Question about Arris Touchstone 450a (CM450) Modem
Unable to connect Linksys wireless router to my arris cm450a
The arris cm450a has a cable connection like your tv, the computer does not have a Ethernet connection, just usb. can this wrt54g2 wireless router be connected or not? or just needs a adapt
  • 40 Answers
All routers will only work with ethernet. You would need to get an ethernet card installed in your computer. You can probably buy one for about 20.00 at Walmart. If you don't want to do this you can purchase a usb/ethernet adapter and still use the usb port on your computer. You can purchase one of these for around 5.00's on ebay. Just go to ebay and search for usb/ethernet adapter. Please rate if this has helped. Thanks.
Posted on Apr 10, 2009
I need the wep security code for my sons dsi to download games on it from the internet. router name arris model # cm450a
When you did the initial setup for your router, you should have configured the wireless adapter in the router:
* set a SSID -- the "name" of the network
* set an encryption-level -- hint: use 'WPA' or 'WPA2'
* set a password for your network
It's that SSID/password that you need to enter on the DSI, to make a wireless connection to your router.
Apr 21, 2011 | Arris Touchstone 450a (CM450) Modem
I am unable to set up my Linksys WRT150N router security. I am using a Mac Computer OS X v10.5.8. I can access the internet using the router but only through an unsecure connection. When I go to change the...
Is there any computer connected to the router ?
If not then you will need to connect the computer
to the router.
Do not change any wireless settings on the router
with the wireless computer.
you will need to connect the computer to the
router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the
router.
Now once you change the network anme and security
on the router, you will need to connect to the
wireless network on your wireless computers.
Click Here for step by step instructions
Jan 24, 2010 | Linksys Wireless-N WRT150N Router
WIFI not working with Linksys wireless-g broadband router/Comcast
Unplugging the wireless router and connecting it again should not have altered the wireless connection/configuration. You have connected the cables correctly because the Internet works when you connect a LAN cable to the router.
The Linksys wireless configuration or the wireless card configuration in the computer was changed it to lose the wireless connection. The wireless card configuration needs to be changed to match the wireless router's settings or change the Linksys with new configuration settings and configure the wireless card accordingly.
To secure your router with a login password and wireless security, please follow my instructions - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Should you need further assistance, please leave me a comment.
Dec 25, 2009 | Linksys Wireless-G Broadband Router
We have just signed up for cable TV/high speed internet/cable telephone. The modem provided is an "Arris" version 1.5. The cable tech said I could connect my Belkin G router so that more than one computer...
Plug the ethernet net cord into the arris ethernet port. plug the other end into the router where it says "internet"
Plug a ethernet cable from one of the router ports to the computer.
First start up the arris modem, then power up the router, then start the computer.
Oct 22, 2009 | Belkin 802.11g Wireless Desktop Network...
Can't install linksys wrt54g2 router with arris tm602g modem
I've tried network magic and everything thing else and I still can't get it to work.
Sep 28, 2009 | Linksys Wireless-G WRT54GS Router...
Trying to connect my ps3 to the internet but need wireless route
That won't work because your old sbc wireless router 2wire gateway is also a modem. You need a plain router for Time Warner. Try Linksys router.
Sep 08, 2009 | 2wire (1000-100052-000) 802.11g/b Wireless...
Unable to set up wireless router
Shut down your computer, unplug the cable modem and the switch. Connect all three - computer to switch, switch to modem. Make sure that the ethernet cable between the router and the modem is in the router uplink port and that the computer is plugged into one of the four ports that look alike. Wait 30 seconds - plug in the modem. Wait another 30 seconds, plug in the router, wait another 30 seconds and boot the computer. Open a browser and see if you have internet access. If you still don't, then try to check the browser by typing 192.168.1.1 into the address bar of the browser. That should give you the browser sign in screen. The Linksys default is to leave the user name blank and type admin for the password. That should give you access to the router so you can check the settings. If this doesn't work, document carefully what happens and post again with your results and we'll try to go from there.
Jun 08, 2009 | Arris Touchstone 450a (CM450) Modem
My IMAC ethernet connection to my wrt54G is much slower than wifi
Then you have your settings wrong, as I have the same setup for many years. The setup page of your router should be set basically default, it should be all set to auto ip and other than your dns there should not be anything else to set. I have 3 wireless and two wired devices and all of the computers .And the speed is constant,,something is wrong with your settings, if you can take a screenshot by opening the router homepage and hitting the print screen button on your keyboard, you can then hit paste on here and it will past the entire thing on here to examine
Mar 20, 2009 | Linksys Wireless-G WRT54GS Router...
How do i connect a Linksys wrt54g2 to a arris cm450a
Your modem is capable of linking up to a router. What you do is take an ethernet cable and run it form the internet port on your modem to the internet/wan port on your router. From there you connect your pc's into the LAN ports on the router (typically labeled 1-5) if they are hardwired or you connect wirelessly with your laptop. You need to also power cycle/reset your modem when you plug your router in.
Jan 31, 2009 | Arris Touchstone 450a (CM450) Modem
No ip address from modem to linksys wrt160 n router
1).turn off the modem and the router.disconnected from the Internet ISP. and the computer.
2).disconnect the router from the modem.
3).turn on the modem.
4).connect the router to the modem, and turn on the router.
5).connected the computer to the router, adn turn on the computer.
if you are using wireless, waited about 5 minutes before turning it on.
goto control panel>>wireless network, and configure the wireless seting.
Nov 17, 2008 | Arris Touchstone 450a (CM450) Modem
Arris Touchstone 450a (CM450) Modem Logo
845 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
