Question about Kenmore 23822 Top Load Washer
Kenmore model number 82870120
I was washing my thrid load of laundry and on the last load it quit spinning. The washer is ten-fifteen years but never had a problem.
    Problem Solver:
  • 18 Answers
Put the machine on spin and turn on. If you hear the motor it is a part called a coupler if it is completely dead it is the lid switch. to gain access into this machine look for 2 phillips head screwson the lower front or back side of the control panel. some models have plastic covers that pop off on each side covering these screws. after removing these the control panel flips up and you will see 2 brass clips on each side that you will pop of with a flathead screwdriver. now unplug the lid switch wires and the entire shell of the machine will lift off. now you have easy access to the lid switch and down at the bottom you will see the pump for the washer. remove the 2 metal clips and the pump slides off. check it as they are prone to leaking. now you will see 2 more clips securing the motor some also have screws in the clips but anyway remove these and the motor slides out. the coupler consists of two plastic hubs with 3 prongs sticking out one on the motor and one on the transmission with a rubber disk connecting the 2 together. this part has been redesigned 4 times the latest one has teardrop shaped prongs and a metal sleeve insert where they attach to the motor and tranny
Posted on Jan 31, 2009
I have a Kenmore 70 series Washing machine top load model 110 serial number 82870120 . where is the lint trap located and how to take out to clean? clothes have a lot of lint after being washed.
It is likely that a tissue or paper product was included with the wash load. The series 70 does not have a lint trap. At the hose connection to the house drain lint has been known to build up restricting the emptying. This buildup would not introduce lint into the washer.
If the water temperature is very very cold and you use powder detergent it will not dissolve completely into the water and will leave a white residue on the fabrics.
Try running a short load in the washer allowing for ample water to rinse out the machine before the next wash load.
Dec 28, 2015 | Kenmore series 70 80 90 Washer timer...
What cu. ft washer in a model 110-82870120 top load kenmore washer.
you can find out by measuring the depth of the tub in inches. Measure the diameter of the tub at the opening where you put the clothes in. Multiply those 2 numbers. Then divide the figure by 144 which is a cubic foot in inches. That will Give you the cubic feet.
Example Depth of 23 inches and diameter of 21 inches. 23X21= 483/144 = 3.35 cu. ft.
Jan 16, 2011 | Kenmore 24032\24036 Top Load Washer
I have Kenmore ELite HE5t Model 110. I keep getting an "F35" code and washer does nothing....even pushing the "Stop" button doesn't work..door will not unlock...I have to turn off breaker to open door.
Hi, we also got the SUDS error followed by F35 many times. I replaced the analog water level switch, Wirlpool part number W10156252, and the problem went away. The part is located against the back right corner of the top of the washer after removing the top cover. The part cost $62.99 + $12.95 express shipping from ApplianceZone.net. I have the Kenmore HE3t Steam Washer, model number 110.46752 700 front loader. I was able to run about 6 loads of laundry by unplugging the washer, waiting about 5 minutes, the re-plugging and re-starting the washer. Thereafter, the problem became permanent. I always used HE detergent. The washer was purchased new in December 2007, and the I made the repair in September 2009. I spent about $1300 for the Kenmore H3t Steam Washer, and I am disappointed that it required repair after less than 2 years. My mothers old Maytag washer lasted more than 15 years, and was not susceptible to soap SUDS.
Oct 05, 2010 | Kenmore Elite HE5t Washer
Kenmore 20422 leaves water and clothes soaked after spin cycle
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
Initial thoughts point to one of two places.
1. It's possible that your pump and/or hoses are clogged.
2. It is also possible that the "Motor coupler" between the motor and transmission is worn and cannot provide full power to the tub when agitating.
See the following illustrated descriptions of how to access the pump and motor coupler.
If either is bad or worn, they aren't all that expensive.
I doubt that the problem is the motor since the machine will agitate and spin.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=134&osCsid=1c39a06ff50bcc5c8439ed37e02f402a
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
Jan 06, 2010 | Kenmore 22422 Top Load Washer
Burning smell at end of wash
could be the belts but it could also be the motor depending on the smell
Jun 04, 2009 | Kenmore 22622 Top Load Washer
Kenmore 80 Series - machine won't rinse or spin
Manually move the timer to the SPIN mode and turn it on.
If nothing happens, replace the lid switch.
With a model number I could be more specific.
Feb 27, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer humms and smells horrible....
You have a bad motor. ( very common) If you take your model number to a local used parts store you may be able to find a good used motor for cheap. If no luck finding a used one, Order it from sears. (the motor is deffinately your problem, I replace them all the time.)
Nov 13, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series heavy duty super capacity washer-new in 2002
HI colleen. thanks for the question. i know that you have been doing laundry for 30 yrs. i have been repairing for 45 years. they did not have daugs then. so the problem was not there. yes overloading is the cause . but if it wont go into the spin cycle . that could be the lid switch.
Oct 07, 2008 | Washing Machines
Kenmore elite washer top loading 6 years old clothes still wet after spin cylce
Click on 'washing machines', then brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line. Possible your filter is clogged after these years.
And dont forget to rate me on this great site.
Jan 21, 2008 | Washing Machines
Kenmore 94802 - Goes through all cycles.. Doesn't stop after last spin cycle.
I hate to say it, but it sure sounds like a timer problem. There are contacts inside that move and switch items no matter what setting its in. Its a possibilty that the power contact is stuck closed and when you manually turn it off it breaks contact. The job to replace is really not that hard, remove console (unplug unit first), mark your wires, then just replace. The part though is a touch expensive (131789200 Sears Part Number). Probably would be a little cheaper than buying a new unit I guess. Let me know if you need any further information. Jim
Nov 04, 2007 | Kenmore 94802 Front Load Stacked Washer /...
Kenmore 23822 Top Load Washer Logo
159 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
