Question about Indesit WA 125 Front Load Washer
Indesit washing machine WIXE127 switches off main fuse
My washing machine is 12 months old and for the last 2 days, when I try to switch on the washing machine, the main electrical fuse box switches off. Why?
I've changed the fuse (13A) in the plug, but still the same problem.
  • ukpapillon Jan 31, 2009
    I Switched off all plugs in the house and tried only the washing machine. Same problem, the main fuse switches off still. What can it be?
  • 4 Answers
Try pluging into a diferent socket as the socket may be bad(they draw alot of power washine machines and the socket can wear quickly) If still does it electrical fault, in the machine! Modern fuse boards will trip if a light bulb blows.so not the fuse or the machines fuse! May even be a leek in the machine!
Hope this helps
Posted on Feb 25, 2009
  • 150 Answers
Have you added anything else that is drawing juice on the same breaker?
If so try turning those off.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Posted on Jan 31, 2009
Error code 008 on indesit wixe127. What is it and how can i fix it please?
F08: Wash Heater Relay Stuck (signalled in presence of empty) or pressure switch stuck on Full (simultaneously empty and full)
- Check efficiency of J3 connector contacts on card
- Check pressure switch status by checking ohmic continuity on wiring connector J3 pins 2 and 4 (it must only be present with
tub empty), pins 2 and 3 (it must only be present with water in the drum) and pins 2 and 1 (it must only be present with water in the tub above normal level, more than halfway up door glass).
- Check wiring J3/pressure switch
- Check connection of heating element J3 connector pins 5 and 6.
- Replace pressure switch
- Replace Card
Dado
Dec 27, 2014 | Indesit Washing Machines
Where are the brushes on wixe127 indesit washing machine
I am presuming someone has told you that the brushes need changing?
Those will be the motor brushes then ;-0)
My comment:
It can sometimes be false economy to just have the brushes changed although financially very attractive. Experience of others is that the brushes may only last months unless, that is, the motor is totally refurbished at the same time. It depends on how old the motor is and how much wear the commutator has had.
The problem is that motors are expensive because they are such well made and hard worked pieces- our 19+ year-old Bosch motor (and belt at the same time of course) cost GBP 250 but will probably outlast us!
Good luck,
John C
Mar 08, 2011 | Washing Machines
All lights flash on indesit washing machine soon after switch on
Indesit washing machine lights come on briefly when awitched on at mains and then no power
Feb 17, 2010 | Indesit W 123 Front Load Washer
Indesit washing machine wixe127 has f04 faultcode starts cycle then empties and fills simultaneously
Error code F04 indicates pressure switch jammed on empty.
to rectify, do the following
Remove lower rear panel of washer.
Remove large black hose on drum
Remove and clean filter inside hose.
Remove hose onto pump and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Washing Machines
Error code f-08 on indesit wixe127 washer
Error code F08 means that the heaterrrelay cannot be activated.
Check the connections to the Pressure switch, the Module,and the Heater element.
If you can, test the element of the heater to make sure it is o/k.
Hope this helps.
Dec 02, 2009 | Indesit W 123 Front Load Washer
Wixe127 indesit wash machine gets to 1 minute left on wash cycle and just keeps running with 1 minute on display
If all you are getting is a wash cycle and not a spinning cycle this could indicate a faulty door switch. the machine will not allow a spin cycle unless the door is locked.
Oct 10, 2009 | Washing Machines
Error code F-03 Indesit wixe127
Hi.
The code F03 means the wash thermistor is open circuit.
Unfortunately, you will have to call an engineer.
Cheers.
Nov 18, 2008 | Washing Machines
Hi i have a indesit wixe127 and when i switch it on it comes up with deno and will not wash wot is wrong with it
I had the same problem with DENO, while we run the wash machine i press start button and step easier(try the start button and click buttons simultaneously until the code DOF) button until DOF code came, after everything went well. e.ladislau@yahoo.com
Jun 19, 2008 | Indesit Washing Machines
Washing machine blown fuses
Hi - had a similar problem with about 3 different makes of washing machine - the RCD switch on the main household fuse box was continually tripping . Nobody could give me a right answer . Eventually ended up with a Hotpoint . Felt sorry for the delivery guys from the electrical retailers having to keep dragging machines in and out .
May 07, 2007 | Indesit WA 115 Front Load Washer
Indesit WA 125 Front Load Washer Logo
508 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
