Question about Brother P-touch QL-550 Thermal Label Printer
Printer Driver compatibility with Vista??
OS is Vista Home Premium (32 bit). I have the 4.2 version disk of software for this P-touch editor/addressbook. When intalling error occurs saying "Set up information is not compatible with the OS being used". I can click ok..and instal continues. But when I open Editor another error says "Driver is damaged. Reinstall Driver". Is it that version 4.2 is not vista compatible? How do I overcome this in lay-mens terms (cause im not very IT savy)....Thanks in advance.
  • 1 more comment
  • ferrel486 Jan 31, 2009
    Thanks... I have downloaded this driver several times with no luck... same errors occur. Any other advice?
  • ferrel486 Feb 01, 2009
    Many thanks... that seems to have resolved the driver issue... But it still wont print...(groan!)... There are no error messages in P-touch editor (which is why I think the driver is now compatible), but when I try to print a label the machine only prints on about 1cm of the label (and overtypes continuously) in this small spot. Print preview is showing correct layout, margins are fine... label size all correct... etc etc... I cant work it out..... BOY it should not be this hard to install a simple little label machine. Your help is REALLY appreciated!! Cheers.
  • Anonymous Mar 12, 2014
    downloaded new software onto new mac.
    error essage: Err_AirPrintSetDefault can't open p-touch editor.
    thanks for help
  • 257 Answers
Hi, You need to download the vista driver. Can be found on Brothers site or windows site. Here is the windows direct site link :
http://www.microsoft.com/windows/compatibility/Details.aspx?type=Hardware&p=Brother%20QL-550&v=Brother&uid=&pf=0&pi=3&c=printers%20%26%20scanners&sc=other%20printers&os=32-bit
Copy and paste and Good Luck!
Posted on Jan 31, 2009
  • Jim London
    Jim London Jan 31, 2009
    Hi, It sounds like you haven't removed the old versions and vista is looking at them first. You need to go to the add/remove section in the control panel and remove any printer drivers, then go to the system section under hardware devices and completely remove the drivers for the brother printer.( Under devices look for printers find the brother printer rt click on properties and tab on drivers and use the remove button) DO NOT try to use the disk. Unplug the printer and reboot the computer. Now install the downloaded software and record the driver number. Follow any instructions. When or if you are instructed to plug in the printer watch for the driver number and make sure it is the same so that vista is using the downloaded version instead of one of the builtins. If it doesn't tell you to plug it in go ahead and watch the screen for the found new hardware. Good Luck!
  • Jim London
    Jim London Feb 01, 2009
    Hi again, Ok getting there! Sounds now like the data is in raw mode. Try putting in your disk without installing or if it gives you the option to browse the disk see if there is a setup mode that will install the program without installing the drivers. If not, you can install the disk and if it sees your driver and asks which one you want to keep you know because you wrote it down earlier. Vista may install the program and not the driver , worst case is you would have to remove it and try again. Don't you just love long distance troubleshooting! Good Luck!
I have the photo printer for 4 years, just installed it with original ink cartridges, the printer prints regular text just fine, but in trying to print photos, the photos come out very red with no...
HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Oct 28, 2010 | HP Photosmart 8450 InkJet Printer
LJ 3050 printer is printing very slow.
TRY HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Oct 27, 2010 | HP LaserJet 3050 Printer
My printer will not print black ink i just changed 3 cartridges
Oct 27, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
My D7160 cuts the bottom part off of every photo. How do I fix this?
Oct 27, 2010 | HP Photosmart D7160 InkJet Printer
Black lines on scans and prints HP 2727nf
Oct 27, 2010 | HP Laserjet M2727nf Multifunction Printer
Will not print. Have to power off and then power back on for printer to start.
Oct 27, 2010 | HP LaserJet P2015dn Printer
Trying to install my epson stylus cx3200 to my HP desktop computer. It's not one of the listed models. I need a name of model that is compatible with epson stylus cx3200.
If I knew what software you have, I would have had instruction for your too
Go to the web site below and download and install
Twain Driver ver 3.04 for Vista and the Printer Driver version 6.5 or 5.5 for Vista
The Twain Driver ver 3.04is number 5 down the list for both 32-bit and 64-bit Vista
If your computer is 64 bit, and that is what I thought your computer was, because you have home premium. Then you need number 4 down the list. It be number 5 if you have 32-bit Vista.
The printer driver version 6.5 is number 4 down the list
www.epson.com/cgi-bin/Store/.../supDetail.jsp?oid
When you go to that web site you'll see a tab Support and Driver-select tab
Next select All in One-view all
and then a meun will display and select your printer model and just follow the steps To the file to download above.
Oct 01, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Canon MP500 all in one printer is not compatible with Windows Vista. Is there a solution for this problem, or do I need to buy a different printer?
My Canon PIXMA MP500, purchased in mid-2006, came with the (then) ScanSoft OmniPage SE2 software on a CD. The PC had WinXP Installed. I had no use for the ScanSoft it so I made no effort to install it.
Fast Forward:
Two PC crashes later, July 2009. Using Win Vista Home Premium
LOST, important WinWord document file, only a hard copy available.
I tried to recover, scanning the "Xerox" copy. The SE Version of OmniPage was very complicated but I succeeded in producing a replacement *.doc file.
It appears that newer editions of WinVista contain the right printer drivers for this Canon Model.
Apr 26, 2009 | Canon Pixma MP500 All-In-One InkJet...
Software incompatibility on my acer aspire6930-6455
Well, we wont know until you try. In my opinion, your 32/64 bit issues will be solved, but you would still have the normal vista/xp compatibility issues.
But that is to be expected, like when we all upgraded from win98 to XP.
So - I would recommend downgrading to Vista 32 bit, or getting the 64bit software version of the programs you want to use.
Good Luck, and let me know what you did, and how it turned out! :)
Jan 07, 2009 | Acer Aspire AS6930-6455 16" Notebook PC
Brother P-touch QL-550 Thermal Label Printer Logo
796 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
