Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Blower inner turbine broken.
Looking to purchase a replacement, can somebody help
    Sergeant:
    Champion:
  • 373 Answers
Did you try coleman.com site
Posted on Jan 31, 2009
How do I get a new belt to repace a broken one in a DC23 turbine head
Hi there, it's Jack at Dyson.
The Turbine head's belt is not a part we would ask a customer to fit, and therefore it's not available as an individual component. It's part of the turbine drive mechanism, and we'd advise against attempting to dismantle this as it could result in damage to the Turbine head. If the Turbine head happened to fail within the Dyson warranty period we should normally be able to replace it, as long as it's been used and maintained according to the User guide. Out of warranty, a replacement Turbine head could be chargeable.
If you'd like some additional help or advice from our experts you're welcome to contact us directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Oct 07, 2014 | Dyson DC23 Turbinehead Canister Vacuum...
BLOWER WHEEL BROKEN
In your instruction manual you should find a parts list, purchase a new blower wheel and install it. If it is an older unit it may be best to just replace it.
Feb 12, 2014 | Frigidaire Dehumidifiers
Blower motor resistor replacement 1999 chevrolet silverado
posible fan moter bearing or sometimes a foren object falls into the the housing
Nov 29, 2011 | 1999 Chevrolet Silverado 1500
I have Whirlpool portable air conditioner ACP122GPW. The upper wheel blower (condenser) was broken and I am looking for its part number in order to purchase new one. Could you lease help, thank you. Repair...
I am also looking for an "upper Blower wheel' for my Whirlpool portable Air Conditioner and have not been able to find one. The model # is: ACP122GPW. I've looked all over town, even ordered one, and it was too small. I believe the part # is: 09040193. Can you help?
Sep 05, 2011 | Whirlpool ACP102PS Portable Air...
Super super loud vibrating noise loud as race car 110 db i took apart and saw that the screws in the plastic housing surrounding the blower motor had fell out (all of them x4). because of that the...
yes the turbine blades are spinning very fast if the out of ballance this is whats making all the noise it will also shake its self to bits very soon change the turbine fan
Nov 28, 2010 | EuroTech EDC158 Electric Dryer
Hi i am unable see my screen. It looking white
Sounds like you have a broken LCD screen. Somebody needs to open your blackberry to replace it. Go to your provider, they might replace the phone for you. If they refuse and If you want somebody else to do it for you go to Blackberry Repair. If you want to do it yourself, here is a Blackberry curve Repair Guide that shows how.
Jun 13, 2010 | RIM BlackBerry 8700g Smartphone
I'm in the USA and looking for a Dyson DC-11 power head replacement. Any ideas?
Hi its Darran at Dyson.
A replacement turbine head can be purchased online direct from Dyson at www.dyson.com/store. The part costs $95.99.
I hope that this information is useful to you.
Kind regards
Darran
Dyson Customer Service
Mar 17, 2010 | Dyson DC11 All Floors Bagless Canister...
Brushes are not spinning. think the belt is off or broken. how do i access the belt?
There is no belt in this machine. The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine will have to be replaced and they are expensive. Unfortunately, replacing the turbine and not a lasting solution. It will do it again and again. It is designed poorly.
Dec 03, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac, brushes won't rotate, have cleaned filter by brushes, removed brushes and they rotate okay when off steam vac, tried to ajust level for carpet cleaning and brushes still don't move
Check to see if the shaft on the brush block hasn't broken off. Otherwise it is the turbine that drives the brushes and is either clogged up inside or needs to be replaced.
Jun 07, 2008 | Vacuums
Brushes not rotating on hoover f7425-900 steamvac v2
I had the same problem and it was inside the turbine assembly. If you take the turbine assembly off the machine and open it up, you will see the turbine blades on one side and the reduction gears on the other side. The problem on mine was a needle bearing sandwiched between two washers on the reduction gear side. This bearing/washer stack is the stabilizer for the turbine gear shaft. Mine was rusted solid. I removed the washers and bearing and cleaned them up with a wire wheel being careful not to lose any of the tiny needles. Once evrything was rust-free, I reset the needles with grease and sandwiched the bearing between the washers. I then reinstalled this stack back in the case along with the other gears, regreased everything, and buttoned it up. Brushes are spinning better than they have in a long time.
Mar 02, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Heating & Cooling Logo
19 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
