Question about Compaq Armada 1700 Notebook
Hard drive controller
I am getting a hard drive controller error when running Compaq diagnostics. The same diagnostics program says the hard drive is fine. It passes all the tests. I get a" smart hard drive detects imminent hard drive failure " message when I boot up. I press F1 to ignore & it boots up fine. Then depending on the size of programs I run it will blue screen with a error & begin a memory dump. Sometimes it will run fine until I close it out. Other times it will not even complete loading the operating system. I am running Microsoft 2000 Pro. Is the controller replaceable? Do I need a new motherboard? Is there anything else I should look for etc. Any help is appreciated.
  • 65 Answers
Certain diags only test the diagnostic tracks. That is what's passing more than likely. You should boot the laptop in safe mode (F8) and click start, run, type in cmd, hit enter and type scandisk. This will do a complete scan on the drive. If there are any errors replace the drive.
Posted on Jul 30, 2007
SOURCE:
Error 301 hard
Compaq laptop has detected a SMART fault. You should backup your data and test the harddrive with the maufactures diagnostics like Seatools for Seagate. Run a short DST. Drive may pass. I would still replace it. Clone your current drive to the new one. The drive is probably on its way out.
Aug 20, 2012 | Compaq Presario CQ61-310US Laptop
Compaq armada 1700-when powering the system the following error appears "Error loading operating ststem"
There is a good possibility that the hard disk drive may be failing, so if you can try running diagnostics and see if you get a failure on the hard drive.
If you can't run diagnostics, then boot to your Windows CD, press R for recovery console, then at the command prompt run the command CHKDSK /R see if you get any errors on files.
If that doesn't resolve, then boot to the windows CD press enter instead of R and repair windows.
If that still fails, then the hard drive is likely bad
Aug 20, 2011 | Compaq Armada 1700 Notebook
I have an HP dv6700 that won't boot windows. It's running vista 32 bit with Phoenix bios on there. I have tried a recovery disk but there seem to be no startup errors nor did it find memory nor hard drive...
BIOS diags do not test RAM's Windows functionality. Download Microsoft's Memory diagnostic too and burn to a cd. then test your memory.
To run Windows Memory Diagnostic, you must reboot your computer with the disk or CD-ROM on which you installed Windows Memory Diagnostic in the drive. After the reboot, Windows Memory Diagnostic will load and its interface will appear. After loading, the first test pass will begin, using the default standard test suite, and continue until complete, unless Windows Memory Diagnostic is either paused or exited. Once the first test pass is complete, Windows Memory Diagnostic will begin a second test pass using the same settings as before. Windows Memory Diagnostic will continue to run test passes until you exit.
http://oca.microsoft.com/en/windiag.asp
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 21, 2011 | HP Pavilion DV6700T Notebook
I get the error code 2000-0146 only when i run the f12 diagnostic
The 2000-0146 error code indicates a read/write failure of the hard drive. There is at least 1 sector that is failing on the drive. While it is working at the moment, the drive is failing and will over time degrade and eventually fail completely. Backup any important data, then replace the drive.
Dec 11, 2009 | Dell Computers & Internet
Biohd-5 Error upon running diagnostic. How to
1. Restart the computer.
2. Keep tapping the F10 key when the HP logo appears. BIOS Setup Utility.
3. Select the Diagnostic tab.
4. Select the "hard drive self test" option and press enter to perform the test. Note: This test takes atleast 40 minutes. This will take you to
Pass - The hard drive is not damaged.
Fail - The hard drive is damaged and may need to be replaced.
Aug 04, 2009 | HP Computers & Internet
How to fix Hp slimline Error Code BIOHD-5
2. Keep tapping the F10 key when the Compaq logo appears. BIOS Setup Utility.
Mar 09, 2009 | Computers & Internet
HP Compaq nc6400 does not boot
i missed recovery cd fot HP Compaq nc6400
May 07, 2008 | HP Compaq nc6400 Notebook
These can be fun and Hdd/IDE/SATA Controllers on Desktops are different than laptops.. Embedded controller chips as well as the Northbridge/Southbridge chips are integrated to everything else and its a nightmare to track down period. (Ive had to replace Integrated Modem chips to cure a Boot or BSOD error that states the Video Adapter needs to be changed) ..(Generally due to Power surge or other).. You are on the right track however and I'd just suggest running Memtest of the Knoppix to start be4 I can say other. Is there Shared or dedicated RAM for the GPU on this one? They manned both ways depending on the specific board revision..
Talk soon, Ken
www.ikenfixit.com
Nov 10, 2007 | HP Pavilion dv1000 Notebook
Hard drive controller again
I don't think you have a hard drive controller fault as such... more like your hard drive is going "Flakey" meaning it is developing "Bad Sectors" IE the magnetic media going bad, this is common occurance.. I think you had better backup any valuable data and get a new hard drive and transfer your "Old" drives contents to your "New" drive. There are many programs that can do this for you.. Just Google it. One could install the New hard drive as a new "Master" and set the old as "slave" install a new operating system on the "new" one and then transfer the data from the "old" drive to the "New" and then ditch the "old" ya be good to go.
Jul 30, 2007 | Compaq Armada 1700 Notebook
Hard drive controller problem
S.M.A.R.T (system monitoring)is the warning software that detects when a hard drive is about to fail, so i would back up any important docs to a disc or usb drive immediately and replace the hard drive. The hard drive controller itself will not be the problem, it's the controller saying that the problem is the drive, the controller is only a driver and not a peice of hardware, pressing F1 will ignore any faults and continue to boot, but especially if it doesnt always boot it's definately your hard drive.
Jul 26, 2007 | Compaq Armada 1700 Notebook
Compaq Armada 1700 Notebook Logo
105 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
