Question about Samsung HLP5067W Television
My samsung hl-p5067w does not work
Lamp light was blinking and i replaced the bulb, lights continued to blink and i reset the back cover to depress the lever. but now i still get the same lamp light then all three lights start blinking
  • Anonymous Apr 05, 2009
    My TV is in the shop with the same problem. The repair man thinks it my be the light engine, which is expensive he said it will cost over
    $600.00 to repair. will give you an update when it is repaired.
  • 3 Answers
I would see if it's the lamp ballast only about $100.00 and easy to replace, it's the part underneath the lamp that fires up the bulb. The light engine itself is over $900 to buy and not worth it! I have same T.V.
Posted on Apr 15, 2009
I have a Samsung HL-P5067W/HL DLP tv. When I turn it on cold the lamp light blinks on and off. The fan makes a high pitch sound a relay clicks the TV goes back to standby and the lamp light starts blinking...
This sounds like a lazy lamp--that is getting hard to start. Try a new lamp first. If you are inclined to do so--get a bard bulb and install in the old lamp housing and save some money. Get a real PHILLIPS bulb--it will last a while--compared to cheap generics that are good for maybe 6 months !!
Feb 18, 2014 | Samsung HLP5067W Television
My HL-P5063W won't power on. I replaced the Digital Video Board and the lamp. When I power up the the TV, there are several clicks and never a picture. The lamp does not appear to getting any...
Did u ever replace the Ballast board for this tv?No?,that ur tv problems.The Ballast board only job are to ignite the tv projection lamp to make it work.U hearing multiple clicks,lamp never ignite up the Ballast board.
Jul 29, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
When we turn the TV on, a red light starts to blink but no image or sound is displayed. How can this be fixed?? And What is causing this? my TV model is HL-s5679w
The Blinking light is an error code, most likely you just need to replace the bulb which is fairly easy, there is an access panel on the back and you should be able to replace your self. A new bulb should include basic instructions here is a link price is $110
Sep 14, 2010 | Samsung HL-S5687W 56" HDTV
Samsung HL-S5679W won't start - LED light blinking
Replace Lamp,but CK to make sure Fans are running if OK then replace Lamp Mats Has them for 99.00
May 11, 2010 | Samsung HL-S5679W 56" HDTV
LAMP light blinking after replacement.
Lamp Fan or Ballast board,problem could lead back to Dmd Module Encompass Parts Distubtion has what you need for this Set 1-800-638-3328
Feb 24, 2010 | Samsung HL-P6163W 61" TV
Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Jul 11, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
When turned on, the lamp light continually blinks with no picture
You ever get a resolution to this issue? Was it the bulb?
Jun 12, 2009 | Samsung HL-T5076S 50 in. TV
Samsung HLP5067W Television Logo
309 people viewed this question
Jerry Greenberg
Jerry Greenberg
