Question about Whirlpool Duet GHW9150P Front Load Washer
Is there a drain filter in the washer. we have lots of dogs and the washer seems to be taking longer for the cycles and maybe the hair is blocking the drainage from the clothes
  • 318 Answers
Yes there is a filter in the drain pump. remove the lower front panel and then you will see the pump.
take off the round cover and that is the screen to the pump. with what you have said it is probably plugged with lint and other stuff.
the pump will have water in it so be ready with a towel or a pan to catch the extra water. then whe you have the screen out, clean it and it should drain and work better.
the round screen is about 3 inches in diameter with a flat "handle" on the front of it. you cant miss it so take it apart and you can fix this yourself.
good luck, but you wont need luck, just a towel. about 1/2 a gallon of water.
Posted on Jan 31, 2009
Hi - my washing machine keeps f05 coding & the green start light won't come on
Is the outlet pipe blocked. Check this as sometimes the water gets backed up and this is sensed and an error is displayed
Mar 28, 2015 | Washing Machines
E4 error code on electrolux washing machine ewt 854s
E4 is the pump is blocked {not running} pehaps a hair pin or clothing wires get stuck
fully drain it and take the filter out
and clean it
these error codes are similar to candy
youll get an idea from this video
https://www.youtube.com/watch?v=kzhlvB2LjXg
Nov 28, 2014 | Electrolux EW1000i Front Load Washer
Maytag centennial washer
Dogs inside of spinner are worn out. Take screw off top of spinner and you will see four dogs that are easy to change.
Sep 30, 2017 | Washing Machines
Whirlpool Front Loading Washer Only Spins in Diagnostic Mode
replace the brushes in the motor _around 20 quid and usually the first thing to start messing up when the brushes get short is the fast spin _UNPLUG IT FIRST. you might also like to clean up the com with a bit of wet and dry
Oct 02, 2012 | Whirlpool Washing Machines
The wash cycle is taking a lot longer to do, for example the 30 min wash is taking 1 hour and sometimes longer, the motor seems fine, could it have something to do with the pump
Hi.
When the cycle hangs it means that because of a fault the conditions to advance are not met.
If the washer hangs at start (filling), then there is either a problem with water pressure, blocked inlet, or water flowing back from drain hose because of incorrect hose settings (called siphoning).
If machine hangs mid cycle, then it is often a temperature related problem. Check thermostat and element or check hot inlet and thermostat if dual inlet. Testing requires disassembling and use of the multimeter.
If machine hangs mid cycle or end of the cycle (before spin), then it can be drain system. Check drain hose, drain filter attached to pump and check the pressure switch.
Most machines have a service sheet hidden inside the control panel assembly. The tech sheets shows how to run a diagnostic cycle that will tell where the problem is.
Most common faults resulting in long cycle are heat-related and drain problems.
Regards.
Ginko
Jul 17, 2011 | Samsung Washing Machines
Water will not drain completely/or at all from unit.machine cycles thru all stages, dishes seem clean but lots of water left in botton of washer.
The filter is probably blocked.
It is inside the base of the machine.
Take out the filter and clean it and also clean out the filter well as that can also hold quite a bit of debris.
Please dont forget to vote this answer was helpful
Many thanks
Feb 13, 2011 | Dishwashers
How do i get all the dog hair out of maytag front loaders after i wash my clothers theres still dog hair on them & yes i clean the filters
Make sure you are using the proper amount of "HE" detergant based on our water hardness. Soil and pet hair are suspended in the wash engymes during the was cycle to be taken away during the drain cycle. Use of a non "HE" detergant will produce an over sudsing condition and soil will be suspended in the suds and redeposit on the garments and inner basket during the drain cycle. Using a lesser amount of non "HE" detergant will provide an insufficient amount of wash engymes and also give you the condition you are experiencing. Try using a combination of a granular "HE detergant added directly to the load of clothes along with a liquid fabric softner added to the dispensor. This should help you out. Of course shaking out the garments outdoors that have heavy deposits of pet hair would help as well.
Nov 22, 2010 | Maytag EPIC MFW9700S Front Load Washer
Washer will not drain- filter is clear
I replaced the drain pump and voila! Problem sorted!
Nov 17, 2008 | Haier HLF11P 6 cu.ft. top load washer /...
Whirlpool Duet GHW9150P Front Load Washer Logo
75 people viewed this question
Dan Webster
Dan Webster
Sal De
