Question about Alpine CDA-9883 CD Player
IPod will not work.
I just installed an Alpine CDA-9883 stereo with a direct connect to an iPod. I plug in my 80gb and the stereo simply says, "Searching," and never changes. My wife's 4gb nano worked perfectly with it. I have read about going back to previous versions of the iPod software by restoring the factory settings. This did not work as my iPod came with version 1.2.1. I am pretty frustrated and do not know what to do, any suggestions?
  • 3 more comments
  • Paul Harvey
    Paul Harvey Jul 30, 2007
    I spoke with Alpine today. They stated there have been many problems with the 80 gb iPod and their stereos. The customer service guy basically said it will not work unless Apple changes their firmware. I guess I get to hassle them now. Thanks for your help though.
  • endymion Nov 30, 2007
    My 5th Gen Video Ipod (30gb) also does not work! It just shows "searching when I connect it to my Alpine CDA 9883. I have version 1.2.1 on it. I will try to update to 1.2.3. The manual for the Alpine says it won't work for earlier than 1.1.2. It seems crazy that it will not work for newer versions of the firmware.
    Any suggestions?
  • gardog Dec 30, 2007
    i pod 80gb will not work did i hook it up wrong or whar?
  • RAEMAN May 08, 2008
    I have a Alpine CDA-9883 & I'm having the same problems with my ipod which is a 30 gig. I am on my second cable, the first one worked fine until it got bent at the connector. So I bought another one it worked for 5 days & now all say's is it's seaching. If anyone has a cure please let me know. FRUSTRATED!
  • flipsrock May 29, 2008
    i have encountered the same problem with my 60g ipod video. i updated the ipod software and the problem persists. the following seem to work: unplugging and replugging in the ipod, turning the deck on and off, and toggling through the source button. i am going to go back to the dealer and see what they have to say or if anyone else has had this problem and how they fixed it. if i find anything useful i'll post it a.s.a.p.
This seems like an old, dead thread, but maybe someone else will stumble across it.
I have an Alpine CDA-9883 w/ the KCE-422i ipod cable. Audio was working fine, but I was unable to change playlists, or search music on the iPod (an iPod Photo, 1.2.1 OS).
After experimenting for a while, (disconnecting & reconnecting the cable, resetting the head unit, & resetting the iPod) I finally stumbled across a solution (of sorts.)
I did two things, and I'm not sure which of them actually worked, but it's working properly now. 1) I completely restored the iPod and reloaded all the music using iTunes, 2) I did not allow it to sync album art. I happened to notice in another forum that another one of the newer Alpine head units had problems with album art, so I took it off the ipod. Whether it was this, or the complete restore that worked, I'm not sure. However, neither my nano nor my iphone work properly and they both have album art. So maybe that's the problem.
But here's the odd part. After I got it working, I changed the Sound Check value to "on" and changed the Equalizer on the iPod and it stopped working again. When I turned the equalizer off, it started working again.
Apparently the head unit is very finicky about the settings on the ipod.
Hope some of that helps someone else. Now it works great, and I'm very happy with the head unit/ipod connection.
Posted on Sep 15, 2008
    Scholar:
  • 67 Answers
Restoring factory settings won't revert the player back to previous ipod software. Check with the alpine website product support and see which ipod software versions are compatible with the car deck you installed. I would think the latest version would be supported. then go to the apple website and download the most recent version of itunes that alpine says is compatible. connect your pod and open itunes. upgrade the pod to that itunes version and try it again with the car deck.
Posted on Jul 30, 2007
  • jim fitterer
    jim fitterer Jul 31, 2007
    A temporary solution would be an FM transmitter. DLO makes a decent one called Transpod. You lose some sound quality, but they work fairly well. Also, Harmon kardon makes a system they call Drive + Play. It can transmit your tunes via FM transmitter or through a direct antenna connection.
    The best thing I've found is a device made by Peripheral called Ipod2Car. It connects in place of your CD changer and you get CD quality sound from your iPod. It's not real expensive but can require a bit of installation. You should be able to find any of these items on Amazon for under $100.
Simple solution sued  class action file by everybody that bought cda 9883 or cda 9885 they both have that issue just like apple was sue over there battery issue and i  would bet tell will come up with a response or solution  its there problem not apples they advertise that is compatible with apple there for it should work  because they follow apple  the apple ipod works fine by itself there for its not apples responsibility
Posted on Feb 15, 2008
SOURCE:
Setting up ipod to CDA-9885R
The ipod cable plugs into the rear of the stereo. Here is a link to the installation manual:
http://vault.alpine-usa.com/products/documents/CDA-9885%20OM.PDF
Aug 23, 2012 | Alpine CDA-9885 CD Player
Cda 9883 - no sound
Check for blown fuses behind the deck and under the hood, sometimes by the battery, you may get lucky but you could have smoked the unit, and would not know anything unless you send it in to get fixed. Replacing the unit could be the answer Alpine CDA-9883 CD Player
Feb 20, 2010 | Alpine CDA-9883 CD Player
I have an alpine cda-9883 cd won't eject & error
try detaching the "face" and there should be a little button that you can only push in with some kid of really thin stick,maybe a pin that will reset the cd player and hopefully work
Oct 27, 2009 | Alpine CDA-9883 CD Player
Alpine cda- 9883 radio will not recognize ipod
your ipod might be too new,and your cd player too old the alpine cda 9883 is a 2007 model what kind of ipod do you have,if uyou have an older ipod and got the new itunes9 then try downloading an older version of itunes from itunes.com .....good luck
Sep 26, 2009 | Alpine CDA-9883 CD Player
Where do I plug in the ipod adapter to Alpine
The back.
There should either be a proprietary CD changer plug you can plug an ipod adapter into, or you will need to connect an adapter inline with your antenna. Depends on what equipment you have.
Mar 20, 2009 | Alpine CDA-9883 CD Player
Cd/dvd alpine stereo no sound cd reads
Vehicle type? Factory amplified? Just installed?
May 11, 2008 | Alpine CDA-9883 CD Player
Radio has sound but not the CD player or iPod
Your amp is not turning on - what you should do is connect the "blue/white - remote turn-on lead" to whatever wire you have the "blue - power antenna" output from the Alpine connected to now. That should solve your problem.
Mar 07, 2008 | Alpine CDA-9883 CD Player
Cda 9883 and cda 9885 2008 model no song issues
My ipods fuction fine with my Alpine CDA-9885 ... have you tried pressing the display button on the Alpine? The KCE-422i cable takes quite a beating ... You might check the cables.
Feb 14, 2008 | Alpine CDA-9883 CD Player
Cd plays, but no sound
Disconnect the blue wire from the back of the radio and connect the blue/white wire in its place. This should fix your problem.
Apr 29, 2007 | Alpine CDA-9833 CD Player
Alpine CDA-9883 CD Player Logo
619 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Jeffrey Turcotte
Jeffrey Turcotte
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
