Question about HP DeskJet 5550 InkJet Printer
Hp 5550, cartridges not recognized,
Replaced cartidges, still wont work
  • rosalesy Feb 06, 2009
    I cannot get the light to quit blinking. I have also put in new cartridges and it does not seem to recognize them.
  • 3 Answers
I had the same problem but i only replaced my black cartrage ink and my color was empty so if one is empty remove it and it will work
Posted on Feb 13, 2009
HP5550. Color ink ran out. Replaced with refilled cartridge, ink light still flashing. If I use an original cartridge this does not happen. Shop tells me cartidges are fine and proved it
some HP printers do this after a non original cartridge used The printer should still be able to operate even with the light flashing. If this does not work you may require to replace the print head.
Mar 21, 2011 | HP DeskJet 5550 InkJet Printer
I have an HP 5550 printer. The Ink Cartridge light continually blinks (and nothing prints) when I have both the colored and black cartridges installed. When I remove the black cartidge, it works fine and...
More than likely you have either a defective 56 (black) cartridge or it's empty. If you have Windows XP you may go to control panel and select printers and then right click to get to properties and preferences. From one of those you can get maintenance and attempt to do a clean and see if that works. If you have a cartridge refiller in your area take the cartridge to them and get it weighed....they'll know if it's empty or not by the weight. If you're lucky enough to have a kitchen scale that weighs in gms then weigh it yourself...if it's empty then it will problem be in the mid 20's vs. mid to upper 30s when it's full. EBAY has lots of 56 cartridges for sale and they will usually work just fine. The tri-color ones are more of a crapshoot.
Aug 14, 2010 | HP DeskJet 5550 InkJet Printer
Trying to use a re-filled ink cartridge HPf4280
I seem to recall that these cartridges are chipped and you need to get a chip resetter. Look on the base to see if a small circuit board is present. If so then you have to get it reset or buy a new cartridge.
Please rate my help++++Thanks for using FIXYA
May 18, 2010 | HP LaserJet 4200 Printer
Printer does not recognize Black cartridge. How do correct it? Clean it? This is the 3 or 4th replacement cartridge. The color cartridge light goes on, the black does not light up at all .
the black cartidge slot has gone bad and u wuld have to replace the printer ... coz the copper strips/dotted lines which u see on the ink cartidges, you wuld find similar thing inside the slot ... that acts as an sensor .... its gone bad.... sorry
Apr 14, 2010 | HP D4360 DeskJet Printer InkJet
I refilled an ink cartridge on my hp deskjet 5550 printer and now it says that my cartridge in not compatible with my printer, although it is the same one I was using before.
try cleaning the contacts
if your printer is still not recognizing the cartridges
you must replace the one with the problem
 you must be very cure full with the refilling process cause the new cartridges are very sensitive if they have air inside.
you must pull all air bubbles from the spong check here how you can
http://www.youtube.com/watch?v=dhDaKSzou50
Apr 09, 2010 | HP DeskJet 5550 InkJet Printer
Prints blank pages
did you remove the "blocking tape" (usually a blue colored film) from the ink cartridge before installing? If not, then it might have come loose blocking the contacts, remove your ink cartidge and take a look, that will most likely resolve yoru problem.
Feb 08, 2010 | HP DeskJet 5550 InkJet Printer
Ink cartridge 56 and 58
the printer itself recognizes cartridges
hp 57 print cartridge
hp 58 photo inkjet cartridge
and hp 28 inkjet print cartridge
any other cartridges will be of no use for this specific printer
Oct 31, 2009 | HP DeskJet 5550 InkJet Printer
Printer won't recognize color cartidge
Did you try another cartridge? Try reinstalling the old cartridge and see if the message is different. If so, replace the cartridge.
Aug 18, 2009 | HP Officejet 7210 All-In-One InkJet...
Hp 5550 color printer
original HP, or remanufactured? Put it diagnostic made and see if it prints -
Apr 21, 2008 | HP LaserJet 5550 Printer
HP doesn't recognize black cartridge, Mac user
if you are using a remanufactured cartridge, exchange it in the store, cause it is with problem on it´s internal circuit.
Apr 07, 2008 | HP DeskJet 5550 InkJet Printer
HP DeskJet 5550 InkJet Printer Logo
138 people viewed this question
Seeker5211
Seeker5211
