Question about White Sewing 2999 Mechanical Sewing Machine
White 2999 The tension on the top is loose no matter the tension I dial it to.
  • talk2ginny
    talk2ginny May 11, 2010
    Hi - can you give me a few more details? How long have you had the machine? Does the machine have automatic tensions? What were you doing when the tension failed?
    I know this sounds silly, but sometimes all you need to do is rethread the machine - make sure your presser foot is in the raised position when you rethread.
    If you are still having the problem, please repost with details and I'll try to help.
    Thanks, Ginny
    New Friend:
  • 186 Answers
It looks like you have no tension on the bottom thread. Make sure the bobbin thread is in the tension spring, and that there is no lint under the bobbin tension spring. You may just need to increase the bobbin tension, it is one of the two small screws on the tension spring itself (not the one on the end, the one in the middle).
Try an online repair tips site to see what this all means if you need to.
Posted on Jan 31, 2009
How do you adjust the bobbin tension?
Factory standard tension for upper thread is the midway point between the high and low number. However, that tension dial is meant to be used for tweaking tension. Generally, tweaking is required whenever the type of fabric, needle, or thread are changed, ie thicker fabric like denim should have a different upper tension setting than fine chiffon. To be successful with tension settings, one must become comfortable adjusting the upper tension.
NOTE: Accurate tension is achieved when the upper thread and bobbin thread meet in the middle of the fabric.
Understanding Bobbin Tension
Jan 20, 2016 | Brother Sewing Machine - XL2600i
How do I time a White model 2999 sewing machine?
needle /hook timing is accomplished by adjusting the needle arm on the drive shaft at the head of the machine
There are pages on the net as to how it is done (all machines use the same principle )
However I would suggest that you have it checked at a sewing machine repair service shop
fortunately the timing seldom changes so there may be other problems that give you the impression of timing being out
missing stitches ( bobbin tension and bunching of thread under material (top thread tension) may give you the idea that the timing is out.
Aug 02, 2015 | Sewing Machines
Upper thread tension too loose even when I dial it up to 9
I suggest that you get in touch with http://www.janome.co.uk/index.php?option=com_chronocontact&Itemid=14 and have a chat with them ...
Mar 19, 2013 | Janome Magnolia 7330 Sewing Machine
Loose bottom stitch
try adjusting the top tension and see if that helps the bottom stitch
here is a free manual for the machine
http://www.singerco.com/uploads/download/1142_white-2999-x.pdf
Jan 28, 2013 | White Sewing 2999 Mechanical Sewing...
Brother vx1090 can't move tension dial
I suggest taking the machine to a sewing machine shop & let
the technican look at the tension & see if it needs to be replaced
Jul 30, 2012 | Brother Sewing Machines
The top stitch is perfect but underneath the material there are many loops. I am assuming this is from the bobbin. How do I correct this?
no, more likely your top tension is too loose causing the loops on the underside of your fabric, loops on top would be bobbin too loose. raise presser foot and rethread top thdead pulling thread into tension fully. set top tension dial to 5 and test sew. if still looping underneath try tightening top tension by turning dial up to 6. but usually top tension should only need minor adjustment tweeks. you can test top tension by lowering pressure foot to engage tension and holding thread just above needle thread guide, pulling thread downwards . there should be resistence on it to your pull. if you cant feel any then tension device may be faulty, and require service.
Jun 25, 2011 | Sewing Machines
My white speedylock 1600 is being difficult.. The top threads lay and look perfect.. but the bottom threads are loose.. What can I do about this?
This machine has differential feed (top tension is different from bottom and fabric feed rate can be different from bottom). turn the dials for tension and feed rates to adjust. Adjust bottom tension to tighten bottom threads and possibly speed up bottom feed rate. Tough to say without more info.
Good luck and please rate me.
From White Sewing web site.
"Are wavy fabrics making you seasick? Do puckers leave a sour taste in your mouth? Then you need differential feed. It eliminates distortion and wavy seams when serging knits, plus it prevents puckers and pulled seams on lightweight fabrics. Turn the dial again for instant gathers.
Nov 23, 2009 | White Sewing Speedylock 1600 Mechanical...
Sewing machine Brother xl-5301
When the bottom stitches are loopy it is the top tension which is wrong. I suspect that it is not threaded correctly for it to be this bad. If you have a tension dial make sure that the thread is properly between the disk. Try the top tension on 4-that is an "average" normal setting. Gradually turn it up as needed. A good way to test tension is to use 2 contrasting colours-red and white are good. You will see at a glance where the problem lies and how well you are correcting it with adjustments. You should barely see a trace of the top colour coming through. Rethread the machine top and bottom with 2 colours-set dial to no 4 and go from there.
Jun 13, 2009 | Brother XL-2600
L-344 loose stiching
You need to do a tension assembly test. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Tension assembly test. To do this test. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.)
If it doesn’t work this way then you probably have a piece of thread or lint stuck inside the tension discs. To remove it, turn the tension to 0 zero and raise the presser foot.Using a small screwdriver, open the space between the discs and spray with canned or compressed air. The stuff should come out. Do the tension test again to make sure you got everything and then try sewing again.
sewman7
Dec 22, 2008 | Janome L-344 Mechanical Sewing Machine
White Sewing 2999 Mechanical Sewing Machine Logo
166 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
