Question about HP PSC 2210 All-In-One InkJet Printer
How can I permanently alter the Default Print Settings?
I wish to alter the Default settings to use "fast draft" and "gray scale" (black cartridge only) as the default printer settings. I have been unable to save these changes to the existing/original Default setting using Properties screens/menu. Suggestions?
    President:
  • 2,976 Answers
In the control panel, you can select your printer and set defaults. You can also set them in your printer's setup & maintenance program.
Posted on Jan 31, 2009
My HP C4780 PRINTER WILL PRINT A TEST PAGE BUT NOTHING ELSE. How do I get it to print?
Check the settings in Windows Print Manager.
Make sure that the paper quality matches what is in the printer. If set to glossy, minimal ink is deposited on the page. Also, check the print quality - draft quality provides a minimal amount of ink as well.
Jan 17, 2015 | HP PS C4780 All in One InkJet Printer
How do I set my printer to automatically print in draft mode and just black ink without having to manually select these options each time I print?
Wow Pamela! You ask your question well. Good Job! Print options such as that can not be set at the printer. Changing the settings inside the application is not permanent. Follow HPs instructions here for default settings:
Changing Print Settings in Windows7
Dec 27, 2014 | HP ENVY 5530 E-ALL-IN-ONE PRINTER 1200X600...
Do I have to have a color cartridge in order to print? Can I just use a black ink cartridge?
The HP DeskJet 6122 can print with both or only one ink cartridge installed. The printer driver includes an option to print in gray scale as a substitution for color. If you choose to print a document that has a color other than black and white with only a black cartridge installed, I recommend you select the gray scale print option. To select gray scale, select the printer properties and check the box for gray scale rather than color printing. This selection can be made either at the time a document is ready to print (ie., a one time selection, using the "Properties" box in the print options window), OR as a permenant setting using the Control Panel, Printers, HP DeskJet 6122, "Properties" window. Once changed in the general printer properties, these settings remain active anytime the HP DeskJet 6122 printer is selected to print a document.
Sep 03, 2013 | HP DeskJet 6122 InkJet Printer
The priter goes through the motion as always for printing but a blank piece of paper comes out. I have cleaned the print head but It still does the same thing. Do you have any suggestions that I might...
If you are printing using a color (not "black cartridge only" ) driver, yes, the printer won't print because it uses a "process black" when you use a color driver.
In other words it creates black using the 3 colors, and doesn't actually touch the black cartridge.
You will need to change the default driver to one that you create.
go into control panel, hardware and sound, devices and printers (win7)
right click the officejet 6500 (not the fax driver) and click printer properties
click the advanced tab, and click printing defaults
click the fast economical printing template.
Change "print in gray scale" to Black Ink Only
Click "save as" and name the profile "black draft"
click the newly created "black draft" profile, and click APPLY and OK
This will now be your default, and it will print in black and white while the color cartridges are empty.
Jul 29, 2011 | HP Officejet 6500 Wireless All-in-One...
How do you print just black and not use the color cartridge
check the printer software that's installed in ur PC...
it will have the option to print in draft mode or in gray scale....
Dec 17, 2009 | HP OfficeJet 6210 All-In-One InkJet...
QUESTION FOR DON_FARR
whenever you print greyscale what actually happen is that the printer mixes the red, blue and yellow to give the output in gray scale. See if you mix red, blue and yellow ink in the right proportion it gives you very close to black. just try to print your greyscale with your black ink finished you will still get the same print quality as when the black has ink in it. Or find a way seal the nuzzle of the black in and print your greyscale. check what results.
Dec 12, 2009 | Canon PIXMA MP610 InkJet Printer
Black text Printing using Photo Black
You should be able to set the cartridge it uses when you print, as something like 'Print only black'. Fish around in the printer window when it comes up when it comes up. You may also be able to set this as a default in 'Properties' from the 'Printers' option in Windows, but then it will always try to do this, of course, which you may not want.
Jun 26, 2009 | Canon MP610 Photo All-In-One Printer
HP Deskjet, Set to Black & White; but still prints with color!
Bronze, hopefully this is a logical issue: Assuming you're on WinXP > Go to Start>Control Panels>Printers (and faxes).
Find the printer in question in the list (maybe there's only one or 2 listed) and 'Right-click' on the icon > go down to "Printing Preferences" (about second/third down the list).
In here you will be able to set the printers default settings. I'm not 100% familiar with HPs printing dialog, but there maybe a setting there for either 'Black & White' and 'Grayscale' (albeit it should be greyscale, anyway...) if you choose black and white your printing will not have any mid-tone, so if there's a choise, choose 'Grayscale'.
You can set other features here which will become the new default each time you go to print something - personally I set to 'Draft' or 'Fast Draft' mode by default, that way when I just print out rubbish, I am saving "lots" of ink and if I want something in good quality, I change it at time of printing.
Now, there are some programs and files that "remember" you last print settings, so if you've used a colour print setting previously, that file may still pring in colour, even though the new defaults are mono (black & white). So, print using the new defaults and save the file when finished. It's unlikely the case with OpenOffice, but, I don't know. We'll tackle that as we get to it.
So, if that has not cured the problem, please let me know.
**.The best way to acknowledge contribution is to rate it's relevance.**
Feb 05, 2009 | HP Deskjet 3845 InkJet Printer
Print Quality Settings
Go into your control panel
Select Set Printer Properties
Then printing preferences
Select Fast Print
Then ok all windows
This will now print is fast draft on each document.
Feb 15, 2008 | Canon PIXMA MX310 All-In-One Printer
Can this machine COPY from the Black Cartridge only.
Click Start - All programs - HP - HP Director/Solution center.
In HP Director/Solution center. Click Settings - print settings - printer settings . Click on the Colors tab. Enable the option Print in grayscale and Black print cartridge only.
This is the only way to print with single black cartridge.
Thanks
Dec 21, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP PSC 2210 All-In-One InkJet Printer Logo
205 people viewed this question
Seeker5211
Seeker5211
