901 cabinets, and the other end of the speaker wires need to go to the Front Left and Front Right speaker outputs of the RX-V765. The RX-V765 is a 7 channel surround receiver. Weather you run it as a 7 channel theatre or as a more classic 2 speaker configuration, you will want to run the 901 cabs from the Front L and Front R speaker outputs, unless for some reason you want to specifically use them for any of the surround channels in which case it will not harm anything if you use them for surrounds - it's just that if you're simply wanting to use them as your principal speakers, you want Front L and Front R.
So connect them as I explained, power the receiver up, put on your favorite CD and enjoy!
Oct 24, 2009 | Audio Players & Recorders
Bose 901 Hook up help !
The use of 901's in any digital AV receiver setup for anything EXCEPT STEREO listening through the 901's alone requires you to have a separate amplifier for them and to avoid having to use a Tape Monitor.
That is because if you activate any Tape Monitor circuit at all, you will kill any digital sources. That is a function of AV receivers in general, nothing to do with 901's. However, you can still draw the Front Left and Right signals out of any Pre-Out (with a Y-cable set, looping the Pre Out directly back to the Main In) or Tape Out jacks (remembering to NEVER activate that monitor on the receiver), go into the Active EQ's Amplifier Connections; then Out of the EQ's Amplifier Connection to a separate amp and attach the 901's to that amp. This way you won't introduce proprietary and potentially damaging Active Equalization back into anything in the AV Receiver with its conventional speakers.
The AV Receiver can still drive the Center, Surrounds and the Sub(s) as it is designed. This is how mine is wired.
Come to think of it, you could still have conventional Front L&R speakers on the AV Receiver, but why? Maybe one would prefer the 901's for music and some other speakers for surround. Level matching with the 901's to conventional front speakers would only be possible if the separate amp has its own volume, but it would work. Maybe I'll try it someday. None of my current amps has a volume control.
Oct 22, 2009 | Bose 901 VI Main / Stereo Speaker
How to connect old 901 Bose equilizer to amp/receiver
If you plan to use them with a home theater, you will need a seperate amplifier, as most a/v receivers don't have tape monitors. With an integrated amp hook rec out to the input on eq hook output on eq to playback on tape mon. with seperates hook pre amp out to input on eq, output on eq to power amp input.
Jun 23, 2009 | Bose 901 VI Main / Stereo Speaker
Bose 901 series V speakers
use a dedicated amp for ur 901s..and like the guru said,if ur doing multi channel amplification,just get ur front signal from ur control amp and feed it to ur 901 amp through the 901 eq.i used to work for bose as a service tech here in okinawa ,japan.
Feb 08, 2009 | Bose 901 VI Main / Stereo Speaker
Car Audio & Video Logo
159 people viewed this question
Top Directed Car Audio & Video Experts
Colin Stickland
Colin Stickland
Libran Moreno
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
