Question about Motorola Mobility RAZR V3
No sound coming in
Out of the blue, my Razor has stopped transmitting sound TO me... in other words, I can BE heard by the person at the other end, but I cannot hear them at all, nor can I hear the phone ring/connect to the caller!
Any suggestions beyond "taking the battery out and putting it back in" would be appreciated!
Mp 3 ring tone not install in moto razr v3
and moto razr v3 flashing idea
Posted on Jan 31, 2009
My 2hp Panasonic is blinking when turn on and the compressor stop working while the outdoor fan will be blowing cool air.
1. Turn power on.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit. The power LED lights up. If no abnormality is
stored in the memory, three beeps sound will be
heard.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard.
Jan 26, 2016 | Panasonic Heating & Cooling
My Panasonic split air conditioner has stopped cooling - model:CU-W18DKR. The internal unit and internal fan operate normally. The external unit fan does not run like normal and no compressor sounds f
Sounds like a faulty outdoor controller board. If you are in Australia, call Prime Electronics or Statewide Appliances for spares.
Part number: NPCWA743383
• To make a diagnosis
1. Timer LED start to blink and the unit automatically stops the operation.
2. Press the CHECK button on the remote controller continuously for 5 seconds.
4. Press the "TIMER" or button on the remote controller. The code "H00" (no abnormality) will be displayed and signal will be transmitted to the main unit.
5. Every press of the button (up or down) will increase abnormality numbers and transmit abnormality code signal to the main unit.
6. When the latest abnormality code on the main unit and code transmitted from the remote controller are matched, power LED will light up for 30 seconds and a beep sound (continuously for 4 seconds) will be heard. If no codes are matched, power LED will light up for 0.5 seconds and no sound will be heard.
7. The breakdown diagnosis mode will be canceled by pressing the CHECK button continuously for 5 seconds or without any operation the remote control for 30 seconds.
8. The LED will be off if the unit is turned off or the RESET button on the main unit is pressed.
Or better yet, get a tech to check first.
Feb 10, 2015 | Panasonic Single Split System - Wall...
Where do I find the model number
The words "red and blue lights", "paired", "connect" and "beeps" make me believe that your headphones are Bluetooth-enabled. However, I never heard of a TV that is Bluetooth-enabled. Therefore, I do not think that you will be able to pair, nor connect your headphones to your TV. If you want to listen to your TV wirelessly, you will have to use regular (not Bluetooth) wireless headphones, which consist of two pieces: the headphones and a transmitter that connects to the audio output(s) of your TV and transmits the sound from your TV to the headphones wirelessly.
Dec 06, 2014 | iHip Audio Players & Recorders
I got a cobra 29classic cb, little hours. i have
Set the squelch and knob to full counter-clockwise position. Turn the volume up to the 1/2 way point. Disconnect the external speaker plug from the jack. Disconnect any PA speaker plug from jack. Static / voices should be heard from internal speaker. If not disconnect the mic. Static / voices should be heard. If not, tune a different channel, sound should be heard. if not, look for indication of the radio stuck in transmit mode. If in transmit, there will be no sound until you can stop transmitting (hopefully while connected to a 50 ohm dummy load or suitable antenna - otherwise the final transistors may be blown). Reconnect accessories to determine problem component.
Mar 12, 2010 | Radio Communications
User hears faint static while on a call. It's not load enough to make it hard to hear the caller, but a noticable crackling/static noise can be heard in the background. happens on every call.
Cell phones transmit the sound as digital data. The data when converted back to analog to listen too CAN have "digitizing noise" which will sound like static.
WORSENING the problem is if there is noise in the background of the person sending the voice and the worst possiblle is to have MUSIC in the background. These both drive the CODEC (the analog conversion system) crazy and will create what you describe. The CODEC is designed to transmit ONLY voice.
Oct 23, 2009 | Motorola Mobility Moto Q
I can recieve but i cannot transmit
sounds like you might have a bad voltage regulator
Apr 03, 2008 | Uniden Bearcat Pro PC68LTW 40-Channels...
Washing machine - knocking sound at end of cycles
Hi there is it a top loader or front? If a front loading machine it might be the concrete block has come loose under the top cover.
Thanks J
Feb 26, 2008 | Whirlpool LSB6200KQ Top Load Washer
Can't hear person talking on razor
remove the batery with out turn it off that may restore the default settings
Dec 29, 2007 | Motorola Mobility RAZR V3
No sound when calls come in
because the speaker in your phone is faulty so you have to replace it
Dec 20, 2007 | Nokia N70 Cellular Phone
Bluetooth has stopped transmitting
Make sure your version of bluetooth for the hand held device and the listening device is not an old version. The first generation of blue tooth was able to transmit sound (for phone calls), but not able to transmit stero sound or mp3.
Sorry I couldn't be more helpful... :)
Dec 11, 2007 | RIM BlackBerry 7100G Smartphone
Motorola Mobility RAZR V3 Logo
248 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
