Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
Bridge mode How can i set the westell versalink 327 into bridge mode?
    President:
  • 1,902 Answers
Reset your modem.
There is a reset button on the back.
Push it in and hold it down for thirty seconds with the modem on.
Log into the modem at 192.168.1.1 (admin/password=username/password)
You will need to change the modems administration username/password, doesn't matter what to since we'll make it unreachable soon enough.
On the connection overview page goto configuration.
Go to DHCP configuration and switch the DHCP server off.
Then goto configuration and click on VC configuration.
All but the first VC should be disabled.
Click on the edit or configure button next to the first and enabled VC.
Switch from either DHCP or PPPoE to Bridge.
At the bottom of the screen click on set VC.
Done.
Your modem is now in 'full bridge' mode and will need to be reset again to get it out.
Posted on Feb 05, 2009
How to Disable ap isolation on westell 327w
Follow these four page guide to changing your 327W to bridge mode. This should solve your problem.
Changing your VersaLink 327W gateway to Bridge Mode High Speed Internet...
Dec 25, 2014 | Computers & Internet
Wifi
connect router to pc with network cable and enter in your browser the ip adres
you wil see setup from router
go to wirles part and select enable save settings and try to connect again with the wifi
Oct 17, 2009 | Westell Wirespeed VersaLink...
Forgot username and password how do I fix this westell 327
Did you forget the user name and password for accessing the Web Utility of the router? If yes, you need to reset the router back to it's factory state. There's no other way but to reset it and then reconfigure the router. Set a new user name and password.
Regards,
Firesnake09
Aug 15, 2009 | Westell Wirespeed VersaLink...
Verizon DSL Internet connection intermittant Westell 327
verizon dsl westell 7500 internet light goes off 2 to 3 times daily
Jul 11, 2009 | Westell Wirespeed VersaLink...
Westell 327 modem is listed on itouch; itouch asks for password
lock on the botom of the router it might be locking for the WEP password on the label
Jan 04, 2009 | Westell Wirespeed VersaLink...
Hi I can only use the Westell 327W with DSL
This Westell 327W can only be use with a DSL internet connection since this is a DSL modem..
Hope that helps.........
Sep 19, 2008 | Westell Wirespeed VersaLink...
Westell Versalink, model 327W
if you are using the USB port of the modem, you should be able to see your modem while you are online, but if you are connect through ETHeRNET, you wont be able to see the modem on your device manager.
here is a USB port
and here is an ethernet port
Aug 12, 2008 | Westell Wirespeed VersaLink...
Westell versalink 327w i need default password
If the 327 was never set up for wireless you need to connect to it with an Ethernet cable and plug that into your Mac and one of the RJ45 ports on the back of the 327. Type http://192.168.1.1 into your browser, this should take you to the Westell Home Page (Your Router). The default for wireless in this router is disable. There are tabs across the top on the page, select Configuration>Wireless>Basic. This opens the Wireless Operation Window. If Wireless is disabled, click arrow to enable. You can also enable and disable encryption in this same window and if you choose to use the basic WEP in the device, the WEP key is on the label on the bottom of the router. If all this is good your laptop should be able to detect the wireless connection, the default is the serial number on the bottom of the router so you will know which connection is yours. REMEMBER TO CLICK SAVE before exiting the window! Hope this helps.
May 21, 2008 | Westell Wirespeed VersaLink...
Cannot connect using westel 327 from verizion --lights blinking(dsl)
If they are charging you for the use of the westel, just tell them you don't need it. I would keep using your other modem that works.
Jan 28, 2008 | Westell Wirespeed VersaLink...
Default Password
the default password for your westell 327 is username: admin and password: password, the admin admin combination is what usually isp providers such as verizon tells you to put in after configuring it for the first time. 192.168.1.1 is the url add for you to be able to access your westell 327. after accessing your modem you can find the WEP key below the modem, after enabling the security of your network the WEP kep is your default security password
Dec 12, 2007 | Westell Wirespeed VersaLink...
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
1,086 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
