Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas
The heater keeps shutting off , getting a 99 code
The heater is shutting off, the outside indicator is flashing red and the inside temperature gauge is flashing 99. I have plenty of gas and it will restart, but then go off and begin flashing 99 again.
  • seapoint416 Jan 31, 2009
    I just read another posting on here, it said that a 99 code could mean that the flu was blocked, so I tromped out through the snow to check the flu. Sure enough it was covered in inch thick ice, which I knocked loose. I came in shut the heater off and then back on...whahla...its back to running just fine. Thank you!!!
  • terry80403 Feb 07, 2009
    I have the same problem but there is nothing visibly blocking the flue. I looked inside the flue with a flashlight and did not see anything that is blocking it. Could the blockage be in one of the hoses to the flue? Also I am concerned about running the heater until I find the problem even though it comes on most of the time. Should I be concerned?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
Terry,
Remove the flex hose from the flue pipe inside the house. Try to start the stove. If it runs there is a problem with the flue. If it's been very cold look closely at the pipe around the exhaust pipe. That is the air side. There could be frost built up inside the air pipe. If so it will shut off the gas and you can't run the stove.
Tom Hawkins
hawkins111@gci.net
Posted on Feb 26, 2009
Frigidaire affinity dryer won't heat. Error reads code r11 what is the problem?
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Apr 22, 2015 | Frigidaire Dryers
Dryer not drying
Apr 16, 2015 | Washing Machines
Zanussi tumble dryer keeps cutting out
Feb 25, 2015 | Zanussi Dryers
My clothes are coming out wet of my indesit g75c tumble dryer and a red light is coming on on the topright hand corner of the machine
overheating.
The heating elements are located inside the heater ducts. If you think a heating element is faulty, test it with avolt-ohm-multimeter (VOM)set to the RX1 scale. Disconnect the leads from the power terminals and clip one probe of the VOM to each terminal. The meter should read about 12 ohms. If the reading is higher ohms, the heater is faulty and should be replaced. Replace a faulty heater with a new one of the same type and electrical rating. A heater connected to a 115-volt line usually has an 8.4-ohm resistance; a heater connected to a 220-volt line usually has 11 ohms resistance.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!!
Feb 19, 2015 | Indesit Dryers
My dryer starts yet wont do anything else than a light flashes and it looks like a tshirt checked filter
Dec 03, 2014 | Dryers
Hoover HNV380 Tumble dryer, has developed a fault that causes the dryer to stop working after a few minutes use. When it stops working, the start light indicator flashes steadily, I have replaced the
overheating.
Nov 15, 2014 | Dryers
What does it mean if I my drying system keeps shutting off before the clothes are dry?
Jun 14, 2014 | Kenmore Elite HE4 Electric Dryer
My panasonic PTLB60NTE shuts down after couple of minutes when I use wireless mode. How can I solve this?
There is three indicators lights on the panel
1. lamp indicator.
2. temperature indicator.
3. computer input indicator.
If your projector shutdown itself without given any indication its mean that your projector function POWER OFF TIMER is on. You can off this function.
How: (two keys back side of projector one is menu second is a joystick witch have 4 arrow keys and center press is enter)
press MENU button to display the menu screen and then use joystick UP or DOWN to select the OPTION menu. press joystick to ENTER and then use joystick UP or DOWN to select POWER OFF TIMER use joystick RIGHT or LEFT to select DISABLE then press MENU two times to exit the menu.
If your projector shutdown itself with given any indication then
If LAMP INDICATOR flashing RED then lamp circuit failure its need to be repair or replace.
If TEMP INDICATOR flashing RED then the temperature inside and /or outside the projector is abnormally high.
CAUSE: The ventilation opening are covered. The room temperature is too high. The projector is located at high elevations (above 1400m)
REMEDY:clean the air filter. Remove the object from the ventilation openings or clear around the projector. Set the HIGHLAND option to ON
Jan 04, 2011 | Panasonic PT-LB60NTE LCD Projector
The radiator fan is not coming on when warm, but I still have heat and not over-heating?
Your heater blower, inside the car works to provide heat to the interior of your car, and the air is hot, right? If the cooling fan is not coming on, depending on the outside ambient temperature, you may be using your heater coil for the heater to dispell suficient heat (inside the car), combined with a low outside temperature to keep the engine at normal operating temperature negating the need for the cooling fan. OR your coolant temperature sensor is bad, and the ECU doesn't know that the engine is hot and to turn on the fan. This sensor works by changing the voltage returned to the ECU depending on the temperature of the tip, which changes the resistance to the computers inquiry. So, the computer knows the temp of the coolant. It uses this information to adjust mixture gauge etc. Most now have 2. One for the gauge, and another for the ECU. So don't go by the gauge working. Then there is the fan motor itself. This can be tested by using a testlight on the wires when the engine temperature gauge in at 3/4 to the hot side of the gauge. The other way to test is to bring a live wire to the motor. If the motor is good, the sensor is bad, if the motor is bad, well the motors bad. I hope this helps you, write back if you need additional assistance. . Please take the time to rate our free service, and my performance. Thank you for trying FixYa.com!
Apr 13, 2010 | 1989 Oldsmobile Cutlass Ciera
1996 buick park ave. , heater fan for inside
the ac computer is on the fritz or the ac control panel has a short in it
Jan 19, 2010 | 1996 Buick Park Avenue
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas Logo
264 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
