Question about GE Advantium 120 Convection/Microwave Oven
Advantium 120 problem
I returned from being out and found the Advantium 120 non-functional. No sounds with button pushes; only a flashing hyphen (minus sign).
  • 38 Answers
Dis connect from power alow to reset for about a minute . if not there are switches behind the door probably not making good contact make sure door is closed tightly
Posted on Jul 31, 2007
We keep getting A MESSAGE "select action 1.0lb quick defrost" which displays every 15 minutes after any function on the Advantium 120 is used.
I surmise there's a short in the Quick Defrost button on the keypad. Either the keypad has collapsed there, or some contamination has gotten in. Another possibility is a failing program memory bit in the controller chip, but a contaminated keypad seems most likely. What happens if you press and hold that button while trying to key in another instruction? Is there any change in behavior?
Oct 21, 2014 | GE Advantium 120 Convection/Microwave Oven
Only microwave not working
Chances are you have a bad secondary / cook relay on the control circuit board. The relay can be replaced. See details here.
Jul 06, 2013 | GE Advantium 120 Convection/Microwave Oven
I have a 4 year old Advantium 120. I bought it for $685 and had no problems x 4 years. Now renting the house and the unit stopped working. The repairman says there are two switches and a thermostat which...
Considering the possibility that replacement of the switches & thermostat may not solve the problem, I would likely look into replacement. Unfortunately, microwave repair parts are expensive and non-returnable.
http://www.repairfaq.org/sam/micfaq.htm has a section on this decision.
Also, broken units still have some resale value.
Mar 03, 2011 | GE Microwave Ovens
Ge advantium 120 microwave oven completely dead
You have a bad cavity switch. I would guess it is the one behind the vent cover, toward the left side of unit. You would need to remove unit from wall. Remove outer housing to expose cavity switch. You can see it from vent cover, I would test all cavity switches before removing from wall. You should have a diagram of unit folded up behind vent cover towards right side of unit. This tells all workings of unit. Will also tell where all cavity switches are.
Dec 30, 2009 | GE Advantium 120 Convection/Microwave Oven
How do I replace the fuse in a GE Advantium SCA1001KSS?
under the outer cover on a fuse clip its a special fuse avail at hardware stores
Oct 08, 2009 | GE Advantium 120 Convection/Microwave Oven
GE ADVANTIUM - CONTROLS LOCKED- I CAN NOT FIND MANUAL
Try pushing the clear/off button for 3 seconds to lock or unlock the controls.
May 19, 2009 | GE Advantium 120 Convection/Microwave Oven
Built up grease in oven
I've found the best way to get grease to loosen up in any oven is to place a glass or coffee cup of undiluted ammonia in the oven overnight. The ammonia vapors attack the grease, softening it. The next day:
  1. remove the ammonia
  2. mix it with a 2 cups of water
  3. wear protective gloves
  4. using a non-abrasive cloth or sponge wipe the grease off the surfaces.
  5. switch to clean water only, wipe the oven one last time to remove the ammonia residue left by the cleaning.
Mar 29, 2009 | GE Advantium 120 Convection/Microwave Oven
Advantium 120 makes low buzzing sound all the time
this is the transformer that is doing it and it may end up failing soon , and should be replaced before any other dammage is done,
Nov 06, 2008 | GE Advantium 120 Convection/Microwave Oven
Gibberish on the Front Screen
Try unplugging the unit for 30 seconds then plug it back in. The power outage may have been erratic and the MW did not reset properly.
Jun 16, 2008 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
894 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
