Question about LG Flatron L1750S 17" LCD Monitor
Analog Power Saving Mode
When I turn my computer on the monitor stays off. I press the monitor's power button and the orange light above it goes off, obviously turning it off. I press it again and the light turns blue, the words "Analog Power Saving Mode" coming up on the screen. A few seconds after, the screen goes black and the light turns orange again. All of the solutions I've read so far have dealed with using items on the desktop, something I'm afraid I don't have the luxury of doing.
  • 12 more comments
  • Anonymous Dec 15, 2007
    when i try to turn it on it starts booting up for about 5 secs then turns off before anything comes on the screen. when i turn the monitor off then on it says"analog power saving mode." what should i do?
  • getepe Dec 17, 2007
    I've had the same thing happen to me. After moving the computer & monitor, I got the same message. I've cleaned the inside of the computer out, and replaced both the graphics card AND the monitor itself; I still get the same message.
  • Anonymous Apr 03, 2008
    The things you find out after you've spent the money...
    We recently bought this monitor and it was working fine - for about a week. Then it started doing exactly as everyone else has described - going into Analog Power Saving Mode. At first I was able to restart the computer and it would resolve itself (temporarily) but now I can't even get the monitor to come on, so I have no capability of resolving the problem the way some of the solutions are described.
  • Reuben2008 Apr 10, 2008
    I'm having the same problem as well with my 19" LCD monitor (LG, Flatron). I tried every solution possible but of to no avail. So I'm wondering if it requires a graphic card. Does it? Please help.
  • Anonymous Jul 09, 2008
    same problem
  • linke Jul 09, 2008
    I have the same problem as OP except it says 'Power Saving Mode' and doesn't say analog. I have tried my tower with two other monitors and it was fine so it's definitely this monitor creating the problem. I can't work it out! Also - the problem has gotten progressively worse - it used to work again with a restart, or a disconnection on the cable and rechecking - but now it doesn't work at all. Please help with ideas!
  • hkjeldsen Aug 13, 2008
    I have exactly same issue
  • Di_Canio_Fen Oct 20, 2008
    when I am surfing on internet or doing something in my computer, suddenly it swichs off, the screen becomes black and "power saving mode" appears on it; a few second after the light becomes from orange, blue.
  • anand120176 Nov 24, 2008
    I am also facing the same problem, i.e when i am starting the PC monitor shows Analog power saving mode & after that monitor screen goes black & LED lights orange. Kindly suggest.
  • Anonymous Nov 27, 2008
    Same problem, I thought it was the drivers, but guess what, they were not on the CD rom supplied, and are not available on the LG website. But after reading this thread I guess it's an LG problem.
  • Anonymous Dec 04, 2008
    Mine is the same. Its so annoying. I turn on the power button it turns blue. Then the monitor says anolog power save mode? Then shuts off again. How do i fix it?
  • Anonymous Mar 15, 2009
    I have the exact same problem
  • Anonymous Apr 02, 2009
    Me too - I've unplugged and replugged and reinstalled the driver several times - argh!
  • Anonymous Apr 18, 2009
    i have the same whit w1952tq
  • 1,114 Answers
Firstly check the connecting cable from the screen to the computer at both ends. Ensure that the thumbscrews that keep the connector in place are tight. Has the PC been moved recently? Any chance the cable could have been put in the wrong place? You can get the installation manual on the following link to see where that cables should go: Try resetting the monitor by pressing the "Auto/SET" button on the front panel for a few seconds with the PC on. If that fails you can do a full factory reset on the monitor by using the on screen menu and navigation to the "reset" function on the setings (gearwheel) page. This is described in the manual page A12. If all this fails then disconnect the cable to the monitor, the monitor should display "no input signal" if it does suspect the PC graphics card is faulty.
Posted on Jul 30, 2007
Well , I read all these posts . I'm also having the same problem as everyone one here . but i feel that this is not a fault with yours or my computer . this problem never happened till service pack 3 updated . I built my computer , and had no problems for 1.5 years. then about four weeks ago, maybe same time for some of you . Power Saving Mode started to happen . checked everything and no problems found . I'm trying a few things if i do find something I'll make sure I post
Posted on Jul 26, 2008
    Problem Solver:
  • 18 Answers
You could also change ur analogue cable for hdmi cable........u might need to buy a new graphics card(if it doesnt support hdmi)........i suppose that there is sumthing wrong with the PSU of the of my frndz also solved this problem by getting a new and more stronger power box.........750w
Posted on Mar 24, 2010
  • tragicguy
    tragicguy Apr 03, 2010
    ok............this might occur if you dont have the latest drivers.....for example..........while using catalyst 10.2 this problem occured.....i had to remove the gpu and then use the onboard gpu. When i ddid that i unistalled the old driver and downloaded and installed the new 1.....then i put in the old gpu and the problem was solved....
