Question about Vehicle Parts & Accessories
Remote starter not 'starting'
I just bought a used 04 buick rendezvous with code alarm installed. I've read all I could find on code alarm but the remote start won't start the vehicle. I see the lights flash twice with a quick click each time and then nothing. And what is the 'key' symbol for on the code alarm remote? I was given 2 remotes, one for the keyless entry and one for the code alarm. The red disable switch in the vehicle is not activated. Not sure if I'm missing something or if I should just have someone check it out.
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
  • 22 Answers
SOURCE: Viper remote starter sets off alarm.
Whoever hooked up your system did not hook up the factory alarm disarm and arm wires. Your car thinks it is being stolen as a result of this. You need to get a wire diagram of your car and hook up the proper wires.
Posted on Dec 04, 2008
jmeyer847
  • 204 Answers
SOURCE: How to add remote starter to existing keyless entry/alarm system
No you do not need to scrap anything. Most of the starters at www.directwholesale.net will work with everything you have installed. Also its a good idea to leave all that stuff in anyway as it will take away from the resale value when you go to sell it. Most of the new remote starters will take place of the factory remote anyway so you will only need to carry one (provided you get the one that has all the features on it). If you get the cheapest one out there, you would still carry the factory remote as well (which is what I do myself). I would personally leave all the factory Honda System in and get the cheapest starter out there. Seems like this would 1.) be the best bang for the buck and 2.) not take away from the value of the vehicle since nothing would be removed. Thank you for using FixYa. Good luck to you!
Sincerely,
JC
Posted on Dec 08, 2008
SOURCE: Setting up keyless remote entry with a new remote
1. Close all doors.
2. Press and hold the Unlock button on door lock switch on drivers door.
Hold until instructed to release.
3. Insert and remove key from ignition 2 times. Do Not turn ignition.
4. Insert key in ignition a third time and leave key in ignition. Do Not turn ignition.
5. Release door lock switch on drivers door panel.
A Chime will sound 3 times indicating that you are in programming mode.
6. Press both the Lock and Unlock buttons on the remote up to 30 seconds.
A chime will sound 2 times if remote has programmed successful.
7. Repeat step 6 if you are programming additional remotes.
8. Remove key from ignition to exit programming mode.
Posted on Dec 14, 2008
  • 27 Answers
SOURCE: 2005 Scion Tc keyless entry not working
You can take the car to the dealer and he can reprogram the remote for you. Or you can buy the programming instructions for $9.95 from here: http://www.keylessride.com/order/programming_post.asp?lbfix=yes&make=Scion&remoteyear=2005&model=tC&frid=76C74C4F
You will need a working key to reprogram your remote.
Posted on Dec 19, 2008
doin12volt
  • 233 Answers
SOURCE: car starter not working
look under the dash for a small silver toggle switch....this is a disable switch for the remote start portion of the system..you may have kicked it / bumped it with your foot, causing the remote start portion to be deactivated. Just flip the switch the opposite way and try again..
Also, there may have been a pin style switch installed under the hood...Check to see if it is bent or broken, if it is, simply disconnect it and insulate the wire that was going to it.
This wire is used as a safety to keep the vehicle from remote starting while the hood is up..to keep people from being injured if the remote start is activated while the engine is being worked on.
Have whatever shop installed the system replace your pinswitch if that is the problem.
2006 rendezvous boys, alarm won't work , only when you push alarm on remote
How do you know it doesn't work? Are you sure you understand the operation of the system? It is passive nothing happens unless someone opens a door without a key like breaking windows or they try to start the car with wrong key.
Jun 24, 2016 | 2006 Buick Rendezvous
04 buick rendezvous 3400 engine cuts out at 4000 rpm but does not stall
You need to put a scanner on it and read the output trouble code. You probably have a problem with a coil pack. but to determine that you need to see if there is any codes set in the computer.
Sep 17, 2015 | Buick Cars & Trucks
How to restart vehicle after battery was replaced. It had been just sitting until the battery was replaced like more than six months.
You are facing a maintenance:
2005 Buick Rendezvous - User Reviews - CarGurus
www.cargurus.com > Research > Buick > Rendezvous
CarGurus Rating: 4 - ā€ˇReview by heatingguy
2005 Buick Rendezvous Reviews: Read 10 candid owner reviews for the 2005 Buick ...Many issues involving repair problems have been taken care of.
Jul 26, 2015 | 2005 Buick Rendezvous
ALARM INSTRALL WITHOUT REMOTE START
You need to install the power wire and the ignition wire on the alarm . Most alarms draw power from the thick power wire some have a small power wire and Small ignition wire input that needs to be hooked up also. Only ignition one needs to be hooked up.
May 04, 2014 | C3RS6652W
Wiring diagram for a remote starter 2003 buick century
need to contact the manufacterer of the unit or go to that web adress and see if you can download the manual for it..
Dec 24, 2013 | 2003 Buick Rendezvous
Remote start
my 2000 chevy malibu shakes while im driving over 40 mp
Jul 12, 2013 | 2005 Buick Rendezvous
I received two of these systems in the mail and I am going to attempt to install it myself. I have been reading up and wanted to know if there are any detailed install instructions that I can find....
Not sure if you have this already, but here's a link to the wiring diagram for your vehicle: http://www.modifiedlife.com/2003-buick-rendezvous-remote-starter-wire-diagram/
Notice: All Viper Car Alarm Systems, Remote Starters and Keyless Entry Systems Require DEI Professional Installation for Warranty!! I'm sure you already have the owner's manual, but here's a link to Viper's http://www.viper.com/Support/ Last but not least... this is what I found online in regards to installing your Viper 5701 2-way Alarm w/ remote start: http://forums.evolutionm.net/evo-audio-security/364122-diy-viper-5701-install-ct9a.html
Hope some or all of this helps you!
Dec 15, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
2006 Buick Terraza Remote Starter Issue
Check the disarm wire 52pin black plug ,wire is purple (-), if you unlock the car with your factory remote before you remote start it won't sent the alarm off, this is a temporary solution
Dec 04, 2009 | 2006 Buick Terraza
Rendezvous 04, the rpms stay idling high without pressing gas.
BUICK RENDEZVOUS IDLES UP REALLY HIGH...WITHOUT PRESSING GAS. WHAT IS THIS?
Sep 30, 2009 | 2004 Buick Rendezvous
Vehicle Parts & Accessories Logo
182 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
