Question about Acer Aspire 5520-5908 Notebook
A hard disk problem is preventing windows from starting.
I turn my computer on and it goes to the Acer screen. Then it turns black with the little underscore thing at the top left. It blinks for a long time but it's supposed to go away but it doesn't. Then it shows the thing that says solve problems or start windows but it dont work. Then i do the check on the computer and it says a hard disk problem is preventing windows from starting please contact your administrator or somthing like that. It is Acer Aspire 5520-5912.
  • 3,940 Answers
The black screen with flashing cursor can be caused by the files needed to boot being located in sectors of the hard drive that can no longer be read.
You can try booting to the XP CD, and go to recovery console and RUN CHKDSK /F See if that fixes the file structure and allows the system to boot. If that fails, you can try a repair installation of Windows. If that fails, the most likely resolution is replacing the HDD and reloading Windows and the drivers.
Posted on Jan 31, 2009
My Acer aspire turns on shows windows logo then goes to black screen, what can I do?
Depending on your version of windows, I would trying starting in safe mode to see if the computer does boot. If it does, then you want to restart again, go to advanced boot options and select "start windows with last known good configuration." Access advanced boot options following the steps at this link. Need to Start Windows 7 in Safe Mode Here How
Jul 18, 2015 | Acer Computers & Internet
Turned of my laptop yesterday. now it wont turn back on, all I get is a black screen and the white arrow can anyone tell me how to get it to work again
Your laptop HAS turned back on.
One thing that is a problem is that the operating system hasn't finished loading.
You may need to use the recovery routine, or the hard disk could be dying.
Jan 30, 2015 | Acer Aspire Computers & Internet
Turn on acer laptop and it goes to black screen that says no bootable device
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Feb 16, 2012 | Acer Aspire Computers & Internet
My emachine laptop has a virus. When you turn it on it goes to black screen with the option to start recovery mangement or start windows.When pressing either,it goes to black screen for a little bit then...
You may have files that you want to keep that you saved on your hard drive, but if you haven't backed them up then you will have to lose them because the only thing you can do to fix this is use the factory recovery disk which will wipe your hard drive clean.Just put the disc into the disc tray and you should get an option to start the recovery disc when you turn on the computer, it will tell you to press a key to start it which might be f3 or something different, I'm am not sure what key but when you have done that you should be able to start the recovery and wipe the hard drive clean and it should solve your problem
Oct 29, 2011 | E-Machines eMachines Desktop PC
When I turn my netbook on it starts but goes straight to black screen and nothing happens, I went to safe mode but whenever I press Entre it reboots and goes to black screen again, I have no cd-rom ... so...
It appears that the computer is infected with virus and may need full system recovery. You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key
& keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on
the computer.
You can also create a set to Recovery disk from the recovery partition, to do so
Start Menu> All Programs> Acer erecovery management> Click Create Factory Default Disk, if you receive any error code or unable to burn the disk, please contact Acer Technical
support at 1 800 816 2237 and order for an Recovery Disk.
Thanks and regards,
Jitha
Nov 25, 2010 | Acer Aspire One PC Notebook
Startup repair won't run
"Unmountable boot volume" this problem is your hard disk partition which is failure to recognize & identify the operating system running on the hard disk. Reformat your hard disk and put another operating system to run again your computer.
Jul 27, 2009 | Computers & Internet
Acer AL1914 black screen, green light
it sounds like a deleted driver? try getting the driver for the monitor, did you loose the Operating system at some point, if so try a system restore to a date when the computer was working properlly prior to the malfunction. It sounds like it restored you to a time before the driver for that monitor was installed.
Feb 16, 2009 | Acer AL1914B Black 19 in LCD Monitor
Computer wont go past a blue error screen
Your hard drive may have quit(died). No good solution other than replace the hard drive. Do you have a restore disk for you computer, to use after replacign the HD?
Here is the website for Acer PC
Dec 19, 2008 | Acer Computers & Internet
Toshiba Satellite A 105
The best solution to your proble\m is use TOSHIBA RECOVERY DISK. Install it, it will reformat your hard drive and will reinstall Windows automatically.
Sep 26, 2008 | Toshiba Satellite A105 Notebook
Acer Aspire 5520-5908 Notebook Logo
2,342 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
