Latitude d505 not charging
Plug in to charge and get the green lamp for a couple seconds. Then it flashes orange and battery will not hold a charge. Is my laptop dying ?? i have laptop it is not chargin Latitude d505 not charging
  • peeface
    peeface May 11, 2010
    i think the battery is no good. i have had a latitude d800 for a few years now and it has always been like that. i just leave it plugged in all the time and it has always been fine. try taking the battery out and pressing the button to check the power left in it. i think if it blinks weird it is no good
  • 3,940 Answers
If the system runs using the AC adapter, but the battery doesn't hold a charge and the battery indicator LED flashes orange, then replace the battery (A battery with an internal failure may flash 4 times orange then once green and repeat)
The normal lifespan of a PC battery is 300 to 500 recharge/discharge cycles (roughly 12 to 18 months)
Posted on Jan 31, 2009
Why does my dell mp1800 power and lamp flash orange
the battery needs charging. it is charging when it is solid orange and green when it is fully charged
Aug 22, 2014 | Dell 3.8 GHz Second Processor for...
Battery light flashes green 5 times, then changes to orange.
The flashing green indicator is telling you (and the notebook) that the battery is almost fully charged, but then by switching immediately to flashing orange, the status has changed to "battery charge is low". This is not normal behaviour and probably indicates a serious issue with the battery. My guess is that the charging is initiating some kind of rapid battery self-discharge.
Ref - Knowledge Base
Notebooks will power up and work without a battery just fine.
Ref - Laptop Battery Basics dummies
Try to operate yours this way. This will eliminate the battery from the loop as a potential cause of the BSODs you are seeing.
Jan 09, 2018 | Dell Latitude D610 Notebook
The battery light on my Dell d505 keeping blinking red & green and will not connect to the internet...is that a battery problem or something else...i have plugged it into the wall and still does not...
I believe that means a low or potentially bad battery. Furthermore a bad battery will not hold charge hence the re-occurring issue when plugged to the wall. See if you notice any difference when the battery is removed and you are just plugged into the wall. I was able to find a battery replacement site below.
http://www.batterycentury.com/dell-latitude-d505-battery-p-19435.html
May 08, 2011 | Computers & Internet
Orange light just began flashing on my Dell inspiron 5100...everything else is fine! What's happening?
The battery is less than 100% charged; if it were fully-charged, the lamp would be green.
If it is "flashing", it's probably less than 10% charged.
Recharge it.
Jan 13, 2010 | Dell Latitude D600 Notebook
I am seeing the charge light flash orange quickly 4 times, followed 1 longer green light flash. This happens regardless of whether I have it plugged in or not. What does that mean?
This means your battery charge is critically low. It's also a sign that your battery is no longer holding a significant charge and is a good time to replace the battery.
Nov 25, 2009 | Dell Latitude D430N Notebook
Dell latitude D600 battery charge light flashing
Go to support.dell.com and download the latest bios firmware to update it. If it still does not work then most likely it is already a hardware issue so you need to contact dell support for the hardware issue.
Jun 03, 2009 | Dell Latitude D600 Notebook
it means your battery is damaged. avoid using battery while using charger in your house. remove battery to be safe. battery is for outside or for travel only.
May 29, 2009 | Dell Latitude D600 Notebook
Your laptop isn't dying....it just means the battery is shot and it's time to get a new one...the laptop should be fine with a new battery. I recommend Ebatts.com if your going to order one online.
Jan 20, 2009 | Dell Latitude D505 Notebook
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 09, 2008 | Dell Inspiron E1705 Notebook
Dell Latitude C610 battery claims its too hot to charge....
The charge light flashing orange-orange-orange-green....-orange-orange-orange-green.... usually means the battery has reached the end of its life and now it needs replacing.
There are three ways to test your battery:
1) If the battery has a button on the bottom of it and a row of 5 leds, then push AND HOLD the button for 5 seconds. The LEDs should all turn OFF, then turn back on showing a pattern. If all five LEDs turn on, the battery is dead.
2) Open the Dell Quickset application (doubleclick it in system tray), go to Battery Meter, go to the battery health tab, and pick your battery. It should tell you there if the battery is healthy or not.
3) Reboot your computer and go into the bios. Pick the Battery tab in the bios. It will list the battery health there.
Jan 20, 2008 | Computers & Internet
Computers & Internet Logo
466 people viewed this question
David Payne
David Payne
