Savin copier 9400d error code 542
Just bought copier they said it works just has a paperclip jam. unit looks to be in great shape. just cant find out what code 542 is. can you help????
  • scoobtatoo Jan 31, 2009
    HI I JUST TRIED IT I HIT THE YELLOW INTERRUPT BUTTON THEN THE NUMBERS 107 THEN THE RED STOP BUTTON AND NOTHING HAPPENED AT ALL I TURNED IT OFF AND BACK ON . NO CHANGE. WHAT IS A FINISHER . I HAVE A SORTER ON THE LEFT I DID UNPLUG BOTH PLUGS FROM THAT TURNED THE COPIER OFF AND THEN BACK ON AND TRIED THE PROCESS OVER AGAIN. THERE WAS NO CHANGE.
    IS THERE ANYTHING ELSE I COULD TRY. ON THE SCREEN IT SAYS ERROR CODE 542 CALL FOR SERVICE.
    THANKS TOM
  • 1,326 Answers
I believe that code has to do with the fixing unit. Try to reset it, press the yellow clear botton once then the #"s 1-0-7 then the red stop botton. The display should change.... turn the copier off then back on.. It should reset the code for you.... Just a question dose it have a finisher on it? If it dose have you tried to unplug the finisher with the power off then turn it back on...Is the code gone..if so you have a problem with the finisher... I work on to many different brands.... Good Luck
Posted on Jan 31, 2009
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
How do I fix paper jams for Savin 4018d
If it jams on the way out every copy the the exit switch is out of position or broken, if not then sep pad p/n B0392711. -Carl
Jan 21, 2015 | Savin Office Equipment & Supplies
I have a Savin 8035e. I had an error code SC542 and reset the copier as suggested. Worked great. Problem now - How do I fix alignment?
That error code is a dirty fuser thermistor. Clean it and go into service mode then turn off main power switch. That is all that is required. What is out of alignment?
Oct 10, 2014 | Savin Office Equipment & Supplies
Is there any way to reset the thermal fuse - it was just working fine, and then it said paper jam, now I get the SC-542 error code - how do I reset it first or get in the setup mode to reset the jam...
firs you go to SP mode while pressing
Starting SP Mode
1. Type the keys as follows:cleare mode button which appers in yellow color and continue the numbers 107
2. Press the cleare button which appers in red color and hold it down until the SP-mode menu is displayed (about 3 seconds) then switch OFF the machine and switch ON this process re-set the code -thanks
1 2 3
4 5 6
7 8 9
0 #
Jan 03, 2011 | Savin Office Equipment & Supplies
Please describe code 542-00
SC542: Fusing Temperature Warming-up Error
Definition [A]
The fusing temperature does not reach the fusing standby temperature within
125 seconds after the main power switch is turned on.
Possible Causes
· Fusing thermistor defective or out of position
· Fusing lamp open
· Fusing thermofuse open
· BICU defective
· Power supply board defective
· Poor fusing unit connection
SC543: Fusing Overheat Error 1
possibly a paper jam or thermistors are dirty
Nov 18, 2010 | Ricoh Aficio 450 Copier
Savin error code E-547 error code?
Fusing unit trouble.Clean the thermofuse and thermistors,check the heater lamp.After ,enter in the service mode turn the power switch OFF unplugged the crd.Wait 10 sec. plugg the cords and turn ON the machine.I think the Savin is based the Ricoh copiers machine.The service enter code is : Press the toral clear key - 1 - 0 - 7 -hold down the C key more 3 sec.
Aug 17, 2009 | Savin Office Equipment & Supplies
Savin 4035Esp - Functional Problem Message with Code SC863
Hello sir; SC 863 means your copier hard drive not good,you need to replace one. can't repair.
May 15, 2009 | Ricoh Office Equipment & Supplies
Copier reset procedure.
hi fixya180,
It seems that the error code 541 (which indicates a problem with the heating unit thermistor in the machine), cannot be reset by the user for safety reasons, ref;
http://savin.custhelp.com/cgi-bin/savin.cfg/php/enduser/std_adp.php?p_faqid=7081&p_created=1102093227&p_sid=9TrLDc-i&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PWRmbHQmcF9ncmlkc29ydD0mcF9yb3dfY250PTQzNiZwX3Byb2RzPTI1MTAsMjUxNCZwX2NhdHM9MCZwX3B2PTIuMjUxNCZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9ZXJyb3IgY29kZQ**&p_li=&p_topview=1
This error requires service support from your local authorized dealer or original point of purchase. You say that you've verified the functionality of your fuser unit; then a authorized Savin printer technician will probably just have to reset the error code of your copier.
Hope you find this info helpful in solving the problem and thanks for using the FixYa service
Kind regards
Mar 07, 2008 | Computers & Internet
279 people viewed this question
jasbo
jasbo