Dual monitor? Power save mode? Vista?
Go to display settings. Click on the checkered monitor. Hit the check box for extend the desktop onto this monitor.
this helped me
Posted on Sep 10, 2008
I had that same problem... remove the case of the computer and make sure the graphics card is in tight, and while you're at it, make sure its clean... that solved it for me.
Posted on Aug 01, 2007
I had the exact same problem with a brand new monitor - took it back to costco and exchanged it, works fine now, but I don't want the hassle again
Posted on Jan 24, 2010
  • rammstine911 Jul 14, 2010
    I to have this prob however, my trouble started when i forced my pc into save mode to remove some spywear. no my pc fires up i get a single beep, yet my screen stays black. anything i can do here.
We have rolled out Dell Optiplex 790 machines running Win XP and using E2210 monitors. Recently networking applied power managment options to power of the monitors in 20 mins of inactivity. The monitor...
Turn off power saving mode in your monitor. In monitor beside orange light there will be a menu button press it and find for power management ok it turn of power management. The problem will be fix.
Sep 13, 2017 | Dell E2210 22" Widescreen Flat Panel...
Dropped keyboard. Now display on monitor says 1. Analog input in power save mode - press any key or move mouse to turn on. I have done both, neither works. I have turned off system and I see it rebooting...
the message Analog input in power save mode means that your monitor is not getting a signal from your computer.
Maybe you moved the video cable while reconnecting your keyboard? check both ends of your video cable.
If you have a DVI cable, then your monitor has to be switched to digial input.
I hope this helps.
Nov 10, 2017 | Dell UltraSharp 1708FP 17" LCD Flat Panel...
When I turn my computer on the monitor stays off. I press the monitor's power button and the orange light above it goes off, obviously turning it off. I press it again and the light turns blue, the words...
the monitor is not getting any video information from your computer .. check the connection at the computer to make sure it is fully plugged in .. make sure the video card (if it has one) is securely in place ... make sure the monitor is actually plugged into the right connector .. you may have a bad video card or a damaged cable to your monitor .. you can plug the monitor into another computer to make sure its ok ..
Feb 28, 2010 | LG Flatron L1750S 17" LCD Monitor
My main home computer whener turned on goes to analog powersaving
LG does not show the 1750 monitor on their web site. It did show some discontinued monitors including a 1752, but there was no information available about them.
Another LG site said to use the far right bottom to auto adjust....for another monitor.
My HP has four buttons, MENU, <, >, and Return (also AUTO). Menu opens the monitor dialog box, with the arrow bottoms shifting through the menu. Select an item with return, then arrow to your selection, menu is also your exit button.
You may have a power saving selection here.
Also check the control panel for the POWER OPTIONS properties. A power scheme selection here will also change the mode of your monitor.
good luck
Feb 18, 2010 | LG Flatron L1750S 17" LCD Monitor
My LG flatiron W1943TB turns on, says analog power saving mode, goes black and then the power button flashes.. but the monitor is hooked up to my dell notebook bc my LCD died
Hi erin mckinle,
That is probably it's, uh, analog power saving mode. When the screen goes black and the power button flashes, make some mouse gestures or hit some keys that would not affect anything (try spacebar). That should bring up the screen. If you think it goes into power saving mode too fast, go to Control Panel --> Power Options, and change the values. Hope this helps.
Jan 02, 2010 | LG W1934S-BN 19" Monitor
Analog power saving mode?...
I have a LG flatron wide keeps saying Analog power saving mode and than powers off how do I reset this?
May 13, 2009 | LG 22" FLATRON LCD Monitor
New LG 2452T keeps going to digital power saving mode
i had the same problem.
connect the monitor with the analog cable and shut down your pc.
while it is off unplag the analog cable and place the digital one(dvi).
this should fix your problem m8 ;)
Feb 28, 2009 | LG Flatron L2320A 23" LCD Monitor
"analog power save mode"
different monitors have different settings. Anyhow, press the menu button on your monitor (hope it is there otherwise some other button must have been assigned this function). Choose recall or auto adjust or factory default from there (whichever of these options you can see). Nothing serious.....
Sep 09, 2007 | LG Flatron L1750S 17" LCD Monitor
Lg monitor won't come on
Try connecting the LG monitor to the VGA port on the HP tablet instead on the docking station.
Aug 06, 2007 | LG L1920P 19" LCD Monitor
LG Flatron L1750S 17" LCD Monitor Logo
8,987 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
