Question about Intel D946GZTS Motherboard
No internet connection
I suddenly got disconnected from the internet. What will I do?
  • jollica13 Jan 31, 2009
    Thank you so much jaranya8! Great help.
  • 238 Answers
You can repair it by going to start menu, Control Panel, Network and Internet Connections, Network Connections. Right Click the Icon Local Area Connection and then click Repair. Wait until it repairs your server connection and then click OK.
Posted on Jan 31, 2009
Suddenly stopped working ,won't restart my PC?
First of all disconnect all peropheral connected to your motherboard. Take out Your RAM and clean it with soft clothe. Reinsert ram and restart your PC. If you can get display at this point then shut down your PC connect all peripheral back and restart your PC.
If not you will need to replace your ram.
Nov 29, 2012 | Computers & Internet
Last january my d-link WBR-2310 still working fine but now i wanna use it, it wont connect in the net?
Try power cycling the router.
Disconnect the router from all computers. Power off the router. Power on the router. Reconnect the router to all computers. Check the Internet connectivity.
Mar 01, 2011 | Computers & Internet
I have ATT internet service using a USB device( no DSL or cable wires/lines, just plug in the USB into the port, that's it). I also have a wireless printer that is setup with a DLink router. When I print...
In order for you to print on that particular printer, your computer and the printer need to be on the same network. That is the only way it will work. So, either connect your computer to that Dlink router or connect your printer directly to your computer and browse internet from USB ATT.
Hope this helps.
Aug 11, 2010 | Computers & Internet
PCX2600 cable modem Comcast problems
Thanks.
If you buy the new modem, make sure that you can return it if that's not the problem. Also, explain to Comcast what the problem is and that it happens on both computers. It could be a poor connection on the cable wire that goes into your home.
I had a similar problem and my DSL and Verizon found that the squirrels found my telephone wire rather tasty and ate through most of it..thus causing the bad connection.
Good Luck,
Hank
Jul 10, 2009 | PC Chips P53G v1.0 Motherboard
Network connection disappears
Your router (or modem) probably has an electrical component overheating problem. When it gets too hot, it quits. Turn it off and let it cool before you turn it on. If it comes back on and quits after a while, you should consider better cooling for the router or replacing it.
Jun 10, 2009 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
No connection to Internet
Hi There, It sounds to me like your LAN Port is faulty, install a PCI - LAN Card install the drivers for it and test it again, that should solve your problem...
Good luck
May 16, 2009 | Acer AOpen MX 3ZA (91.88110.101)...
Problems connecting using Microsoft internet explorer 7
Hi there hey if you are using a ethernet card try this first ok.. if you go to the properties of your ethernet card and go to configure than under the speed settings make sure that it is set to auto and try press ok than the card will disconnect from the internet and reconnect try this first... than if nothing helps try the (ipconfig/ renew) command and let this reconfigure the sesttings for the internet explorer you may also want to open and remove and clean the card reinstall the card ok let me know lhow this goes for you. best regards mike
Feb 28, 2009 | Dell Computers & Internet
Do connections to the motherboard have anything to do with connectirng to the internet?
hi
i think u have not hardware problem.
go to your iexplorer tools internet option.
reset your iexplorer settings.
off your firewall .
if u have dialup connection clear your ip address auto alll give exact ipaddresss of dns server.
Mar 21, 2008 | ASUS A7N8X Motherboard
Intel D946GZTS Motherboard Logo
71 people viewed this question
Top Intel Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
