Question about Garden
Need to tune up old lawn mower
Need specs on spark plug gap, setings for idle and rich/lean screws for a kawasaki engine
#fc150v176157
john deer lawn mower JD906
another number stamped on engine was 890408
thanks-- cody
  • 246 Answers
SOURCE: John Deere 14SB mower with Kawasaki FC150V series - Throttle adj.
Hello rfbarrett:
From your Description it Sounds like the Plate that is Attached to the Carburetor (that the Throttle cable Attaches to) Thru Shaft (holds and Moves the Throttle Valve) has Loosened and is Simply Turning on the Thru Shaft and Not Moving the Thru Shaft and Throttle Valve at All.
>>You can View a Breakdown/IPL of the Engine and Mower at this Site Addy, http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt and Enter the Model Numbers 14SB and Click Find. Then Select your Model from the Search Results Area. Then Select the Sectional File. Then Select the Section of the Mower you Wish to View Online. *You can Drag the View Windows for Better Viewing.*
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
centralvalle
  • 386 Answers
SOURCE: what is the spark plug gap for a 6.5 craftsman
.025 "
Posted on Aug 11, 2009
  • 143 Answers
SOURCE: 4.5hp B&S engine on a bolens mower..won't idle steadily
This is called hunting, your fuel-air ratio is not right. Your carb. jets need cleaned
Posted on Sep 05, 2009
Testimonial: "Thanks...always get great advice on here...."
  • 12761 Answers
SOURCE: John Deere LT155 Lawn Tractor has trouble going uphill
u can change belt yourself need belt size and have to remove cutting deck but check belt tension first if loose with brake off belt stretched out and slipping needs replacement
Posted on Sep 29, 2009
  • 78 Answers
SOURCE: blade belt diagram for John Deere LX178 Riding
Remember the belt rule, V of the belt goes in V pulleys.Flat pulleys that are stationary or move get the back of the belt. You can figure it out. Its not rocket science. Remember at some point there has to be a tensioner,usually gets the back of the belt if its a flat pulley. U may have to remove the spring and then reattach the spring after the belt is routed.
Posted on Oct 29, 2009
Spark plug setting for #kkw48141 ,I need to know the gap setting for a 14.0 HP Kawasaki motor
Spark Plug Gap Specs show .028 to .031
I set mine at .030 Hope this will help
Oct 21, 2016 | kawasaki Garden
John deere model FC420
Specifications
Engine HD45
Engine Model Number(Kawasaki FC420V
Horsepower (10.5 kW (14 hp)
Displacement (423 cc (25.8 cu.in.)
Crankcase Capacity w/o oil filter (1.3 L (1.4 qt.)
Crankcase Capacity with oil filter (1.6 L (1.7 qt.)
Spark Plug-Gap (0.64 mm (0.025 in.)
Spark Plug-Torque (20 N·m (15 lb-ft.)
Cylinders (One
Stroke/Cycle (Four
Lubrication (Full-Pressure
Oil Filter (Standard Single Element
Air Cleaner (Dual Stage
Engine HD75
Engine Model Numbe(Kawasaki FC540V
Horsepower (12.7 kW (17 hp)
Displacement (535 cc (32.6 cu.in.)
Crankcase Capacity w/o oil filter (1.6 L (1.7 qt.)
Crankcase Capacity with oil filter (1.9 L (2.0 qt.)
Cylinders (One
Stroke/Cycle (Four
Fuel System
Fuel (See Fuel in the Service Miscellaneous section
Fuel Filter (Single Stage, 60 Micron
Fuel Pump (Vacuum Operated-Diaphragm
Fuel Delivery (Gravity Feed to Fuel Pump)
Fuel Tank Capacity (19 L (5.0 gal.)
Drive Train Mower Deck (36-inch)
Blades (2
Blade Bolt Torque (81 N·m (60 lb-ft.)
Cutting Heights (25-114 mm (1-41/2 in.)
Weight (86.7 Kg (191 lb)
Overall Width (chute up) (927 mm (36.5 in.)
Mower Deck (48-inch)
Blades (3
Blade Bolt Torque (68 N·m (50 lb-ft.)
Cutting Heights (25-127 mm (1-5 in.)
Weight (83.6 Kg (184 lb)
Overall Width (chute up) (1308 mm (51.5 in
ower Deck (54-inch)
Blades (3
Cutting Heights (25-127mm (1-5 in.)
Weight (86.7 Kg (187 lb)
Overall Width (chute up) (1460 mm (57.5 in.)
Recommended Lubricants
Engine Oil (John Deere PLUS-4
Grease (John Deere MOLY HIGH Temperature EP
Transmission Oil (HY-GARD-J20C (TURF-GARD-SAE10W-30 (PLUS-4-SAE10W-30 (TORQ-GARD SUPREME-SAE30
(Specifications and design subject to change without notice.)
Sep 28, 2016 | John Deere Garden
What is the spark plug gap seting fot Champion RJ19LMC?
.30 is the standard for most lawn mower engines...you might check the "engine specifications" in your owner's manual to be sure.
Aug 22, 2014 | Troy Bilt 5.5hp Self Propelled Mower
I have a John Deer riding lawn mower SX95 with a fb460v kawasaki engine that only starts with fuel dropped into carburetor I have a good spark , I had changed the oil and filter , I also took the carb...
in the carb did any of the screws have any micro bored holes for gas to go through like in many small engine iv found . clogged with goop. does it have a gas bowl an a screw on bottom take it out if does an look it over close.
Jul 25, 2014 | John Deere Garden
John deere ride on problems
Black smoke indicates rich mixture. Dirty air filter. choke stuck on. loose main jet in carby. just a few possibilities.
Dec 31, 2012 | Oregon Scientific Oregon Gator Mulcher 3N1...
I have a john deere 70 1974 with a 7 horse power tecumseh how many times to i turn the either jets on the carb
The bottom screw on the carburetor is the main fuel mixture screw, turn this "in" slowly until is "seats" and then back it out two turns. The idle mixture screw is located on the side (do not confuse with the idle speed screw), turn this in slowly until it seats and then back it out one turn. This will get you in the ballpark but it will have to be fine tuned from their. The proper adjustment is between a "lean" running condition (engine will try to cut off) and a "rich" running condition (engine will load up). The main fuel mixture is adjusted at full throttle position and the idle mixture screw is adjusted at idle speed. Once this is done, you can adjust the idle speed screw in the low throttle position. Hope this helps.
Feb 23, 2011 | John Deere Garden
I HAVE A JOHN DEERE LX188 MOWER. 17 HP. GOVENOR NEEDS ADJUSTING.
Your engine per John Deere is a Kawasaki FH500V
Here is the service manual (3.58 Mb pdf file) This should get you going again.
http://www.gardenresources.co.uk/content/garden_machinery/manuals/husqwm227_hwen2002_0000000-01.pdf
Jan 23, 2010 | Garden
Garden Logo
232 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
