Question about Mintek MDP-1815 Portable DVD Player
Says no disk
How do I get my player to stop saying no disk and play movies again?
  • berean58 Jan 31, 2009
    Sounds like there are so many problems with Mintek that there could be a law suit in the works if there are no answers .
    President:
  • 814 Answers
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Posted on May 29, 2009
    Scholar:
    New Friend:
  • 70 Answers
Berean,
Does you player doesn't read any disc at all or it only choose disc to play?
if it doesn't playing any disc and keeps saying "no disk" most probably you have problem with either your optic lens ( optic drive lens that gather data from disk) or spindle motor ( drive the turn table where you put your disc).
but first try to clean your optic lens using a smooth cotton buds. gently wipe the optic lens of your portable player in a circular way.
note: do not apply any liquid to the cottons buds for it may cause moisture or blurry effect on the lens.
cheers,
mark
Posted on Jan 31, 2009
4 Suggested Answers
SOURCE: portable dvd doesnt play movies
Try cleaning the lasers lens with an anti static cleaning wipe. I used " nice'n clean" that I had purchased from Walmart to clean my laptop screen. My dvd player started back playing after gently wiping the laser lens.
Posted on Apr 21, 2007
  • 4102 Answers
SOURCE: Bad disk
if this disk plays on other sources then it is not the disk and sounds like it is a problem with the laser or the motor that pushes the laser along the disk if it dont play no disk at all then it is the layser if you have used a good quality lense cleaner and that didnt cure it then you could try if you are ok taking the case off leave it for 24 hours to make sure no electric is running through it and look where the laser eye is it should be neer the middle where the center of the cd sits if it isnt gently push it back to the middle this will recalibrate your laser then put it back together and try again if this dont work you will then have to get a replacement laser unit these can be expensive but you should be able to fit it your self as the wire areconected by conector but before you do this make sure you use a good lense cleaner as the cheaper ones wont work all the time and listen if the cd is spinning in the unit if its not spinning then you need replace the unit if you dont feel up to it then a repair shop will do this for you their si no way round it other than to replaceit they usually last the life of the warranty they are made to last no longer hope this is some help but not much more you can do
Posted on Oct 30, 2007
  • 103 Answers
SOURCE: apex AD-1100W dvd/cd/mp3 player quit playing movies
hi,
Does it happen for all dvd disc or some particular dvd disc. If it is with some particular disc then clean the dvd and try them. If the problem exist for all the dvd then try to clean the lens by dvd lens cleaner and try to play. dvd lens cleaner will be available in dvd stores.
Thanks,
Posted on May 23, 2009
My dvd player keeps saying 'incorrect disk' why? and what can i do to stop it?
I don't understand your problem.
Is it the TV or is it the DVD? You say you tried other dvds and the problem is still there. Looks like the TV is the problem. Sometimes it's hard to help people when they only mention on screen issues. How can first DVD say 'incorrect disk' and then another dvd, and another still say 'incorrect disk'? It just doesn't seem to make sense. Is the contents on the disk a computer recorded movie, film or home movie? If so, you have to record the film on the disk with a format that accept the DVD. Could the DVD be a Blu-Ray, can it play a number of video formats, DVD, DivX, KviD DVD, etc.? Try first with a purchased movie DVD disc, if it doesn't work, then the DVD is faulty. DVD players these days are meant to play a wide range of video format, including CD discs. If you have an old DVD player, you may not play latest discs. But if the DVD is incorporated with the TV, then you have to insert a new movie and see if it plays. Go to an appliance or TV DVD store and talk to them. Or you can purchase a new movie and insert it in. If it doesn't work, you can always return it. As you said, you've tried different DVDs, sounds like it is a separate DVD player. If so, try other movie discs. I get the same warning only when I insert discs with movies I recorded on my computer, such as Pinnacle video editor.
Dec 27, 2014 | Digihome LCD TV
When I put a dvd in it wont play and before it would
If it say not supported, It may mean the dvd disk is dirty. Sometime invisible hand oil evaporated on the disk. You rinse the disk off hot tap water and block off the water drops and try all the disks again.
Feb 09, 2012 | Disney Cars Ramone DVD Player
My Blu ray player randomly stops playing movies but all other setting work
Have you made sure the disks are clean and have no marring on them? Blue Ray players are very sensitive to any disk issues. Also have you checked to see if any updated Firmware (the software the system uses to read the movies) has been released for the player? They constantly update the operating software of players and the way the disks are recorded, so regular updating is essential to prevent this type of problem in playback, freeze up is the most common complaint.
Feb 07, 2012 | Televison & Video
I have a Zenith I played a dvd an it worked fine - put another movie in the dvd player and was going to watch that one and it never read - screen kept saying 'reading'. I tried another dvd and the...
try using a CD cleaner disk..
How old is the system?
DO CDs work when you try them?
Put a disk in... remembering the position it was in..
Then try to play the disk...
Eject if it does not play and look to see if it has moved to a different position...
If not, there is a motor problem or the laser is not sensing the disk being there.
Have you ever opened up the main box of the system?
Has anyone else been inside it?
If yes, then maybe it is time to do it again to observe if there is movement of the laser pickup..
Jun 01, 2011 | Zenith XBS444 250watt DVD/VHS 6-Speaker...
DVD Player Not loading Movies
optical sensor is burned out or the spindle is not spinning the disk to read it.
Nov 06, 2009 | Coby DVD-224 DVD Player
Insignia IS-PD04922 Poratble DVD Player 2005
take a cotton swab with some alchohol on it and clean the lens, let it dry and try again.
Jun 09, 2008 | Insignia I-PD720 Portable DVD Player
Pioneer muti-disk dv-c503 dvd/cd player carousel wont saty open
When i put a cd into the tray the door will close. It will say its loading but then the cd tray will reopen again not allowing the cd to play.
Nov 26, 2007 | Pioneer DV-C503 Multi-disc DVD Player
Dvds dont work
have you tried a cleaning disk and make sure the movie disks have no finger prints on them that will stop it from loading.
Nov 24, 2007 | Durabrand PDV-705 Portable DVD Player
Reads all but DVD-Help PLEASE
When you say it won?t read are you trying to play commercial DVD movies or read DVD data disks? If you're trying to play movies then you need a couple of things the first being some type of player program. Real player works as does Windows media player but usually DVD drives come with a striped down version of PowerDVD or WinDVD. If you in fact have a player installed and when a DVD is inserted in your drive it doesn't play it may not be configured to automatically play DVDs. Try opening your player program and trying to manually play your DVD. Let us know if you have any success or if you need more assisted. If you do let us know what player program and operating system you have and any error messages that may appear.
Jan 01, 2007 | LG GCC 4320B CD-RW/DVD-ROM Burner
INSIGNIA IS-PD040922
The laser has become damaged/worn-out. There is no fix for it as replacement parts are not made for it.
Nov 27, 2006 | Insignia IS-PDO40922 Portable DVD Player
Mintek MDP-1815 Portable DVD Player Logo
355 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Jason Morris
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
